Question about RCA P46921 46" Rear Projection Television
Green glow hi i have a RCA model # P46731at and everything that should be white has a green glow around it...i removed the mirror and all the bulbs seem to be working if i move the adjustment slider on the green bulb the haze moves with it..any ideas
  • jr50hockey Feb 21, 2008
    is this something i should try on my own?
    President:
  • 3,130 Answers
The RCA Set does not use convergence IC's Im afraid. It uses discreet push pull type transistor array just like a low power audio amp. there are 6 NPN and 6 PNP type transistors. they also use preamp to drive these transistors. Then to make life a bit more difficult, RCA uses a separate power supply board for the convergence alone. These should be checked both at the same time. The boards most likely are not available, so you will need to have the boards rebuilt at PTS corp.com, or Tristatemodule.com. Good Luck
Posted on Feb 21, 2008
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s
  • Cary Farah
    Cary Farah Feb 22, 2008
    send the board into PTS corp.com, or Tristatemodule.com
  • Cary Farah
    have to tryed to do convergence on you menu?
How do you get the mirror apart to change the light bulb?
Here are the instructions, basically you remove the screws on each side and then on side will lift off. I used a flat head screw driver to work around seem until it lifted off. Hope this helps.
http://www.conair.com/instruction_booklets/06PM8043%20BE18NX.pdf
Jun 16, 2011 | Conair Chrome Double Sided Lighted Makeup...
Screen blury,very pink,green edging on picture almost colorless!
This would be a convergence issue you can run the convergence setup that is in your user manual if that does not work you are going to need service.
thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 17, 2009 | RCA HD52W56 52" Rear Projection HDTV
Changing oil, in guns RED Green Blue ( algae)
you can get the coolant kit which has the coolant for all three tubes and step by step instructions on how to do the proceedure on the phillips / Magnavox rear projection Tvs.Heres the link shipping is free within the US.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Apr 22, 2009 | Televison & Video
RCA HD52W59
Actually, we didn't remove any bulbs, we removed the lamp in the back of the tv.
Dec 14, 2008 | RCA HD52W59 HDTV Projection Television
RCA TV model # P46731AT
Why is my picture more blue then red bulbs are working on RCA .....P46731AT
Oct 29, 2008 | Televison & Video
Clean the light guns
if i remeber the screen comes out if you remove the border around it just be carful not to bend it too far, but it can bend quit a bit and it should come right out and you can clean the back of it too
Aug 27, 2008 | RCA P46921 46" Rear Projection Television
Extreme White Glowing
Your CRT fluid needs to be replaced. Goto www.TvRepairKits.com and order their fluid kit.
Sep 28, 2007 | Philips 60PP9363 60" Rear Projection...
RCA P46921 46" Rear Projection Television Logo
122 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
