Question about Broan-NuTone Allure II QS230SS Kitchen Hood
Broan Allure QS2 Range Hood
Hello, A few weeks ago the lights and the fan stopped working on my
Range Hood. The small green indicator light still lights when I press the various fan power buttons, but there is no power to the lights or fan. What would cause BOTH of them to stop working?
I have already replaced with new bulbs and re-set the circuit-breaker in the
hopes of restoring power - but nothing has solved the problem. The Range Hood is hard wired on the same breaker as my ktchen lights and i have had no problems the 7 years I have had it.
Thanks in advance for any help you can give.
  • shanman11 Mar 08, 2008
    Range Hood. The small green indicator light does not light when I press the various fan power buttons, but there is power to the lights or fan. What would cause BOTH of them to stop working?
    I have already re-set the circuit-breaker in the
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Posted on Mar 11, 2010
  • 1 more comment
  • alex5 Oct 09, 2010
    I figured out what cause the fuse to blow. When one of the halogen light blown, it creates a instant short before the element clears, causing the control board to get a higher than normal current flow.Good job sbamga, I would never fine the control board in that mess of equipment assembly.
  • Bruce Rahn Oct 06, 2011
    I have the control board but I can not see any fuse.Where is it and how does it look like please?
  • petercaseydo
    petercaseydo Jul 20, 2012
    BINGO! This should be the first thing to look for. The best way to access the control board will be either to pull out the range so you have a good view of what you're doing, or to simply take down the range hood and work on it on the bench.An assortment of fuses can be found at your local Radio Shack.
    Welcome Back:
    Visited the website for 2 consecutive days.
Hi, we are trying to replace the fuse on our Allure III hood but cannot find it.Would rather not remove the whole hood as we are not very handy! Can anyone provide detailed instructions on how to get to the fuse?
Posted on Aug 18, 2012
  • Bruce Rahn Aug 19, 2012
    I replaced the control board with a new one.The new ones have a fuse but my old control board did not have a fuse.
Lights will not stay on on my allure ventahood fan works well but lights come on then go right back off
Posted on Dec 16, 2009
Broan QS2 Allure 30" ---- the three aluminimum spring clips that are riveted inside back of the hood are broken. They are designed to hold pressure against the frame of the hood vent filters. Where or how do I obtain these three clips either online order or dealer with parts?
Posted on Mar 10, 2011
  • 38 Answers
If definetly the control board Part # R111638. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
Posted on May 14, 2008
  • 40 Answers
It sounds like the control board failed.
Posted on Apr 16, 2008
PK2229 blower stop working
Light and fan are two separate functions in your hood. The fan gets very greasy from the cooking. The grease doesn't act as a lubricant but as dirt. Remove the fan from the unit and check to see if the shaft is wiggling,or if it is seized. At this point you may need to replace motor. If it turns somewhat put a few drops of oil at the shaft, both ends if possible, and spin the fan by hand until it's loose. Replace back into hood and see what happens. Many times the bearings in these fans go dry and will not spin. GOOD LUCK FRIEND.
Jan 18, 2015 | Kitchen Ranges
Tip
The green fan-level indicators will operate properly but the fan/light will not...
Hi Mertl, I sure hope you found the solution since, but I am posting the answer for other people like me (and you) who need to find it !
The service manual says:
To replace the fuse:
1. Disconnect power at service entrance.
2. Remove filters, bottom panel, light wire harness, and air chute.
The fuse is actually right behind the fan controls, so to access it you need to disassemble everything that's in the way.
BTW, for anyone wondering if it's the fuse that's faulty, here's a clue:
If the fuse has opened (blown), the green fan-level indicators
will operate properly when the fan buttons/switches are pressed
- but the fan and lights will not turn on.
The fuse is a 5 x 20 mm, 10 Amp, Fast-Acting, 125V (min.).
Good luck all !
on Oct 05, 2008 | Broan-NuTone WS230 Kitchen Hood
Brian range hood model CJD130SS fan light on display flashes with fan off or on.
I believe that's the "change or clean filter" indication. Clean the aluminum filters in the dishwasher, replace the charcoal filters if non-ducted, press the fan light over 3 seconds and it should reset.
Sep 02, 2013 | Broan-NuTone Broan Elite E661...
The fan in my has not stopped working in a few weeks now.what can I do to make it stop blowing air
test this steps and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Jul 29, 2013 | Kitchen Ranges
Exhaust fan and lights do not work
see this steps and fix it. God bless you
Switch If the range vent hood fan and light are not working the switch might be defective. Watch our video on switch testing and test this switch for continuity.
Selector Switch If the range vent hood fan and light are not working the selector switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rotary Switch If the range vent hood fan and light are not working the rotary switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rocker Switch If the range vent hood fan and light are not working the rocker switch might be defective. Watch our video on switch testing and test this switch for continuity.
Switch Kit If the range vent hood fan and light are not working the switch kit might be defective. Watch our video on switch testing and test this switch for continuity.
Micro Switch If the range vent hood fan and light are not working the micro switch might not have continuity. The best way to test the switch is with an Ohm meter. See our switch testing videos for help testing this micro switch.
Thermal Fuse If the range vent hood fan and light are not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Main Control Board If the range vent hood fan and light are not working the main control board may be defective.
User Control and Display Board If the range vent hood fan and light are not working the user control and display board may be defective. Check other causes before ordering this board.
Oct 02, 2012 | Dacor Millennia DHI602 Kitchen Hood
Fan turns on and off since turning hood light on a few days ago
If it is a Broan, there is a delay button that was also depressed. It will turn the fans off after a few minutes. If not, then you're shorted out either in the control panel or the wiring in the range hood.
Sep 23, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
Changing fuse on Nutone Allure Ws2
Good luck all !
Aug 16, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Printhead light is flashing
the light indicator on the machine blinks one (1) green and then (six) yellow, over and over again. what does this indicate? a few weeks ago it blinked 7 times and i had to change the ink cartridge holder.
if(zs>0){w(''+x2+'#b">Get the answer below
');zSB(1,3);w('
Mar 23, 2008 | Zebra 105Se Thermal Printer
Broan-NuTone Allure II QS230SS Kitchen Hood Logo
6,239 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
