Question about InFocus ScreenPlay 4805 Multimedia Projector
No Power my 4805 wont power up I replaced the bulb but cant get any power please someone help
  • friction1 Mar 08, 2008
    Thx for the Advise it has been very helpful
  • Anonymous Mar 17, 2008
    fan runs ,lamp comse on for 2 seconds then goes out, when repowering after a few minutes same happens. led does not come on. my e- mail is verelst@gmail.com am I am in South-Afrika (no agents for infocus ) would appreciate any help . thanks Ferdi
When you say no power do you mean nothing is lit not even the led on the top cover. If that is the case the power supply maybe at fault. Check with another power cable and make sure the lamp door is fully seated in it's place.
Posted on Mar 08, 2008
Check fuse, check to see if fan is clean, check to insure lamp and houseing is completely seated
Posted on Mar 06, 2008
Infocus 4805, wont power up remotely
the lamp has burned ot and needs replaced,
Nov 25, 2007 | InFocus ScreenPlay 4805 Multimedia...
Ordered/installed from Infocus a new bulb unit.
the colorwheel needs to be replaced. the projector won't turn on if the colorwheel motor is not up to speed.
Feb 25, 2010 | InFocus ScreenPlay 4805 Multimedia...
How do i find out if i need a new lamp for my infocus 4805. when i turn it on the fan blows for a cpl secs and the green light blinks a few times, but i dont get anything saying the lampis out
when you power it on, do you hear a high-pitched whir? if not, you need to replace the colorwheel. it's also the colorwheel if you hear a buzzing instead. if the colorwheel does not spin, the lamp won't come on. if the colorwheel is ok, check the lamp. is the screen on the side of the lamp clogged with dust? is the inside of the lamp bulging, spotted, or foggy? if so, replace the lamp and clean out your projector with canned air. dust blocks air flow and keeps in the heat. this shortens the life of your lamp and projector. if you do need the colorwheel replaced, you could get the part from an infocus service center and do it yourself, or send it in for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 27, 2009 | InFocus ScreenPlay 4805 Multimedia...
Tail lights wont work on my 1996 explorer
pull the bulb and check for power to the bulb socket if there is power replace the bulb because what happens is the bulbs get so hot they melt the sawder contacts at the bottom and that causes them not to work
Aug 19, 2009 | 1996 Ford Explorer
My bulb went out on my infocus sp-4805. I bought a new bulb, and replaced it, and it worked...for five minutes. the picture went out, and it was overheated. I took some parts off, and sprayed can air in...
The fan is probably on it's way out and cannot produce enough air flow to cool the lamp. Replace the fan with the same ratings as the original and it should work fine. The only other thing would be a problem with the power supply not supplying enough power to the fan, but, a bad fan is more likely.
Feb 24, 2009 | InFocus ScreenPlay 4805 Multimedia...
I turn on the 4805,green led blinks & bulb does not come on?
After a few minuets does the green blinking light turn to a red blinking light?
If so the problem is the lamp did not strike.Either the lamp has failed (most likely) or there is a problem with the power supply (less likely)
Feb 12, 2009 | InFocus ScreenPlay 4805 Multimedia...
No pwer to Infocus sp 4805
My 4805 made a loud pop noise and smoke and died.
I thought it the bulb and wasted $340 on that purchase.
They are subject to overheating and the main circuit board may be fried.
It cost me $50 for a tech to confirm my suspicons of the same.
Look at the main circuit board and you might idenify a scorched
overheated area.. My shop told me you can purchase a new main
board.. Diagnosed by no power to the bulb...
Sep 12, 2008 | InFocus ScreenPlay 4805 Multimedia...
Infocus 4805 Projector - Color Problem
It is possible that the LCD panels are burned. Is the green the only color that is off? Typically the bulb won't change the colors that drastically. Verify that the input is set correctly, having a unit expecting component inputs when you provide RGB will change the colors too. Please update this with your findings.
Dan
Apr 03, 2008 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
197 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
