Question about Nikon Coolpix 4500 Digital Camera
I am unable to take pictures or do anything with my camera because I suddenly have this message that my memory card is "write protected". Please let me know how to get this off!
  • jseamon Feb 07, 2010
    Thank you! So easy!
  • Nikon Master
  • 32,281 Answers
The SD memory card that Nikon Coolpix camera use have a small slide switch on the edge of the SD memory card. This slide switch is used to set the SD memory card to Read/Write or Write protect.
Posted on Feb 07, 2010
I was taking pictures with my digital camera and all of a sudden the lcd screen said memory card not readable, need to format card. i selected cancel. the card is full of pictures from a recent vacation. ...
Could you please tell me the type of camera (model) and the type of memory and the computer that you are running? You might need to purchase a memory card reader and plug it into your computer and then eject the memory card from the camera and insert it into the memory card reader. Some computers come with a memory card reader in them. I would try that first.
If you filled the memory card past its capacity, you may have compromised the photos that are on it.
Mar 12, 2011 | Cameras
Receiving "card locked" message and unable to take
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Dec 20, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Unable to turn off the card protection. unable to take pictures with protection on or download pictures
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 07, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
After taking dozens of pics all day my camera all of a sudden won't take a pic, zoom, etc and after a short time it says card reader error.
The memory card may be full. Transfer the pictures from the camera as normal (or directed), and once sure they are on your computer or printed out, delete all the pictures (erase) from the memory card.
Try to take pictures again - if the error is still present (or you are unable to transfer the pictures to the computer) , there may be an issue with the card. You may not be able to use the card anymore - but before discarding, see if it works in another device or "stand alone memory card reader". If it works in either of those devices, there may be a problem with your camera. Try using another memory card to see if you get the same message when trying to take pictures with the new card installed. if you do, it looks more like a camera problem than a memory card problem. Hopefully, it's the memory - and not the camera.
Please rate this reply if helpful - good luck!
Jul 08, 2010 | Samsung SL202 Digital Camera
Message card is locked
Usually, the write protection is on the memory card itself.
You should power off the camera, take out the memory card and move the little switch on it's side to disable the write protection.
Good luck,
Pelu.
Apr 10, 2010 | HP Photosmart 735 Digital Camera
A memory card "write protected"
Get a card reader and download the pics from the card to your computer. Then, format the card in the camera.
Dec 23, 2009 | Cameras
Memory card not read - cant use the camera at all
Use a separate card reader to download your pictures. Then, format the card in the camera.
Aug 26, 2009 | Polaroid T730 Digital Camera
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
Memory card says it write protected
Make sure the SD card lock is 'off' and then use thin, opaque sticky tape (ie non see-through; eg insulation tape) to cover the whole gap but keep clear of the metal contacts at the back.
The mechanical lock switch accidentally moves to the "locked" position during insertion due to the poor quality of the switch.
Jul 21, 2008 | Nikon COOLPIX L3 Digital Camera
Memory
The best way around this problem is to have a card reader installed on your PC.
Using the card reader you can format, delete, copy or whatever just like it was a hard drive attached to the computer.
You can even get a usb card reader so there is no need to install anything into your PC. Check yourlocal PC for either version.
There is however a possibility that the card has been put into write protect mode. Pull the card out and there will normally be a tiny switch. One way is writeable, the other is write protected.
Let me know how you go =)
Apr 11, 2008 | Casio Exilim EX-S600 Digital Camera
Nikon Coolpix 4500 Digital Camera Logo
61 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
