You need a new relay. You can purchase an entire kit which would be your best and easiest replacement. It is part number URCO410. The instructions will come in the kit. Its fairly inexpensive and will get you up and running for a few more years unless your compressor was damaged. Just read the instructions carefully and make sure your wiring is right because if you wire it wrong you will burn up your compressor windings.
Hope this helps _MJ_
The module you are talking baout should be the over load relay and ptc start switch.it should be on the right side of the compressor if it is smoking it needs to be replaced as soon as possible.
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
