Question about HP Photosmart C6180 All-In-One InkJet Printer
HPC6150 YELLOW CARTRIDGE SHOWS EMPTY AND WILL NOT PRINT IN COLOR
I REPLACED CARTRDGE YELLOW AND STILL DOES THE SAME PROBLEM SHOWING EMPTY WHEN IT IS FULL. ALL FOUR CONTACTS ARE BEING MADE WITH THE CARTRIDGE. WHAT WOULD CAUSE THIS PROBLEM.
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
Red ink prints as yellow, and green color is very faint. Ho wdo I clean the cartridge?
probably a problem with the cartridges ( empty)
replace with new cartridges
Dec 17, 2016 | Office Equipment & Supplies
Yellow is not appearing in my color printings
Often, when a color is not printing, or it is not showing the correct shade/color, it is because one or more of the color ink cartridges is low or empty. See if this happens when you use new ink cartridge(s)
Mar 03, 2014 | Brother MFC-465CN InkJet Printer
Magenta color problem
This can be caused by one color not printing ...either from the lack of toner or the cartridge not being seen as full ..To reset them follow this procedure..
http://www.ehow.com/how_6881778_reset-2600n-toner-chip.html
This will override the toner level in the cartrdges and allow it to print all colors..and probably get rid of teh problem ..Usually the magenta predominant printing is caused by the lack of yellow color ..so watch it cause this one might empty first and cause it again if this procedure fix it for now ..There is a possibility that it is already out ..(empty )
Jan 28, 2011 | HP Color LaserJet 2600n Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Problem in cartridge of HP Officejet Pro L7380 All-in-One Printer
Every cartridge needs to have ink in it to print. Even if you only want to print black and white and one of your colors is empty. A dirty little industry secret is that when you print black....it also makes the colors print too...so you get to buy even more ink than you need to!
Dec 19, 2009 | Office Equipment & Supplies
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
HP C6280 with new ink cartridges shows cartridges empty
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Feb 03, 2009 | HP C6280 All-in-One Printer
I had a refilled canon cartridge for the MP 610 printer It now says cartridge is not recognised and shows it empty although its full
That is correct. Canon refills always show as empty. You will have to wait until the cartrdge runs out of ink before you know it is indeed empty.
May 06, 2008 | Office Equipment & Supplies
Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
JP
Dec 31, 2007 | Epson Stylus CX5000 InkJet Photo Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
121 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
