Question about Fisher and Paykel GWL11 Top Load Washer
My Fisher Paykal Washer is filling and emptying at the same time
As my washer fills (cold) is also empties at the same time. I did remove the pump the other day because it blocked with a hair pin of all things. It work fine the next day. I have removed the pump before when the spinner was wrapped with theads and was stuck.
  • 1,531 Answers
Check your drain hose if it to low in the main drain pipe this can cause the water to siphon out as well and there should be a small flap like door in the drain pump assemble that may be stuck in the open position.there is a chance that you may need to replace the pump. check the wiring and make sure it is connected properly
Posted on Feb 07, 2010
Water will not drain, makes a noise when filling, pump does not seem to be froze up.
Three things to inspect are:
  1. Clogged drain hose - cause water to back up to the pump and shut down
  2. Clogged drain tube - usually occurs when the drain hose is attached to a drain tube that empties out into the homes sewer system. Just like a clogged drain, water will back up all the way through the drain hose into the pump and shut down.
  3. Clogged or bad drain pump - Many times, debris left in pockets will work it's way into the drain pump. Over time, enough debris (paper, coins etc) could lodge itself into the pump. When the machine tries to empty or spin out, the pump becomes overwhelmed and shuts down. Sometimes, you may even see a puddle of water appear under the washer due to a clogged pump. This can also happen if the pump itself is worn out and no longer working up to specifications.
Luckily, your drain pump is easily accessible. Placing a towel or blanket down, unplug the machine, disconnect the fill and drain hoses and gently turn the washer forward onto the towel or blanket. Only tools needed are a pair of pliers and a phillip head screwdriver. After removing the drain hose and the screw holding the pump in place, it should easily be removed so you can inspect for debris (a very common problem with F&P washers.
Best of luck with your repair.
Greg
Jul 20, 2011 | Fisher and Paykel GWL11 Top Load Washer
I have a Fisher and Paykal Smart Drive 053 washine machine. It has just started doing the following: Start load - Cold, warm or Hot and any size Fills intermittent. will fill for a couple of seconds...
Hi just read your posting.When the machine stops and starts does it beep and show an error code.This error code will be a series of lights that light up and the machine will beep.On the wash progress line of lights which lights are lit when the machine beeps,Is it the 1st and 6th or the 4th and 8th etc.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Jun 05, 2011 | Fisher and Paykel (IWL12)
We have an old Fisher and Paykal top loader GW608U, it has been sitting in a store without being used. now that we what to use, we connected all the pipes but the machine keeps taking on water. hot and...
The seals have perished and need replacing contact f&p service with model no and purchase new ones. Udo control panel after disconnecting power to machine .Water valves held in by 3 screws and 2 control wires
Apr 29, 2011 | Fisher and Paykel Fisher & Paykel Washer
During the rinse cycle, our GWL 11 Fisher & Paykel
The problem is in the pump, so it will not pump out, you will need to find another way to empty it, removing the agitator will make the job easier.
When you get the water out the pump can be accessed from underneath, it turns anticlockwise to remove it,.
I would buy a new pump as it is most likely that is all that is wrong with it.
Apr 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
It wont complete cycle and empty the water just hums for a while and then turns its self off
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
It is very cold in my garage where my Fisher and Paykel washing machine is. First it would not fill it just ran and ran without filling, then it started filling fine, but then after a while started...
water freezes. sounds like first your fill pipes were froze then the pump froze. if you can find a place inside the house for washer or you may have to build a room around washer and dryer and heat it
Dec 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
My maytag neptune washer stop washing with 10 minutes left to go.
If your machine is a FAV6800AWW or FAV9800AWW the (upside down u and f) may be a “NF” for no fill error. The washer has tried to fill the machine with water and has sensed a water fill issue. The control board has shut the wash cycle down with an “NF” error to the display because of excess time to complete the water fill portion of the wash cycle.
Will the machine complete the cycle with Hot water only or Cold water only? I would do a Quick Wash cycle just to test with an empty wash basket.
Regardless of the above test and assuming you have good water pressure for both Hot and Cold supplies to the washer I would do the following. Close the water source valves to the washer and remove the Hot and Cold hose connections at the back of the machine and check for clogged inlet screens. If the water inlet screens are free of restrictions I would go into Service Mode and turn on the Hot and Cold water valves on one at a time and make sure the tub will fill with about 2 inches of water in about 3 minutes in service mode. Check both Hot and Cold inlet valves individually see page 16 of the SM Board Output Test, enter service mode and do the function test for both Hot and Cold Water Valve’s. If the inlet screens are clean and you have water fill restrictions in service mode we may need to look at replacing the water inlet valve assembly. You can turn on the drain pump in service mode to empty the tub or just start a wash cycle and the machine will empty the tub.
The Service Manual for reference. Sears Parts Direct for reference.
May 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer continuously filling/emptying
Your drain hose from the washer is in your household drain line too far, should not be any further in the drain line than 7 inches
Mar 23, 2009 | Washing Machines
Fisher paykel will not complete rinse spin cycle
will sence it will spin once the water is out .that must mean your pump is restricted.unplug go to buttom of washer find pump and clean out
Dec 31, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel GWL11 Top Load Washer Logo
123 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
