Question about IBM 17IBMRBABLKNR
Color on monitor
The color on the screen of my monitor has changed to bizarre colors of pink and blue. I went into properties and display options, but the problem still persists. Any suggestions?
  • 160 Answers
check that the signal cable from the CPU to the monitor is not having loose contacts. if the problem not solved it may be due to the LOT or IC problem, contact the service man at the nearest to you.
Let me know if your problem is solved and rate me as FIXYA!
Posted on Apr 17, 2008
  • 34 Answers
If going to DEGAUSS (Magnet or upside down U) doesnt work, and you have already changed the colors, try wiggling the cable (Look for changes, same happened to my old monitor) and if all elsa fails, give it a proper burial...
Posted on Feb 22, 2008
How do I adjust the color on monitor?
  1. PC Monitor
    • 1Check the color balance options on your monitor. Typically, there is a button on the monitor itself that can be used to enter the Settings menu and configure color. The color balance may have somehow been changed, resulting in the pink image.
    • 2 Calibrate the color system for your monitor through Windows. Press "Windows-X" to open the Power User menu and select "Control Panel." In the Search bar, type "calibrate display" and click on "Calibrate Display Color" when it shows up. Provide your administrator password or confirmation if prompted.
    • Sponsored Links
    • 3 Check to see if the cable connecting the monitor to the computer is loose by lightly jiggling the connector at both points. If it's loose, this could be the cause of the display error. Secure the connection and see if the issue has cleared up.
    • 4 Check the connectors themselves for bent or damaged pins. A damaged pin can cause a faulty connection, which can lead to errors like a pink-tinted screen. If the pins are just bent, you can try to bend them back into place with a pair of needle nose pliers. If they are otherwise damaged or missing, you'll have to replace the cable itself.
    • 5 Perform a factory reset of your monitor if replacing the cable has not repaired the issue. Instructions for a factory reset vary from one model and manufacturer to the next, so consult your owner's guide for detailed instructions.
    • 6 Connect your computer to a different monitor if the problem persists after factory reset. If the problem persists with a new monitor, the issue is likely with your video card. If this is the case, consult the card's manufacturer for detailed diagnosis and assistance. If not, your monitor may be damaged and incapable of rendering a properly colored image. Take it to a repair professional for repair or replace it.
Read more :
May 11, 2014 | Acer V193w LCD Monitor
Yellow screen
There are a variety of problems that can happen to the display monitor of an Acer laptop.
The most common problem is the screen fading or becoming too hard to see.
This can be corrected by adjusting the brightness levels.
Another common problem involves incorrect color, which can be resolved by adjusting the display color settings.
Yet another big problem is the display freezing or appearing jumpy, which can be resolved by updating the display driver.
Hold down the "Fn" key.
Tap the right-arrow key to brighten the display screen.
Tap the left-arrow key to darken the display screen.
Release the "Fn" key to save your display settings.
Right-click on the desktop and click "Graphic Properties."
Adjust the screen resolution by clicking "Display Settings" and choosing a resolution setting from the drop-down menu.
Click "Apply" to check the resolution of the display.
Click "OK" to save the resolution settings.
Adjust the color of the screen by clicking "Color Correction" and moving the brightness or contrast slider to the right or left.
Click "Apply" to check the color resolution of the display.
Click "OK" to save the color settings.
Click "OK" to exit the Graphic Properties application.
Update the Display Driver
Right-click on the desktop. Click "Personalize," "Display Settings" and "Advanced Settings."
Click the "Intel Graphics" tab and choose "Monitor Properties."
Click "Driver."
Click "Update Driver" and choose "Search Automatically."
Click "Install" to install the updated monitor driver. After the driver has been installed, click "OK" to restart the laptop when prompted.
Yellow screen
Yellow tinting in monitors can be caused by either a software calibration issue, bad cables or a worn out display and backlight.
Before you assume that the issue is a hardware one, determine if there are software settings that affect the color or if the cables are working correctly.
After checking these items, and if the yellow tint only occurs on one monitor and you cannot eliminate it, the problem is a display hardware issue and it is less expensive to replace the monitor.
Unplug the power cord from the monitor and replace it with another one.
This is a standard power cord used in printers, monitors and desktop PCs so you can trade it for a cable from another device.
Turn on the PC and monitor to see if the yellow is still there.
Turn off the computer and monitor.
Replace the video cable with another VGA cable from another monitor.
Use one from another computer before going out to buy one.
Restart the computer to see if the yellow tint is gone.
Right click any area on the desktop and click "Properties" from the list of options that appears.
Choose "Display Settings," then "Advanced Settings."
Select "Monitor" and click the "Calibrate Color" button.
Wait to see if the yellow tint goes away.
Locate the temperature color settings on the monitor.
Adjust these to see if there is a change in the color.
A warm color setting will give the screen images more of a yellowish tint.
Click on the "Start" icon, then click "Control Panel" and "System and Security" and choose "Device Driver."
Locate the video driver and click "Update."
Select the option allowing Windows to connect to the Internet to find an updated driver.
Wait for the update to complete in a few minutes.
Expect the yellowing issue to disappear.
Connect the PC to another monitor to see if the same problem occurs.
If the yellow tint does not appear on the newly connected monitor, the problem is a bad backlight or display and the monitor should be replaced with a new one.
Jul 21, 2013 | Acer Computers & Internet
@the monitor appearance changed to pink shade and we are not able to see in this colour pl give me a solution to sent it back to normal mode
probably the color setting of the monitor has been changed.
on the monitor panel press the menu button and go to the color option.
see if increasing or decreasing the RED GREEN and BLUE color options sets back the monitor to normal.
usually some monitors have a reset option also, by selecting it everything will get back to normal.
Aug 02, 2011 | Computers & Internet
My monitor screen is pink, both the background & the letters/graphics.
Go to control panel then settings then Display and it will give you options to change it, the color is also changed by buttons on the bottom of your monitor.
Mar 12, 2011 | NEC MultiSync LCD1970GX 19" LCD Monitor
The screen color is off. It looks yellow, pink
Try changing the connecting cable. You seem to be connecting it with a composite cable which might have loose pins.
Sep 15, 2009 | KDS Radius RAD-7 17" Flat Panel LCD...
Screen got yellowish color
Sounds like overstressed video cable, at least that wire for BLUE signal, 'cause when image is yellow - the BLUE color is missing.
Open the monitor and ring coaxial wire in blue insulation.
Sep 11, 2009 | AOC CT720G 17" CRT Monitor
My monitor suddenly altered the colors on the screen; white background now appears slightly pink, green appears black. How can I make adjustment to correct the color?
your monitor is either going bad or your display setting are messed up.use the buttons on the front and mess with color option if that don't work then you need a new monitor
Aug 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Monitor screen turned into pink
A defective monitor cable can cause the monitor to turn pink.
May 13, 2007 | SAMTRON 55V 15" CRT Monitor
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
