Question about RCA RCU811 LCD Remote Control
Hi i use this remote to program my toshiba tv,it work for while ,it stop working.could you me what happen with this remote. thank you.
    Brigadier General:
  • 4,090 Answers
That is like asking How long is a piece of string!
The batteries are flat
It's got an internal fault
It loses its code
contacts are corroded
and 1000 other faults that may cause it to stop.
The common onbe is faulty batteries and dirty contacts where batteries connect
Best we can do for you
Please rate my help++++Thanks for using FIXYA
Posted on Feb 07, 2010
2 Suggested Answers
SOURCE: need code to program toshiba tv with Direct tv remote
I HAVE A TOSHIBA 32A33 TV AND JUST UPGRADED MY RECEIVERS AND REMOTES I CANNOT GET THE DIRECT TV UNIVERSAL REMOTE RC64 CODES THAT THEY HAVE PROVIDED TO WORK, ANY ADDITIONAL CODES ? PLEASE HELP
Posted on Dec 06, 2008
I have an old remote that works for a VCR and I did have it working for the TV but one day someone was playing with buttons and it stopped working. I was wondering how to program my Toshiba vc 260 remote...
Try the following procedure:
1. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
Feb 28, 2011 | Toshiba Vc-260 Remote Control
I can't program my remote. My tv is a toshiba. I
There is only one code for Toshiba programmed into the URC4110 remote: 0000
If this code doesn't work or you have a different One-for-All remote, please post back and I will try to find another code or get the correct codes for your actual remote:
Regards,
BElectric
Dec 01, 2010 | One For All URC4110 Remote Control
I have a toshiba universal remote model ct-90121. I need the program codes and programing instructions for an rca tv
According to Toshiba, the CT-90121 isn't a universal remote control. This remote only works with TOSHIBA TVs with the following model numbers:
32AFX62, 32AFX63, 32HFX72, 34HDX82, 36AFX62, 36AFX63, 36FX72, 36HFX72, 42HDX52, 42HDX82, 50HX70, 57HDX82, 57HL83, 57HLX82, 65HDX82, 65HLX83
Unless you posted the wrong remote model number (?) your Toshiba remote isn't going to work with your RCA TV.
Please rate this solution if you find it helpful. Thanks!
Nov 02, 2010 | Toshiba Televison & Video
I need to program an RCA universal remote for a Toshiba TV
Ideally I need the exact model number of the RCA remote you are using as these remotes use different 3 or 4 digit codes.
However I have listed the common codes RCA use for Toshiba. You will need to go through them, one by one, until you hit on the one that works for your particular Toshiba TV.
If for some reason these codes do not work - please post up the exact model number of the RCA remote and I will look at it again for you.
1) Common 4 digit codes for Toshiba
1000, 1048, 1072, 1105, 1109, 1118, 1160, 1190, 1241.
2) Common 3 digit codes for Toshiba
000, 048, 049, 071, 072, 073, 105, 109, 117, 118, 160, 161, 162, 190, 201, 207, 283.
Hope this helps. If so a rating is appreciated.
Otherwise please post additional information as requested.
Thanks for using FixYa.
Jan 08, 2010 | RCA Universal Remote Control
My sky remote wont control the volume on my tv
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
Ok - not proper solution yet but nearly there!
Dec 19, 2008 | Televison & Video
The Cap/Text button works but it makes no difference on my tv
Try new batteries in the remote and confirm that the settings are correct and that you haven't accidently selected no caption option.
Sep 04, 2017 | Toshiba CT-90157 Remote Control
Toshiba TV Remote Control not working
Hi
can you give to me your exact problem?
Thanks!
Sep 22, 2008 | Toshiba 30HF85 30" TV
Can't find code for my RCR312W to work on my Toshiba TV. I tried all different codes. Any suggestions?
Have you tried these codes?
Code 1000 for Toshiba TV Code 1048 for Toshiba TV Code 1072 for Toshiba TV Code 1105 for Toshiba TV Code 1109 for Toshiba TV Code 1118 for Toshiba TV Code 1160 for Toshiba TV Code 1190 for Toshiba TV Code 1241 for Toshiba TV
Sep 10, 2008 | RCA Universal Remote Control
CT9946
The Toshiba codes I have for that remote are
0156 0060 0154 0035
0060 0508 0036 0070
0102 1508 0217 0109
0490 0718 0195 0191
Apr 29, 2008 | Televison & Video
Need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Oct 01, 2007 | One For All URC-3021 Remote Control
RCA RCU811 LCD Remote Control Logo
47 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
