Question about Apple 20gb Ipod Mp3 Player With Click Wheel System
I reset the my ipod just like the apple web site said. Then it showed a power cord going 2 an outlet from the wall. So i plugged it in the wall. It still showed it. Then I pressed the menu and center button like the web site said to do. It went a way and showed a charged battery. I pressed to turn it on an the apple showed on the screen for a few seconds and then went back 2 showing that I need to pug it back into the wall. What can i do now?
You must have a 3rd or 4th gen Ipod. It should not do this with a reset. If you reformat it through Itune , then it will. The plug into a power outlet means it is trying to reformat. If it will not, your hard drive is corupted or logic board. If it is the hard drive and you can get it to show on your computer, you can go to your disc utilities and erase the hard drive by writing zeros. then connect to Itunes and reformate. Plug into a power wall charger and it should complete. You need a good charge in your battery. If your battery is not charging or needs to charge , that will stop it from completing a reformat. I hope this helps.
Posted on Feb 13, 2010
On the ipod 20gb after apple logo comes then bettry logo comes
Reset Click Wheel Ipod (newer ipods including resetting an ipod video)
1. Flip the Hold switch on and off and make sure it ends up no longer on hold.
2. Press and hold the Menu and Select buttons (center Button) until the Apple logo appears (may take 5-11 seconds, and you may need to repeat this step)
If this not work for you try plugging your ipod into computer or wall power
Resetting iPod (with dock connector)
Most problems with iPod can be solved by resetting it.
To reset iPod:
1 Connect iPod to a power outlet using the iPod Power Adapter.
2 Toggle the Hold switch on and off (set it to Hold, then turn it off again).
3 Press and hold the Play/Pause and Menu buttons for at least 5 seconds, until the
Apple logo appears.
If Your iPod Won't Turn On or Respond
* Make sure the Hold switch is off.
* If you're using the iPod Remote, make sure the remotes Hold switch is off.
* If that doesn't work, connect iPod to the iPod Power Adapter and connect the
adapter to a working electrical outlet. Your iPod battery may need to be recharged.
Resetting iPod (with out dock connector)
If that doesn't work, your iPod may need to be reset.While the iPod
is connected to power, press and hold the Play and Menu buttons
for at least 5 seconds, until the Apple logo appears.
Mar 03, 2011 | Apple iPod classic MP3 Player
My ipod screen went black while it was playing.
When this happened to my ipod, I followed these instructions on the apple web site and it did the trick. The problem happens periodically.
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
Here's the site if you're using a different model ipod:
http://support.apple.com/kb/ht1320
Feb 28, 2011 | Audio Players & Recorders
I want to reset my ipod because it is not responding
alandtonipea:
From the Apple support web site article HT1320 (click here):
2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Thanks for using FixYa
Feb 16, 2011 | Apple iPod MA446LL/A MP3 Player
I plug my i pod touch 3rg gen. intothe computer and it stays connected for about 15 seconds then disconnects... its not the cord i used multiple... and it charges fine on a wall charger... help!!??!!
try resetting ipod.
To reset your iPod:
· 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
· 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
· If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
· If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Jan 01, 2011 | Computers & Internet
My iPod Nano Died And I Just Bought A New USB Cord And It Wont Charge Or Turn On...It'll Just Show A Little Apple For 2 Seconds Then Go Back To A Black Screen...How Can I Fix This.!?
Welcome to Fixya
Looks like the software just hanged-up on you. Try to reset the Ipod by following the procedures below.
1st option:
Turn the Hold switch on, then back to off.
Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
2nd option (Disk Mode):
Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Note: Do not disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Cheers!
Nov 05, 2010 | Apple iPod nano
I am reformatting my 20gb ipod now it says to plug it to a wall outlet but doesn't do anything. what do I do now? itunes doesn't see it either
I'm not sure which version you have, but most iPods will respond once they have been reset. Follow this link to the Apple site with instructions for resetting your particular iPod. Good luck!
http://support.apple.com/kb/HT1320
Feb 18, 2010 | Apple 20gb Ipod Mp3 Player With Click...
Ipod show plug in
This is the result of a firmware update.
You need to plug it into an Apple wall charger rather than a generic USB charger in order to complete the firmware update.
If you have used an Apple charger already then take your iPod to an Apple store as they can remedy this.
Mar 05, 2008 | Apple iPod MP3 Player
Ipod only shows outlet
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod.five_rs/
If you need more assistance let me know. Good luck.
Feb 23, 2008 | Apple iPod 4th Generation MP3 Player
You could try resetting the ipod. On my ipod photo, you have to turn the hold switch on then off, then hold down the Menu and select buttons for 10 sec's. It takes a few tries :>.
Check out:
http://docs.info.apple.com/article.html?artnum=61705
When turning on my iPod keeps saying to go to the Apple web site for support
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
Nov 26, 2007 | Apple iPod MA446LL/A MP3 Player
Apple 20gb Ipod Mp3 Player With Click Wheel System Logo
151 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
