Question about Jabra Bluetooth Headset with Adjustable Ear-Hook Headset
I cannot get my Blackberry Storm to pair with my Jabra BT2070.
I have charged the Jabra for two hours. On my phone, Bluetooth is enabled. My phone finds a device sometimes, but it says Blackberry 9530. It's like the phone is just finding itself. This is crazy! Other times, it cannot find any device to pair with, but the Jabra is supposed to be "auto-pairing", right? Thanks for help.
  • 583 Answers
You have to first put the Headset into discoverable mode. According to the Jabra website, this is done by pressing and holding the end/mute button until the light comes on steady. Follow the procedure for your phone to pair a bluetooth device to it. The PIN code will be 0000.
Posted on Feb 07, 2010
I cant use my jabra BT2070 what is the password for pairing update????
Hi leovy_naguit,
I see that you need information regarding your Jabra Bluetooth Headset.
*Once the Light on the Headset is constantly lit it means that it is ready for pairing.
*On you Mobile phone go to Bluetooth it should be detected as soon as you set your mobile phone's BT to be discoverable.
*Select Connect/Accept/OK or which ever options you Mobile Phone will provide when pairing with your headset.
*The pairing code will be " 0000 "
This should help you pair up your headset with any Mobile phone or device that uses Bluetooth.
I hope that this will be of help.
Have a nice day,
mvincentc
Apr 30, 2011 | Jabra Bluetooth Headset - BT2070
How can i connect my jabra bt2070 with my computer running windows 7?
You can buy a bluetooth usb adapter and make your pc bluetooth enabled. I bought an I/o gear blue tooth adapter for $ 2.58 and it allows me to pair up my headset to my pc and I can go up to 500 ft away and hear perfectly.
All you need are 2.0 usb ports (high speed)
the adapter can cost up to $ 20 but it works and boy is it worth it!
Apr 20, 2011 | Jabra Bluetooth Headset - BT2070
I am pretty sure that the numeric passkey for Jabra BT2070 is 0000 but it doesnot work in my blackberry 8900. how do i connect it to my phone ?
Try this... 1. Turn off the Jabra bluetooth. 2. Turn on by pressing Volume up + power button until the power light comes on steady. 3. Then turn bluetooth from your blackberry 8900 and make the bluetooth seen/available by other devices. 4. Search bluetooth in range...Look for Jabra BT2070 click then will ask you to put the code which is "0000" or "1234". 5. Then check if the steady light comes to blink...
Mar 19, 2011 | Cell Phones
My jabra bt2070 bluetoot headset blinks 3 times and won't pair with my blackberry. What do I do?
Have you already tried to put your headset in pairing mode first? Anyway, to do it, starting with it turned off, press and hold the on/off button for some 5 seconds, until the indicator light is steadily lit (it will flash as it was being turned on, but don't release the button at that phase). Then, make your phone's bluetooth application search for new devices. After a while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros);
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out.
Regards, Carlos
Jul 05, 2010 | Jabra Bluetooth Headset - BT2070
How pair bluetooth Jabra vbt2050 with a blackberry storm 2
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
Mar 04, 2010 | RIM BlackBerry Storm2 9550 Smartphone
I bought a jabra bt 2050...i cant get the led light to stay on..it only wants to flash...and it wont pair with my blackberry storm
Try to press and hold the center on/off button for 10 seconds, this will put the Jabra BT2050 into paring mode.
Assumptions made:
1) The BlackBerry is Bluetooth enabled.
2) The Jabra BT2050 is fully charged.
Hope this help.
Joseph
Jan 05, 2010 | Jabra BT2050 Bluetooth Headset
Jabra 2050 wont pair with blackberry storm
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Sep 05, 2009 | Jabra Bluetooth Headset with Adjustable...
How do I put a Jabra VBT 2050 into discovery mode?
OK, this is what you do: 1. Make sure your Jabra VBT 2050 is fully charged. 2. Enable bluetooth on your phone. 3. Turn on your VBT 2050 with the little button on the side (the white light between the keys should flash). 4. Initiate a search from your phone while holding down the center button on the VBT 2050 (middle, under the + and -). 5. You might need to do another bluetooth search using your phone (it took me about 4 times befor my Blackberry Storm picked up the signal. 6. When your phone asks for a code, type in 0000 (the default number).
Jan 10, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
Jabra Bluetooth Headset with Adjustable Ear-Hook Headset Logo
883 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
romy sibug
romy sibug
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
