Question about HP ScanJet 3500C Flatbed Scanner
Error while communicating with scanner message
When I klick on scan documents in the HP director I get a message that reads "error communicating with this device
    Guru:
  • 239 Answers
Smile...well this is due to a default setting in windows which u need to change.
1. leave the device plugged to the USB & power it
2. Go to device manager \ expand (+) universal serial bus controllers
3. Right-click \ properties \ usb root hub \Power management tab \ uncheck box (allow the computer to switch off the device)
Restart! Don't forget to vote me dear!
Posted on Feb 07, 2010
I have a hp psc 1410 all in one printer and when i starting to scan a document or a picture ,an error message appears that saying an error occurred communicating with the scaning divise. Please ensure that...
Try this simple step first,
Disconnect the Power cord from the back of printer (while printer is on)
Wait for 10 seconds,
Connect the cord back and wait till it initializes.
Close HP Director or HP Solution Center,
Try to Scan, It should work.
Jul 06, 2010 | HP Office Equipment & Supplies
Scanner does not work when requested from HP Director
Make sure the cable is plugged all the way in to the printer it gets loose for some reason and have had this problem my self many times. I replaced the US plug and mine went away but test the cable first.you can go to WWW.hp.com and support and read the Trouble bullitins for this printer and you will find a white paper or TSB on this.
Sep 28, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP Scanjet 3570c not scanning
Scanning Without HP Hardware
1. Click Start
2. Control Panel
3. Click Scanners and Cameras
4. Click on the Icon and follow the Scanner and Camera Wizard instructions.
5. Select the HP scanning device from the TWAIN source list
6. Click File and then Scan New .
Feb 08, 2009 | HP ScanJet 3570C Flatbed Scanner
Scan problem with HP Officejet J5700: When I press scan the screen shows "No scan options, refer to device documentation for troubleshooting"
This particular error message is in regards with the software of the printer. Its either your printer is not communicating with the computer software for scanning or your firewall is blocking the software. But before we proceed with any troubleshooting steps why don't you check if you have hp solution center or hp director in your computer. If you have any of this two softwares try to scan usig it. If it will have an error message try to send any feedbacks
Nov 28, 2008 | HP Office Equipment & Supplies
Won't scan nor fax
HP multi units are notorious for scanner failures. It is just a weak component in their machines. I have seen this time and time again. The only solution is to change the scanner out or purchase a different machine. Just keep in mind the notoriety HP has which failed scanners. If you want to venture into the replacement of the scanner the following website might have the product you are looking for. Otherwise, search around the net for a scanner assembly unit for the OJ7310. But, be prepared scanner units are not cheap.
Check here first...PrinterFixer.net
Nov 13, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Connection issue between XP Pro and HP C6180 all-in-one
Hi Lynn,
Unfortunately, HP.com doesn't have a very satisfying online solution to your problem. Still, there are a few things you can try.
The first is a general diagnostic check of your scanner. HP provides a doc that takes you through some steps, many of which you probably already tried, to see if it's a simple fix:
An error occurred while communicating with scanning device
The next document is a set of diagnostic steps to address errors trying to scan to a PDF:
An error occurred while trying to scan to a PDF
I don't know if the current situation was created by a fault in the device or some recent change in your configuration settings. I do know you can use the HP Director software installed on your computer to set the scan destination settings:
Settting "Scan To" Destination using HP Director
Those were the most relevant solutions I could find for you. I hope some of this information is helpful. Good luck.
-Trip
Oct 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Scanning
I can use it to print but I cannot scan anything anymore since I updated my internet explorer. My OS is Microsoft XP. I am using a 4-in-one scanner. Thanks a lot.
May 19, 2008 | HP All-in-One Printer
HP ScanJet 3500C Flatbed Scanner Logo
557 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
