Question about Refrigerators
The fridge is leaking underneath. The drip tray is dry.
  • 572 Answers
Ur drain is probably clogged
Posted on Feb 07, 2010
I have a Kenmore SR1087 fridge. Water is dripping into the drain hole at the bottom of the freezer. I do not see a tray underneath. Not leaking on the floor. Is that normal, where is the water going?
The defrost water should pass through the tube into a flimsy plastic tray that is heated underneath to speed evaporation. The tray may be hard to see because of hardware around the perimeter.
Aug 24, 2016 | Kenmore Refrigerators
Igloo mini fridges
The question is: Are you seeing water inside the fridge where it shouldn't be? Are there water stains in the try? Some of these have no tube, the water just drips from a small hole above the tray.
Jan 05, 2018 | Igloo FR834A Stainless Steel 3.2 Cu Ft...
I have the Kenmore top-mount 106.76232402 leaking
hi.turn water supply to fridge first.cont drip might be a faulty valve.hope this helps.Ali
Jun 26, 2012 | Kenmore Refrigerators
It's leaking water from underneath the unit
Hi there, I know that most units have a drip tray at the back or under the unit itself. well the older ones anyway, not sure with really new ones, but they shoukd. these trays hod water condensation and any drainage from the fridge itself. These trays sometimes have a coil in them which heats and help to evaporate the waterso that it does not overfill and spill out. these trays can become overfilled, the heating elemet can stopworking or
Jun 01, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Condensation is forming on the glass door and dripping onto floor boards. How do we stop the condensation. It does say to empty drain tray but we cannot find it and instruction manual does not tell you...
The drain tray is under the fridge often times set back a little bit. Remove the kick plate by pulling from one side then the other side, strait forward till it pops off. The kick plate is a plate as close to the floor as you can get on the front side of the fridge going the entire width of the bottom of the fridge. Now get eye level with the underneath of the fridge. Center your view on the underneath of the fridge. The drain tray is right there. Pull it out, carefully as it is probably full of water, and dump the water out of it. Replace the drain tray and then replace the kick plate. Check the drain pan once a week or so and you should have no more water leaking on your floor. Hope this helps.
Mar 22, 2011 | Refrigerators
Ive had my westinghouse moist cold 421 for quite a few years and lately there has been at times water leaking at the inside under the vegetable cripsers . I'm unable to find my user manual but I recall...
The drip tray is all the way at the bottom.Pull of the grill at the bottom of the refrig,tray should be there.
Also there is a hole or tube under your crispers,check that its clear and not clogged with junk.
Jan 20, 2010 | Westinghouse Refrigerators
Icemaker leaks into freezer compartment
MDG,
Sometimes the drainage inlet for the defrost can get clogged and then the frost has no place to go (usually an evaporator pan at the base of the fridge) have you ever felt the side walls or within the fridge and it was warm? When it is working the tray heats to rid the fridge of the frost. The DYI solution is simple but can be frustrating. If the freezer is on top and you can remove the drip tray and the contents for that matter and see the inlet all the way in the back most likely covered in ice, turn of the fridge throw a bunch of towels togeter with sponges and buckets and le the fridge thaw out for the day sopping out all of the water. If you can get to the inlet squirk some hot water with a turkey baster down into the hole and listen for the flow out into the bottom into the tray. Take the back off of the fridge (or access panel at the botom) to see the evap tray. If it is totally dry and looks like it has been for a while then it hasn't been draining. Usually unless a waterline is leaking or broken ice formation is a faulty defrost, huge amounts of continuous water is a leaking suply line. The frustraing part of the DYI solution is if you don't get the blockage free from the line (usually a clear tubing that emties into the evaoprator tray) and put everything back together and restock the fridge about a week later it will start icing up again.
randy32sgi
Feb 11, 2009 | GE Refrigerators
Refrigerator has water leak
Had the same problem with mine. Got a technician to have a look. Inside the fridge at the back there's an overflow tray. CHeck if this is not blocked. Clear it by putting a tray behind your fridge under the overlfow pipe and pour hot water through the overflow tray inside the fridge. Sometimes food gets stuck in there and nobody thinks to clear this out. Mine was easily unblocked and now its stopped leaking.
Apr 14, 2008 | Refrigerators
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
