Question about Motorola Mobility RAZR V3
Just doesn't connect to my computer - Motorola Mobility RAZR V3
Computer doesn't recognize camera
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Dec 18, 2012 | Nikon D3000 Digital Camera
How do I connect this keyboard to the computer
Keyboards connect several ways. Older systems use a PS/2 connector (round) that plugs into the purple/gray jack on the back of the computer. The mouse plugs into the green jack next to it.
If you have a USB keyboard, it plugs into any USB slot.
PS/2 connections must be made with the computer off. USB connections work any time. If one slot doesn't work, try another.
If the keyboard doesn't work, try another.
Nov 17, 2011 | Unitech K2724U-B Keyboard PC Desktop
Panasonic hdtv 1080i CT-36HX41E..Can you hook up a PC to the tv for the monitor?
You can connect this to your computer if you have an S-Video output on your computer. This is the only supported connection on your TV. This model doesn't have a VGA, DVI, or HDMI port.
Hope that helps!
Jul 19, 2011 | Panasonic CT-32HX40 32" TV
I accidentally plugged the router out and now my Internet connection doesn't work. The local network connection is displayed as working and responding nevertheless. The second and fourth (starting...
Power down your router and computer. Wait 15 seconds, then turn on the router first, then the computer. If this doesn't work, you can also try rebooting the modem as well. You will then need to power all three down, then start with the modem and wait a minute as it boots up and runs its auto-tests, then the router, then the computer.
Jun 20, 2011 | D-Link DIR-300 Wireless Router
I install the software but I am unable to download photos and videos...I follow instructions but I can't and I don't know why. I connect the camera after I've installed the software and...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 21, 2011 | Fuji Finepix Z20fd Digital Camera
Lap top fires up and then just sticks on the Acer logo, Any ideas ?
Hi there!
Is there any USB device connected to the laptop like printer, USB memory stick, scanner, etc? If there is, I suggest you remove it before starting the computer.
If there's nothing connected to the computer then it is a possible hardware problem. If you know how to open the computer, I suggest to remove the memory and place it back. if that doesn't work, it might be another hardware causing the problem. Call ACER so they can help diagnose the problem. If the computer doesn't warranty from ACER, I suggest to bring it to a qualified technician.
Hope this helps.
May 21, 2011 | Office Equipment & Supplies
My computer will not open up futura. it says connection error. everything is connected?
Make sure you have the USB cable plugged into the BACK of your computer, not the front or a USB hub. If it's a laptop, keep trying different ports. The USB for this machine needs more power than the other ports offer (12 V), something Singer doesn't tell you, and probably doesn't even now.
Best of luck!
Apr 22, 2011 | Singer CE-100 Futura Computerized Sewing...
When I connect my headhphone to monitor doesn`t work?
If you mean the pale green jack on the back of the monitor, it is not a headphone jack. It is to let you connect the sound output from your computer (usually also a green jack) to a little speaker in the monitor. That speaker is better than nothing, but sound quality is poor.
Jul 30, 2010 | Sharp LL 172A-B 17" LCD Monitor
When i connect thru a USB my motorola v235 it doesn`t show it as connected and i can`t access it, i downloaded the drivers but it showes an installation page and doesn`t recognize the phone. what can i do...
Does your phone require software to be installed on your computer first?
My LG requires software from LG before it would recognize or manipulate the phone. Perhaps your phone is similar.
Thanks for your interest in FixYa.com
Jan 14, 2010 | Cell Phones
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
