Question about Kitchen Ranges
Tappan model tef326fb Cook top works fine....CPU works...Neither element in oven will come on
  • 1,531 Answers
This is usually a faulty electronic control panel.check both the elements and see if you continuity if you do they are good and you need to replace the control board( EOC ).
make sure to check the wiring to the rang and make sure all the connections are tight.
I hope htis has been some help to you good luck
Posted on Feb 07, 2010
Why does my broiler lite when I operate my oven?
There is a possibility that the switch is not wired correctly or perhaps your selector knob is on upside down i have seen this before.
Jul 15, 2014 | Tappan Ovens
Gas Tappan oven will not power up after power outage
make this test and use the multimeter. God bless you
No power
Make sure there's power getting to your range, oven or cook top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
Nov 04, 2013 | Tappan Kitchen Ranges
The inside oven is not heating. The top burners are working fine.
If this is an electric oven, most likely the oven bake element has burnt out.
the model and serial number should be behind the bottom drawer,
most elements are held in with (2) 1/4 inch socket hex head screws.
Remember to unplug stove or shut off breaker before servicing.
The element can be slid out usually, then unplugged or remove
the back cover behind stove and unplug it from the wiring harness.
I hope this is useful
Aug 02, 2011 | Tappan Ovens
My D61 e delongi cooker will not work the oven at all ,the cook top is fine
Most common oven problems are;
Faulty oven element - check continuity with meter - if faulty replace;
Burnt wiring at the oven element terminals - visual check - if faulty repair;
Electronic clock/timer on auto. - clock timer must be on manual for manual oven operation.
Feb 16, 2011 | Ovens
I tried to cook a frozen pizza in my Tappan electric range last night (which required it to be preheated to 400 degrees) and it would not preheat at all, even after about a 3 hour wait. I just turned up...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153992&diagram_id=1251523#d1251523
your looking for part number 67 on that part breakdown
it is the bake element and if you inspect it im sure you will find it cooked or broken
befor you actually order the part take the unit out
unplug it
and inspect your wire connections to both sides of the element
Oct 17, 2009 | Tappan 30IN ELEC IGNa Oven
The oven does not heat up. broiler and cook top is working.
Check to see if the oven elements work, take out the racks and check if the black tubes on the top and bottom have ripped.
Aug 05, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Stove does not work now that we have removed a broken element
Carleen,
Thanks for the reply.
OK... I know this sounds odd and all... but all of the components (elements in the oven specifically) have to be installed and working correctly for the oven to operate properly.
Most people don't know this, but even when the oven is turned off and sitting there peacefully waiting for something to cook, there is STILL 120 Volts at one of the terminals on the element. Know what that means? That means that it is constantly (always) powered up! It also means that it is a necessary component involved in applying 220 volts to all the OTHER (cook top burners anyone?) components.
So... to take care of this and to bring you oven (and cook top) back to life, ya gotta go get yourself a new element and install it. OK?
Do you have the model number? If you do, give it to me and I'll look up the part number for you, deal?
SG
May 17, 2009 | Hotpoint RB525BC Electric Kitchen Range
Bake or broil does not work
if an element itself had shorted it would not stop the other from working and you could inspect each element and see blistering as evidence.the pop you heard has to be in common with both elements but not the cook top[burners]so thats going to be the wiring in the back of range, or switching,[thermostat,clock timer or oven selector switch,depends on which model you have]you will have to pull range and remove back pannels.you will find an obivous burn't connection.too repair all new connections must be clean and tight,or will burn again.
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Tappan oven won't turn on after cleaning
I don't precisely understand...responding. I assume that if you say oven on that the oven isn't heating but the indicator controls are working. This has several possibilities. First, do turn your circuit breakers off then on...there are two linked together. This may reset something. If that fails, your problems are likely in either the high limit safety switch or the heating elements. The elements are more likely. To check them, turn off the power and remove them from the oven. This is usually by taking out one screw and unclipping the element. See if the element is bulged or damaged. If not, use a multitester to see if one of them is not conducting. Replace it. High limit should conduct fully. Use the curcuit diagram on the stove to determine its location.
Dec 27, 2007 | Ovens
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Kitchen Ranges Logo
152 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
