Question about Dell Inspiron 530s Desktop Computer
Cannot access system -- forgot password. Cannot
Cannot access system -- forgot password. Cannot enter BIOS without password to change it. What else can I try?
  • karekter5 Feb 07, 2010
    Most of us would be too timid to short out something inside their system with a paperclip but I still think your advice deserves an EXCELLENT rating!
  • joecoolvette
    joecoolvette May 11, 2010
    It'll clear the CMOS password, but you can't bypass the Windows password.
  • 583 Answers
Open the computer case. On the motherboard, (looking from the bottom of the motherboard), in the bottom right quadrant, to the right of the CMOS battery, you'll see two jumpers labeled CLR_CMOS and PSWD. You'll want to move the jumper for the PSWD block to pins 2-3 for 5 seconds and then replace the jumper on pins 1-2. This will clear the CMOS password.
Posted on Feb 07, 2010
    Brigadier General:
  • 4,090 Answers
Open the door where the RAM chips are, locate the pins ( should be two) short out with a paper clip and reboot.
Please rate my help++++Thanks for using Fixya
How can i have the password bios of laptop dell E6420
f you are running Dell servers, it is recommended to enable BIOS password. This is will prevent accidental changes done to Dell BIOS settings by others who get physical access to the server.
You can setup two different types of passwords in Dell BIOS:
System Password: This will be prompted before the system can boot up, and load the operating system.
Setup password: The system will prompt for this password only when you are trying to access the BIOS settings.
Depending on your situation, it might be a good idea to enable both the system and setup password at the BIOS level. I recommend that you at least enable BIOS password.
Press F2 for System Setup
When the Dell server is booting up, press F2 to start system setup, from where you can change Dell BIOS settings.
BIOS System Security
From the Dell BIOS main menu, scroll down to "System Security" and press enter.
Password Not Enabled
From here, you can see that both the System and Setup password is not enabled by default.
Enable System Password (and Setup Password)
Scroll to "System Password" and press enter, which will prompt you to enter the password that you like to set for the system. Please understand that if you set this password, you have to enter this password everytime you start the system. Do the same thing for Setup Password.
Don't forget this bios password. If you forget, then you have go through the painful process of resetting the Dell BIOS password.
Password is Enabled
Once you've enabled both the password, from the "System Security" menu, you'll see that that both system and setup password is enabled as shown below.
password is set
System Password Prompt (During Startup)
From now-onwards, anytime you start the system, it will not load the operating system, unless you specify the system password as shown below.
12345
Setup Password Prompt (To Access BIOS)
If you press F2, to get to the BIOS, it will prompt for the setup password as shown below. If you don't enter a valid password here, you cannot access the Dell BIOS settings anymore.
Dec 16, 2014 | Dell Latitude E6420 Laptop Computer...
Remove password from hardrive in bios
Before your computer loads your operating system, it starts by running the BIOS program, which is extremely important because of its various options.
You can even set a password on your hard drive so that nobody can use your laptop computer without your password.
Once you put in the password into your hard drive, you can only remove it by accessing the BIOS system and deleting the password completely from the memory of your computer.
Save all of your important files on an external hard drive or similar storage device.
This is a precaution to avoid losing all of your files when making changes to the BIOS.
Then, restart your computer.
Wait for your computer's operating system to ask you to access the BIOS menu.
This may be at different times, depending on the manufacturer of your computer.
It can ask you when the manufacturer's logo comes up, or on a separate screen indicating for you to click the "F2" button on your keyboard to start.
Access the BIOS menu by clicking the key or combination of keys that you are informed to click. This information can be found in your computer's manual, but it changes between different companies.
Commonly used keys for this process are "F10", "F2" and "Delete."
Go to the BIOS option that contains your hard disk drive password.
The option that will lead you to this password varies immensely due to different laptop models, but it may appear as something such as "Advanced" or "Security."
Look for the option for changing the password, which should say "User Password," and then click "Enter." Put in the existing password and then click "Enter."
Do not enter any password into the blank fields asking you to enter a new password, and this will remove the password.
Exit the menu by clicking "Save and Exit." Click "Enter."
