Well, any type of streaming video will need a good amount of bandwith to transfer without interuption. If you were, for instance, plugged directly into a cable or DSL modem and it worked fine, and now youve set up a wireless router and moved your computer across the house... it's possibl;e your computer is not getting a good connection. If multiple computers share the same connection through this router then they are all sharing the limited bandwith you get from your ISP. Try (if possible) moving the router (and or cable/dsl modem) closer to your PC and make sure other aren't online when you are.
No. First check if messenger voice port is blocked or open on your network. Try using VPN or socks, if you are not getting voice still please let us know.
I myself is a big time user of yahoo messenger and a regular chatter of 2
chat rooms and using yahoo from past 7 years.
This is true that he/she can change your account information and even
can hack it !! its quite a regular thing these days because of loop
holes in yahoo account security.
DON'T EVER USE YOUR MAIN ID (THE ID IN WHICH YOU ADD FRIENDS )
Booters (who can disconnect you from messenger wither by hanging your
yahoo messenger or by making you forcefully signout from messenger) and
hackers are there on yahoo.
I got solution/s for this problem:-
1-use ysupra chat client.Its freely downloadable..you can search on google to download it freely,it provides a lot of security to out accounts while we use our id in chat rooms.This is the best chat client till date.
2-Make ids with numbers,like my id is eric_the_hunk27...i have made other ids with numbers like eric_the_hunk22..21...25..26. AND DONT ADD ANYONE ON THESE IDS.MAKE THESE IDS JUST FOR CHAT ROOMS.This helps a lot ,first people in chat room will recognise you.On ysupra..almost 99% of the booters can't boot you,its very safe.
2-while using ysupra,you can simultaneously sign -in in your yahoo messenger too,use yahoo messenger to sin\gn in with your main id (the id in which you add friends and want to be safe and secure from any kind of attack),don't use your main ID in chat room ever.
3- incase you want to add soneone in chat room to your main id,then you just have to send add request from your main id to that person..that's easy..just type the id of that person to whom you want to add in "type id here" in your yahoo messenger and then press enter,then add the person.
IN THIS WAY,YOU WILL BE VERY VERY SECURE...
ALMOST 99% OF THE HACKERS ON YAHOO HACK THE ACCOUNTS WHEN THE PERSON TO WHOME THEY WANT TO HACK IS IN CHAT ROOM.ITSD BECAUSE THEY CAN TRACE YOUR IP ADDRESS IN CHAT ROOM.
SO,IF YOU DON'T TAKE YOUR MAIN ID IN CHAT ROOM..THEY WONT BE ABLE TO HACK YOUR ID...
AND IF THEY HACK THE CHAT ROOM ID THAN ITS NOT AN ISSUE BECAUSE YOU WONT BE HAVING FRIENDS IN THOSE IDS..AND YOU WOULD BE USING THOSE IDS JUST FOR CHAT ROOMS...
YOU CAN MAKE AT MAX 6 IDS FROM YAHOO MESSENGER IN 24 HOURS TIME...I GUESS THIS IS MORE THAN SUFFICIENT...LOL
the issue as to do with connection of the chat room, try another chat room like tagged and all other network that has chat room to know if it is the connection
type
/help in main chat window
you will get the list of available command
/follow space userid
it will take you to that room
I don't know wether yahoo has changed this or not but it worked till 2 months back
