Question about Dometic RM2852 Refrigerator
Ref/freezer quit working. looks like somekind of liquid in back leaked out.. fuses ok.is this repairable? motorhome Domestic RM2852
  • 316 Answers
Motorhome refrigerators are a different system entirely than residential style refrigerators. I would do a search for dometic, not domestic, refrigerator repair
Posted on Feb 26, 2010
I have a domestic rm2852 and the freezer freezes but the refrigerator part is warm. I can't get it below 50*
Inside the fridge is a dial to adjust the freezer and fridge temps make sure that is set lower. Also check to make sure the fan in the freezer behind back panel is working, and the vents are not blocked. The video should help with that part.
Jul 05, 2017 | Refrigerators
RM2825 not cooling whats the problem
maybe its your fan or thoes heater in the freezer not defrosting it. if it has coils on the back see if they ware they should be. and if they are underneath cleam them. but see if it builed up with ice in the freezer by removing the pannel in the freezer. hope this help
Feb 07, 2012 | Dometic RM2852 Refrigerator
Refrigerator does not cool properly. Freezer seems to be ok.
I'm Leo
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | Dometic RM2852 Refrigerator
I have a Roper RS22CFXTQ00 side by side. It leaks water in the floor. Water gathers under bottom drawer in freezer then leaks into the floor. I also have a problem with the hose that feeds water to the...
first check for a hole that water should drain tru. it must drain under the ref. into a pan and then it is evaporated by the heat.. u need to go on the back of ref.,. look where water goes into the freezer and that will need to put some putty or soke tape to stop the air leak that is causing your spout to freeze.. try those. ok
Feb 11, 2011 | Roper Refrigerators
We have a Domestic Model RM2852 refrigeratro in camper with auto factory preset thermostat. but it freezes the food. What can we do to set temp. down. Product # 921 1460-57. Serial # 319 05815 Thank...
you have 2 choices #1 is replace the thermostat.#2 is check for air leaks around the door seals,if leaking air,compresor will run on overtime...trying to cool the air inside.
Aug 14, 2010 | Dometic RM2852 Refrigerator
I HAVE A 1997 FLEETWOOD RV WITH ORIGINAL DOMETIC RM2852 REF IN IT. ALL POWER SEAMS TO WORK (LIGHTS ARE ON PLUGED IN OR OFF OF GAS BUT THE WHOLE PROBLEM IS THE REF OR FREEZER WILL NOT GET COLD
Largest problem is with the cooling unit going bad on these unit at about your units age.
But first
check your 12 volt fuses and make sure both the fuses in the back of the refer and the fuse in the power distribution panel are good
Must have 12 volt for the gas to work
Sep 23, 2009 | Dometic RM2852 Refrigerator
Dometic Americana Freezer/Fridge not cooling
The recall has nothing to do with your fridge not working. Your cooling unit has gone bad. And yes you can get a new fridge for a few hundred more than a new cooling unit. And sooner or later PPL motorhomes will run out of their cheap stock. The fridges they have are out of production. I know I am a Dometic dealer.
Jan 11, 2009 | Dometic RM2852 Refrigerator
Refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Nov 11, 2007 | Refrigerators
Dometic RM2852 Refrigerator Logo
285 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
