Question about Car Audio & Video
I have a 'BOSS' car amplifier and i dont know how to tell how old it is or how many watts or anything. How do I find out info on it
  • Stephen Sedwick May 11, 2010
    if you can find tha serial num or modle num go onto google and just type one of those in and that should ancer all your questions
  • djdjuanfix1 May 11, 2010
    What is the model Number?
  • 524 Answers
This amp does have a code or sereal number somewhere on it. If it does google it if it doesnt then there is really no way to tell its true power output unless you know how to run a mulitmeter
Posted on Mar 22, 2010
I have 2 boss 2400 watt 15 how much watts do it push out for real 2000 or 1500
These units have a peak power rating of 2400 watts however they only have an rms or nominal rating of 1200 watts each. if this helped please help me by marking this as the answer, cheers
Feb 04, 2015 | Boss Car Audio & Video
Will a Pyle PT530A 350watt receiver work with a pair of 4ohm 200wattRMS per speaker
Yes they will, but alway be careful with audio gear.
There are 30 watt speakers that can handle peaks of 500 watts for a short time. There are also 500 watt speakers I can "kill" with a peak less than 500 watt.
Most amplifier manufactures like to boost about the power an amplifier can deliver and their speakers can handle. But as long as they don't tell how long the speaker can handle the power and at what frequencies the value does not say anything.
Whit high power amplifiers, never switch over while the volume if at maximum.
You know what I mean. I can't hear my CD player. first turn the volume to the max and then press the CD button, and the speakers will explode. Always when you preaa any button on the pre amp juts lower de volume first and you won't destroy your speakers.
My old Kef Concerto's are almost 40 years of age. 30 watt and are running on a 500 watt Yamaha amplifier for years now. And believe me my chidden know how to punish a speaker. Never any problem, nr with the speakers, nor with the amplifiers.
Jul 28, 2014 | Car Audio & Video
Whats d power supply rating for boss chaos amplifier
400 watts RMS
is what the ratings on that iss you can also check the website at www.boss.com but you should be looking at 400watt RMS if I am not mistaken.
thanks and please do rate your free information request and leave feedback.
Apr 28, 2010 | Boss CHAOS CH450 Car Audio Amplifier
I have 2 perfomance teknique 700wts and i dont know what kind of amplifier use
Hello perezmagdiel,
That 700 watts is maximum peak power, not RMS. If you're looking to not spend a lot of money for an amp, but want something that sends enough power to the Performance Teknique's, I'd recommend a 2-channel like the Boss Diablo D400.2. It's plently powerful enough and if you change out later, the amp can be bridged. And for inexpensive, it's got a lot of nice features, including a remote level control. It's 2ohm stable in stereo. Nice, for under $70.
Hope this helps.
Jul 17, 2009 | Performance Teknique ICBM-892 Car Audio...
Why would i spend a 100 to 120 dollars on a car amp?
any amp will work with any speaker, you just need to make sure it is a mono amp if you are running 1 speaker and a stereo amp wither 2 or 4 channel if you are running 2 or 4 speakers, the ohm rating on the amp should match the speakers also, on the back of the speaker it has the ohm rating, most will be 8 ohm, but you still find some 4 ohm, depending on the speaker if it has a lot of throw (the in and out movement) you may want a higher wattage amp so you get clean sound, it is up to you.... if you are installing lower price amps to you may hear engine wine or noise while car is running so a grounde loop isolator installed on the system will remedy that... also with the amp the directions will tell you the ohm rating of the wire to use, follow that.... and keep the ground short and clean where ever you put it.. try not to go directly off the battery cause you will get a lot of noise... hope this helps..
Jun 23, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
Boss chaos 150 200 watt that shows light but doesn't produce sound
DID YOU CONNECT THE JACKS FROM THE HEAD UNIT? JUST A THOUGHT AS THIS IS EASY TO OVER LOOK
May 27, 2009 | Boss C150 Car Audio Amplifier
Blown amp, on circuit board, connecting fuse and power connect.
These amplifiers dont employ reverse polarity protection that most higher priced ones do.
The amplifier(s) are definately in need of repair - probably power supply - IF boss sells parts.
Chances are, however, the repair will meet or exceed the cost of a new (appropriately rated) entry level amplifier.
Just about anything can be repaired.... question is, are you willing to pay?
Jan 14, 2009 | Kenwood KAC-X501F Car Audio Amplifier
If this is the CH150, it's not bridgeable. Try connecting it normally (one speaker per channel) to see if it will produce output.
Dec 05, 2007 | Boss C150 Car Audio Amplifier
Car Audio & Video Logo
102 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
