Question about Denon AVR-4308CI Receiver
Gui does not come up on screen - Denon AVR-4308CI Receiver
    Problem Solver:
  • 12 Answers
Possible causes & solutions, in order of simplicity:
1. Wrong input selected on TV - Reconfirm you have selected the input corresponding to the receiver's MON. OUT connection, e.g., component video, S-video.
2. Wrong output set on receiver - Reconfirm you haven't previously selected an output on the receiver that is unavailable on your TV, e.g., on some receivers, HDMI cannot be used for on-screen display. The front panel may show the setting as a backup for no on-screen display. If not, you may have to reset the receiver to factory defaults -- find out how to do this in the manual.
3. For component video or HDMI only -- Output signal from receiver may be set to a mode that the TV cannot process, e.g. 720p for a TV with only 480i/480p/1080i capability.
4. If the receiver is a high-end model with "Pure Direct" or similar settings that have been selected, the video circuitry and possibly also the OSD may be unavailable. Try switching to a normal setting or another input.
By the way, the usual term for the menus from an AV receiver is "on-screen display (OSD)" -- not "GUI (graphical user interface)," which is more appropriate for computers or cell phones.
Posted on Feb 14, 2010
Radio tuning
PIONEER VSX-D903S - A/V Receiver
PIONEER CU-VSX079 - Remote
Here's the basics: Make sure your receiver is in the Tuner mode, by selecting Tuner on either the remote (grey button), on the receiver, or from the GUI menu. (The display will also show TUNER.) There are a couple of different ways to tune a station. One method is with the remote. Use the Band button on the remote (or via the GUI display), or the FM/AM button on the receiver, to select the frequency type. Use the Freq/Ch buttons on the remote to tune, the number buttons for presets (30 presets total. Examples: Preset 5, simply press 5; Preset 15, enter 5-5; Preset 25, enter 5-5-5). You can also use the on-screen GUI menu and the remote to tune stations, using the lower grey buttons. If you want to tune directly, via the receiver, press Select, to switch between frequency tuning and presets (displays ST CALL) mode. Use the Multi-Jog dial to make your selection in either mode. The easiest way to program a station into a preset is to use the onscreen GUI menu. [NOTE: The GUI mode (TV Monitor Video Out, composite video) is active when an amber (orange) ring glows around the Multi-Jog dial (the GUI button on the receiver will also glow simultaneously). Use the remote lower grey buttons, or use the Multi-Jog dial and Select, to move the cursor and select commands on the TV. This A/V Receiver handles composite video/S-video, and Stereo/Dolby 3-Channel/Dolby Pro-Logic audio only. (Pre-ATSC/HD video, Pre-Dolby Digital/DTS multi-channel surround audio)]
Feb 07, 2014 | Pioneer VSX-D903S Receiver
Samsung printer CLX-4195FW Power on then: [7]
The problem is caused by the GUI OPE Controller.
Part code JC92-02505A.
After replacing, and reassembling, you need to switch the printer on, while holding down the "0" key. This puts the printer into calibration mode for the LCD touch display. Go through the sequence on the screen and then restart the printer. If you do not got through the calibration, the touch screen will not work ?
If your in Australia, you can purchase from here:
PBA GUI OPE CLX 6260FW SEC OPE SUB
Oct 22, 2013 | Samsung Clx Series 635753716764 Clx-4195fw...
Pioneer VSX D903S ...HOW do i adjust the rear speaker volume....it is currently much too low
You make surround channel adjustments using the on-screen GUI interface. This can be done either by using the remote (recommended), or by using the appropriate controls on the receiver. [The GUI mode is active when the GUI button and the ring surrounding the Multi-Jog dial is glowing amber.]
Nov 07, 2011 | Pioneer VSX-D903S Receiver
How to change to upnp
First, access the GUI of your router. Open browser and type 192.168.1.1, type admin for username and password or if you had change it before, use that username and password that you had set up. Once you see the Linksys GUI page, click on Administration on the upper right corner of the screen and click on management, from there you can edit the UPNP settings.
Sep 03, 2011 | Linksys Wireless-G WRT54G Router
Blank screen on startup
If the laptop runs OK apart from that, I suspect the GUI has been switched off. Switching off the GUI will speed up the boot process but nothing else.
Click start and type msconfig in the search window. Browse the menu and check the GUI box.
Re start your laptop and the start screen will re appear.
Dec 23, 2010 | Acer Aspire One PC Notebook
Hi i get no service on my iphone
Have you tried to unlock the iPhone? This is a common problem if the iPhone is jailbroken or unlocked.
Kindly try the steps below:
* Go to Settings:General:Reset.
* Click Reset Network Settings
* Enter your passcode if you have created one.
* Click the red button: Reset Network Settings
* The iPhone will take a minute to shut down, then it will reboot.
- If these steps will not work, then follow the steps below:
1. Start with iphone with no service (jailbroken and unlocked)
2. Use iBrickr to load Launchctl GUI (Application -> Browse Application -> Launchctl GUI)
3. Open Launchctl GUI, look for the CommCenter line. If it is red - go to step 5. If it is black - proceed to the next step.
4. Select the CommCenter line, you will see a list of 3 options, select the unload -w, and press ok to confirm, the CommCenter should now be red in the list.
5. Fully restart your iPhone.
6. Open Launchctl GUI, look for the CommCenter line. It should be red if you did the above steps correctly.
7. Select the CommCenter line, you will see a list of 3 options, select the load -w, and press ok to confirm, the CommCenter should now be black in the list.
8. Press the home button. Your phone should now display 'searching' then display your network with full signal.
NOTE: Once your iPhone is working fine, open iBrickr again, go to applications, and delete the Launchctl GUI from your phone by clicking the red (-)minus buttons on the right of the screen.
Thank you and good luck!
Jun 13, 2010 | Apple iPhone 3G
White Screen - Unable to See Desktop GUI.
Two separate problems, sounded like..
White screen? If external video is okay then it's likely (1) a bad screen, or (2) a disconnected video cable.
If the system shuts down, I'd check the fan - if the fan is reasonably clean and running, then it's probably a bad motherboard.
Mar 15, 2010 | Toshiba Satellite 1805-S274 Notebook
NO GUI displayed
I had a similar problem with my Denon 3808 after it had the protection circuit tripped. First all I would get is a blue screen with sound, then after powering the unit off I got the display back, but all of the on screen GUI menus were gone. I could tell that the menu button worked because display located physically on the recever worked. I reset/rebooted the system (follow the directions in manual) and everything came back. Be aware by resetting the system any customization you have done will be lost. Hope that helps
May 30, 2009 | Denon AVR 3808Ci Receiver
On screen display does not appear
Same problem, thanks for the solution -- resetting power solved it.
Mar 02, 2008 | Denon AVR-4308CI Receiver
Denon AVR-4308CI Receiver Logo
493 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
