Question about Kenmore 62882 Electric Dryer
Need diagram for replacing 3 plug to a 4 plug
  • 5,911 Answers
The following link explains how to convert from a 3 prong appliance cord to a 4 prong:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have questions, please post back and let me know. I hope this helps you.
Posted on Feb 07, 2010
I need wiring diagram for the spark plugs on a 2001 ford Windstar V-6;3.8L
1-4-2-5-3-6
Cylinder numbering:
  • Windshield side
    1--2--3
    4--5--6
    Frt. Of vehicle
Coil numbering:
    • --4 PIN--
      --1--- 2--- 3--
      --5--- 6--- 4--
Feb 12, 2015 | 2001 Ford Windstar
Spark plug wiring diagram for 05 tahoe
Greg Bernett 2821 Solutions February 14, 2010
You didn't post your engine size so please pick the applicable diagram:
1996-98 4.3L Engines Firing Order: 1-6-5-4-3-2Distributor Rotation: Clockwise
1996-98 5.0L, 5.7L and 7.4L Engines Firing Order: 1-8-4-3-6-5-7-2Distributor Rotation: Clockwise
4.3L Engines Firing order: 1-6-5-4-3-2 Distributor rotation: Clockwise
4.8L, 5.3L and 6.0L Engines Firing order: 1-8-7-2-6-5-4-3 Distributorless ignition system (one coil on each cylinder)
5.0L, 5.7L and 7.4L Engines Firing order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
Source: spark plug wiring diagram for 98 tahoe
    ledsled378 2926 Solutions July 24, 2010
01f93b7.jpg ..............................
Source: Need diagram for spark plug wiring for 1997 Chevy
Testimonial: "Thank you for your prompt response. Saved my husband from some distress!"
Was this solution helpful? Yes No
    Dennis Weid. 44272 Solutions September 16, 2008
This was all I could come with, hope it helps.
Feb 27, 2013 | 1998 Chevrolet Tahoe
1999 ford escort I changed the plugs, but broke a plug cap. Bought a generic replacement spark plug wire that had to be modified to fit into the head. I cannot get the firing order correct. The car...
Remove the plugs from the head. Insert into the coil wires. Make sure they are properly earthed on the engine. Crank the motor and check for spark at each of the plugs.
Refer to the diagram. Cylinders are connected as shown on the diagram in blue. 1 goes to cylinder 1(sparkplug furthest from coil pack), 2 to 2, 3 to 3 and 4 to 4(closets to coil pack).
To test the coil pack use a digital volt meter. Measure resistance between coil towers for coil 1(marked 1 in red on diagram) Value should be between 12000 and 14500 ohm. Do the same for coil towers 2.
Measure resistance between I and C1. If the measurement is more than 5 ohm the coil is defective. Do the same for I to C2.
Measuring voltage at I(Ignition start/run) to ground should be 10V.
I is connected to the 15A engine fuse. The radio interference capacitor is connected between this line and earth at the coil. Disconnect it to see if it cures the problem.
C1 and C2 connect to the powertrain control module.
Bear in mind that aftermarket coil wires may cause problems with misfiring, so see if you cant find an OEM coil wire to replace the broken one before replacing anything else.
Nov 15, 2010 | 1989 Ford Escort
Firing order diagram for ford f150 I need to see
FIRING ORDERS NOTE: To avoid confusion, replace spark plug wires one at a time. Fig. 1: 5.8L engine Firing order: 1-3-7-2-6-5-4-8 Distributor rotation: Counterclockwise 88282g01.gif
Fig. 2: 4.9L engineFiring order: 1-5-3-6-2-4Distributor rotation: Clockwise 88282g02.gif
Fig. 3: 5.0L and 7.5L enginesFiring order: 1-5-4-2-6-3-7-8Distributor rotation: Counterclockwise 88282g03.gif
Fig. 4: 6.9L and 7.3L Diesel enginesInjection order: 1-2-7-3-4-5-6-8 88282g04.gif
Sep 09, 2010 | 1994 Ford F150 Styleside Supercab
I just need a diagram of spark plug replacement in 1997 Hyundai sonata 2.0 liter engine automatic.
For the 1997 Hyundai Sonata 2.0L DOHC In-Line 4-Cylinder:
Firing Order:
1 - 3 - 4 - 2
Cylinders:
..........(back)..........
|...4....3....2....1...|
.........(front)
Coil Connections:
(back)
|..1..|
|..4..|
|..3..|
|..2..|
(front)
Let me know if this helped and THANKS for using FixYa.com!
Aug 04, 2010 | Hyundai Sonata Cars & Trucks
2002 ford f150 4.2l wiring diagram
The COIL PACK TOWERS are numbered : coil----3---4 pack---2---6 plug----1---5 ----------------------------------------------------------------- The engine cylinders / spark plugs are numbered : passenger side , front to rear , 1 , 2 , 3 -----drivers side , front to rear , 4 , 5 , 6 ------------------------------------------------------------------- The spark plug firing order is ( 1 -4 - 2 - 5 - 3 - 6 )
Apr 07, 2010 | 2004 Ford F150
Missing after replacing spark plugs
What size engine? Check the gap on the plugs as well. "pregapped" is not always right
Feb 18, 2010 | 1991 Oldsmobile Cutlass Ciera
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
I need a plug wire diagram for a 1995 Pontiac
Looking on your engine:
(Coil packs)
5-2 3-6 4-1
(Cylinders)
1 3 5
2 4 6
Your firing order (although irrelevant):
1-2-3-4-5-6
Sep 14, 2009 | 1995 Pontiac Grand Am
Got spark plug wires crossed,need diagram
Hope this helps, couldn't find diagram.
Firing order 1-8-4-3-6-5-7-2 --------------- | 2 4 6 8 | | | front | ----- | | | 8 || | | 1 4 || of | |2 3|| | | 7 6 || | | 5 || vehicle | ----- | | | | 1 3 5 7 | --------------- Distributor rotates clockwise
Dec 20, 2008 | 1996 Jeep Grand Cherokee
Kenmore 62882 Electric Dryer Logo
88 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
