Question about M-Audio Studiophile BX8 Main / Stereo Speaker
Need help...My M audio Bx8...One works perfectly, the other has power, but no sound.Please call...I'm in a session 336-541-4693 mastersong1@netzero.net
  • mastersong1 Feb 07, 2010
    I switched speakers....same problem with same speaker. My blue light is on both speakers. I'm just not getting any sound out of this particular one.
    My M audio Bx8 Studiophile speakers...One speaker works fine, the other has power (blue light is on) but no sound. I have switched cords and speakers etc...same problem with the same speaker. HELP
  • 506 Answers
Well from my understanding these are bi-amped monitors. One amp drives highs and one amp drives the mids and lows. being that you do not have sound from either a common point betwenn the two amps has failed. if you have already verified your source input is correct not much can be done at this time. the monitor needs to be opened up and repaired. without having a schematic i can't even tell you where to begin. i will talk to M-Audio tomorrow to see if they can even share that kind of information. Sorry I couldn't fix your problem but your monitor is quite possibly down and out for a bit. I will let you know what i find out.
Posted on Feb 07, 2010
  • 583 Answers
To determine if it is the signal going to the speaker or a problem within the speaker unit, swap speakers. If the problem stays with the speaker unit, then you have a defective speaker. If the problem moves to the other speaker, then you have a signal problem. If it is a signal problem, it could be the wiring from the signal source or the signal source itself.
Let me know what you find or please clarify if I didn't understand your problem correctly.
  • Mark Tidwell
    Mark Tidwell Feb 07, 2010
    The issue is inside the box then. If the unit is not under warranty and you want to try and affect a repair yourself, you'll need to remove the back of the cabinet. First, be sure that any overloads are not tripped (the power to the system will not be interrupted if the overload for the speaker is tripped).
    Once inside the unit, you will need to look for any overloads that might be tripped inside as well. There is not any user serviceable components inside, but you can check for obvious things like loose connections, especially the wiring from the amplifier to the speaker itself. There could be a fuse for the amplifier that is separate from the power supply which would allow the power light to operate, but the remainder of the system to not function.
How to take the big speaker out of a studiophile BX8 speaker
As you can see, there are 8 screws holding the woofer in. Remove them, lift the speaker up, but before you disconnect it....Mark + and - onto the wires...red + and black -. .http://i46.tinypic.com/14l3j0z.jpg
Aug 18, 2014 | M-Audio Studiophile BX8 Main / Stereo...
How to remove tweeters maudio bx8 speakers
Remove the backplate and the wires are often hold togeter with a tiedrap, so you need a long , how do you call it in english:) , sciccoskind tool or you can try to unplug, the plugs between the powerunit/ amplifier and you speakers . I'm busy rebuildimg m3-8 from m-audio, cause of some where cheap amp/powerunit and did it by hand and i have large hand, but put some tape around the backplatesurrounding for scratches.
And if you have them loose you can remove them.... but why?
Do you think you just can replace them for other once, think again
Jul 10, 2014 | M-Audio Studiophile BX8 Main / Stereo...
Cracklin/popping with m audio bx8 d2's thru fast tack mk2
Check for flucuations in your power supply. If none then put a shield sleeve on your cord.
May 03, 2012 | Avid M-Audio BX8 D2
M audio bx8 blows a fuse
best solution wrap the blown fuse with a piece of tin foil and put it back into the fuse terminal and you shouldn't have a problem.
Mar 03, 2012 | M-Audio Studiophile BX8 Main / Stereo...
Working with Vista
M-Audio Session is looking for the USB device, e.g. "Micro" or "Fastrack"
Jun 21, 2008 | M-Audio Session KeyStudio USB Keyboard
Humming BX8
Hello docjgg,
This sounds like it may be a loose connection (ground) generation common mode noise or it may be a capacitor in the power supply going bad and not providing enough filtering of the AC voltage (allowing for 60 cycle hum). You should get a schematic for the speaker or just take some rule of thumb measurements of the power supply output, with an oscilloscope (you will be looking for ripple voltage, what you could do is use one of your good speakers as a comparison of good to bad.
If you do not want to work on this yourself, you could take the speaker to any TV repair shop or audio repair shop.
I hope this helps
Thank you,
Shuttle83
May 25, 2008 | M-Audio Studiophile BX8a Speaker
Bx8 monitors problems
You will need to REPLACE THE WOOFER / DRIVER on this unit. Cost for a new driver is about $80.
- DJPA
Nov 04, 2007 | M-Audio Studiophile BX8 Main / Stereo...
Subwoffer how to connect it to my amp
You have the M-Audio BX8A speaker listed here. Is this what you have? If so, this is a powered speaker and therefor no need for an amplifier. If you want to use it as part of your 5.1 home theater system, it is not possible to power other speakers with this particular speaker, as it does not have the required output connections.
Jul 23, 2007 | M-Audio Studiophile BX8 Main / Stereo...
M-Audio BX8 blows a fuse
If your monitor is crackling and fizzing, that is not a fuse issue, unless the fuse you have installed is underrated. It sounds like you have a bad driver/woofer, and need to get it replaced. CLICK HERE FOR THE REPLACEMENT DRIVER for this model.
- DJPA
Jul 05, 2007 | M-Audio Studiophile BX8 Main / Stereo...
M-Audio Studiophile BX8 Main / Stereo Speaker Logo
136 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
SHIVAJI YADAV
SHIVAJI YADAV
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