Mar 17, 2014 | Computers & Internet
Accer apire one d255e hardisk security lock
The BIOS (Basic Input Output System) is designed to check the integrity of the computer hardware and launch the operating system. The BIOS also has basic security features that prevent unauthorized access to the computer by locking the hard drive with a password. The password is required in order to launch the operating system. That option can be disable without an changes to the operating system.
Turn your computer on. Press "Esc," "Del," "F2" or "F8" to access the BIOS. Use the arrow keys to go to the "Security" tab. Press "Enter." Highlight "HDD Lock," Boot Password" or "Hard Drive password" using the arrow keys. Press "+" until "Disable" appears. Go to the "Exit" tab, highlight "Save and Exit" and press "Enter." Press "Y" when prompted to reboot your computer without the hard drive password.
May 05, 2013 | Computers & Internet
Forgot ip address and password
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE
- Web Interface
- Device >Configuration >Initialize To change the Default User "ADMIN" password it is necessary to use the Console connection
-Console Interface
-Once the unit has successfully booted and the prompt presented
-Enter "password" (without "")
-Enter "admin" when the system prompts for User
-Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands)
-Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password)
-Enter "" when the system prompts to confirm the New Password In order to complete the configuration it is necessary to save the configuration via the WEB INTERFACE
-Web Interface
-Device > Configuration > Save
Symptom:
SW2900 Baseline Switch - Default console access disabled following password change
From the web interface, the default user "admin" password is changed and console access is disabled
Cause:
When applying the new password, by default the service-type is set to "telnet". When applied, the default "terminal" setting is removed thus disabling console access.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
RESET HARD DISK DRIVE LOCK FOR ACER ASPIRE
Step 1:
Which model of acer laptop ? there are many
Feb 19, 2013 | Acer Aspire Computers & Internet
How to reset hp probook 4310s embeded security password
If your hp computer is installed with Windows 7, following the video to learn how to reset hp computer security password with Windows 7 Password Genius
https://www.youtube.com/watch?v=I5HzG7fb-Wg
If your hp computer is installed with Windows 8, and the password is your only admin password, refer to hp computer Windows 8 admin password reset.
Jun 20, 2012 | HP ProBook 4310s Notebook
Forgot username and password for IBM thinkpad x41
Back up your most important data to an external storage device in case anything goes wrong while changing the BIOS settings. Remove any disc that is currently inserted in the IBM Thinkpad X41's disc drive.
2-Shut off the Thinkpad X41 laptop. Turn the laptop back on and wait for the "To interrupt normal startup, press the blue Access IBM button" message to appear on the screen.
3-Tap the blue Access IBM button at the top of the keyboard. Click the "Access BIOS" button when the "Rescue and Recovery" menu appears.
4-Click "Yes" and wait for the BIOS to load. Type in the current BIOS password for the IBM X41 and press Enter.5-Navigate over to the IBM's "Security" heading by tapping the right arrow key twice. Scroll down to the "Supervisor Password" listing and press "F5."6-Type the IBM's current BIOS password and hit Enter. Leave the next field blank if you want to completely remove the BIOS password, or instead type in a new password to replace the old one. Press Enter.7-Press "Escape" and then highlight "Restart" and press F5. Navigate to "Save changes and Restart" and press Enter.
  • Nov 05, 2011 | IBM ThinkPad X41 Tablet PC
    IBM T60 Bios password has to remove
    The simplest way to remove a BIOS password is to simply remove the CMOS battery
    Jun 14, 2011 | Computers & Internet
    Pc "bios"problem
    this looks like you have kept the bios password and you forgot it. just do one thing open the cpu case to access the inside of the system and then just remove the battery in it. wait for 5 min and again plug in the battery. thats it your bios memory password will be reset.
    2nd solution without removing battery. just reset the bios as shorting the jumper pins. consult your motherboard book to know where to find the bios reset. it will be written as CLEAR CMOS.
    Dec 21, 2009 | Intel Computers & Internet
    I have a inspiron 1100 laptop. I cannot remember my login password. Please help, any suggestions?
    This question has been asked (and answered) hundreds of times. Here is the best answer I pulled up for you.
    http://www.windowspasswordsrecovery.com
    Oct 25, 2009 | Dell Inspiron 1000 Notebook
    Dell Inspiron 530s Desktop Computer   Logo
    230 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
