Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
I have no cd to set it up - D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
  • 4,281 Answers
You can set your router settings without disk too.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
If you need user name and password for connect to your service prtovider then configurayour router as PPPOe .
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Feb 07, 2010
How do I slave a cd-rom drive in a dimension 1100
Most CD or DVD drives installed in modern computers have a group of short jumper pins on the rear of the drive that determine the master or slave setting for the device. The master or slave setting helps to identify the drive when it shares a connector cable inside the computer with another device, such as a hard drive or even another optical drive. Without the master or slave jumper setting, the computer would not be able to tell one device from another or from which drive to retrieve or write data. Configuring a CD drive as master or slave is a relatively simple task that takes only a couple of minutes.
Turn the CD drive so that you view the rear of the unit, then check the position of the jumper covers on the set of pins next to the power adapter plug. If the CD drive will be the only device on the IDE data ribbon cable, set the jumper cover on the two pins farthest away from the power connector. This position is the master drive setting, and, by default, most CD drives ship with this configuration. In most cases, if the CD drive is the only device connected to the cable, you do not need to change the jumper setting. Determine if you need to change the CD drive jumper setting if the device will share a connector cable with a hard drive or another optical drive. If the CD drive will be the primary (master) device on the cable, do not change the jumper setting. If the CD drive will be the secondary (slave) device on the cable, continue to the next step to change the setting. Use a pair of needle-nosed pliers or your fingers to remove the jumper cover from the CD drive if the unit will be the secondary device on the IDE ribbon cable. Set the cover over the pair of pins next the pair from which you removed it, then press it until it completely covers the pins. The jumper is now in the slave setting position.
Mar 02, 2013 | E-Machines T2892 PC Desktop
How do you Reboot a computer back to factory setting
Instructions Things You'll Need:
  • Factory Settings CD
    How To Use the Restore Factory Setting CD
  1. Step 1 Make sure to transfer all of the files you want to keep to a USB memory stick or burn to a CD.
  2. Step 2 Put the "Restore Factory Setting CD" into the CD drive. This CD was packaged with your computer.
  3. Step 3 Confirm you want to restore the factory settings. The computer will begin restoring all settings. Don't disturb your computer, as this process can take several hours. .
  4. Step 4 Reboot the computer to complete the process.
  5. How to Reboot Using the Computer Start-Up
  6. Step 1 Turn on your computer. Right away there will be a black screen. You can restore factory settings without a CD, too. This will reset your BIOS.
  7. Step 2 Press "F1" when the black screen appears to enter the setup configuration mode. You will be presented with a menu.
  8. Step 3 Select "Restore Factory Defaults." That's it. Your computer will do all the work for you. Like the CD, this process may take several hours.
Jan 27, 2010 | Computers & Internet
Can not boot from cd rom...bios boot order is set
Set all in Boot priorty to CDROM
Set Other Boot Device to No.
Jan 07, 2010 | EliteGroup NFORCE 570 SLIT-A Motherboard
My samsung cd-rom sc-148c drive is not working. It is not listed in "My Computer". I have uninstalled and reinstalled it but that does not work.
Is the CD-ROM drive on a separate cable on the second IDE controller on the desktop motherboard? Then the jumper setting can be set to Master or Slave if no other drive is connector to this cable.
If the CD-ROM is also on the first IDE controller and IDE cable as the hard drive then the jumper setting on the CD-ROM must be set to SLAVE because the hard drive would be jumpered as MASTER.
Check the BIOS setting to see if the CD-ROM drive is detected.
If the CD-ROM still does not work after you checked and configured the CD-ROM drive, then is is faulty and needs to be replaced.
Dec 16, 2009 | Samsung SC-148 CD-ROM Drive
How to install win xp in compaq cq40-327tu
You need to ensure bios is set up with boot up from cd first.Then put your xp cd set up disk in the cd drive and restart pc..From there follow the on screen set up and you will be fine..
Aug 26, 2009 | Computers & Internet
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Jun 01, 2009 | Jensen Car Audio & Video
I need to set my computer back to factory settings
You have two options:
1 - Contact HP for the CD set.
2 - Purchase XP or VISTA and install new.
Normally, the CD's are not available as a download.
Dec 29, 2008 | HP Pavilion dv6000z Notebook
Kenwood KDC-X589 seems like the CD player doesn't put out sound
you have to change the cd read setting it might got set to cd read 2 it needs to be cd read 1 in standby mode press menu button scroll through with track button till you see cd read and set it to cd read 1 if not in standby mode try in cd mode same steps
Jul 03, 2008 | Kenwood KDC-X589 CD Player
Nakamichi cd-35z
There is adjustment for bass, mid and treble. Access this by pressing the button to the right of the volume knob. I leave mine set at +1/2, -3, +2 . I also set LOUD on which is done by holding the same button down. With these settings everything sounds pretty spot on, occasionally need to adjust the bass up/down and treble dependant upon the CD.
Mar 09, 2007 | Nakamichi CD-35z CD Changer
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
116 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
