Question about Bose 901 VI Main / Stereo Speaker
Using two equalizers on one system
Hello, i have a nad 372 with monitor in an out 1 & 2. I can cannect both equalizers to it. When i press buttons for both monitors on the front, both lite up, but when i click the cd source button, monitor 2 button goes off. Is it possible to use two equalizers? is it worth using two equalizers? and does the one equalizer work for both A & B channels? If not, how can i get it to work?
Thx
    Problem Solver:
  • 18 Answers
You need only 1 equalizer.
please go thru this manual carefully
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
Posted on May 27, 2008
How to connect it to NAD C-372
Download manual from the Web.
Follow instructions.
Enjoy.
Jan 12, 2016 | Bose 901 Series VI Direct/Reflecting...
Using two equalizers on two sets of Bose 901's
As I have figured from your question you are trying to independently control levels for two sets of Bose speakers attached to your NAD amplifier. The problem lies in that the amplifier can only read one signal at a time, so in theory it will only accept a signal from one equalizer and output it to speakers attached to A and/or B terminals. In order to process different eq settings to two seperate pairs of speakers you will need to use two amplifiers, or an amplifier with built in channel controls for speaker set A and speaker set B.
Feb 21, 2008 | Bose 901 VI Main / Stereo Speaker
The balance pot of my NAD C370 is not working, will the amp still work if I remove the balance pot?
Only if you replace the pot with two resistors of equal value. Both need to be also equal to 1/2 the value of the pot. Then at the point the 2 res tie together -- Tie that point to the middle lead location and the other leads to the other points where the pot was connected. Use 1/2 watt or 1 watt res.
Nov 02, 2010 | NAD C370 2-Channel Amplifier
How do you connect a nad c270 amp to the bose 901 series vi equlizer and system/
Bear in mind that 901's require exclusive use of any amplifier they use. You shouldn't expect to use conventional speakers alongside them on the same amp. The reason is that the 901's require the use of their dedicated Active Equalizer to shape the frequency spectrun to match their drivers' response curves, resulting in a flat sound output. Applying that kind of equalization to any conventional speakers will sound to sharp at the extremes and may even potentially damage them.
For connection I would run a pair of RCA cables from the L&R Audio Line OUT of whatever preamp or source you're using to the Active EQ's Line IN; then the EQ's Line OUT to a NAD amp's Line IN. DEselect any Tape options on the Active EQ, attach the 901's to the new amp, set the NAD volume controls pretty high (and leave them alone), run through any level setup procedures in your control electronics for volume, etc and you're done.
Aug 17, 2010 | NAD C270 2-Channel Amplifier
How do i connect my fisher equalizer to the amp model # CA-871
I assume this amp does not have separate amp and preamp.
(I cannot get the service manual for free...)
Connect the equalizer input to Tape OUT on the amp. Connect the Equalizer output to Tape IN on the amp. (Match up lefts and rights, eh?)
Now, when you press in the tape monitor button, whatever you have playing runs through the equalizer. Tape monitor button out, you hear the sound without the equalizer.
Mar 29, 2010 | Audio Players & Recorders
Excess clipping on nad 372 amp
อิอิ ขอบคุณคับ
May 24, 2009 | NAD C272 Amplifier
Hello how to adjust brightness on an ACER 19" LCD monitor? thank you Kurt
1. Press the MENU key.
2. Press the < or > key to select the BRIGHTNESS icon from the menu (looks like a little sun).
3. Press the MENU button again to enter the BRIGHTNESS menu.
4. Use < or > to select appropriate brightness.
5. Press MENU button to exit.
5. To exit - select the EXIT function from the menu and press MENU button again.
Apr 01, 2009 | Acer X193W LCD Monitor
Nad c372 prob
The unit is detecting a problem and shutting down in what is usually called "protect" mode. Look for bad connections on the board near the voltage regulators.
Dan
Sep 05, 2008 | NAD C372 Amplifier
Connecting the 901 series VI equalizer
hello
please make sure your receiver has a tape monitor switch on the front panel or pre-in/out sockets at the rear. only then all sources will play thru the bose equalizer. also remember if you need a 5.1 or greater setup, you will need 2 amps/receivers.
hope this helps
May 27, 2008 | Bose 901 VI Main / Stereo Speaker
NAD T770 (T2 Monitor button)
the best solution for this problem is to throw it away and never buy nad again. its junk.
Apr 21, 2008 | NAD T770 Receiver
Bose 901 VI Main / Stereo Speaker Logo
245 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
