My operating system is windows 98, i recently upgraded my memory card from i gigabyte to 2 gigs, but every time i boot my computer there is an error message low in memory, the question is; how can i boot windows 98 w/ 2 gigs of memory card, thanx in advanced
    Guru:
  • 239 Answers
CAUSE:
The Windows 32-bit protected-mode cache driver (Vcache) determines the maximum cache size based on the amount of RAM that is present when Windows starts. Vcache then reserves enough memory addresses to permit it to access a cache of the maximum size so that it can increase the cache to that size if needed. These addresses are allocated in a range of virtual addresses from 0xC0000000 through 0xFFFFFFFF (3 to 4 gigabytes) known as the system arena.
On computers with large amounts of RAM, the maximum cache size can be large enough that Vcache consumes all of the addresses in the system arena, leaving no virtual memory addresses available for other functions such as opening an MS-DOS prompt (creating a new virtual machine).
WHAT CAN U DO?
To work around this problem, use one of the following methods:
  • Use the MaxFileCache setting in the System.ini file to reduce the maximum amount of memory that Vcache uses to 512 megabytes (524,288 KB) or less. For additional information about how to use the MaxFileCache setting, click the article number below to view the article in the Microsoft Knowledge Base: 108079 (http://support.microsoft.com/kb/108079/EN-US/ ) 32-Bit File Access Maximum Cache Size
  • Use the System Configuration utility to limit the amount of memory that Windows uses to 512 megabytes (MB) or less.For additional information about how to use the System Configuration utility, click the article number below to view the article in the Microsoft Knowledge Base: 181966 (http://support.microsoft.com/kb/181966/EN-US/ ) System Configuration Utility Advanced Troubleshooting Settings
  • Reduce the amount of memory that is installed in your computer to 512 MB or less.
Posted on Feb 07, 2010
I have a Acer AX1200-U1510A AM2+ Motherboard and i would like to upgrade the processor, ihave 4 gigs of mem and a 1 gig Gigabyte Gt 610 graphics card. I only have a 240 watt power supply what processo
Should work with a processor of the same socket type. I'd seriously upgrade the psu myself. Personally I'd upgrade the motherboard and processor to a quad core, and get the fastest ram, look at ebuyer.com, you can buy a bundle upgrade package for less than you may think. :)
Sep 04, 2012 | Acer Computers & Internet
Win Me will not Boot after load. Win 98 will not Boot either. Says not enough memory ???? 2 Gig Memory PC3200-GA-8ipe1000-g Gigabyte MB
Try just using 512Mb of memory or less as there was a bug in Me and 9x that produced that error if you had more than 512 Mb of ram.
Jul 18, 2011 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
New pny 4 gig won't work with windows 98. Old 1 gig ones will. Can they be made to work?
Windows 98 does not support Fat 32 4gb Partitions. You can try to partition the card into multiple 1gb partition's but would suggest upgrading the system.
Thanks
Dustin
Jan 12, 2011 | PNY 4GB Secure Digital High Capacity...
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
Wont boot 2 windows xp home when 2 gig memory installed,works with 1 gig,tried both slots with both 1 gig sticks.Screen goes black.
Seems the memory is not comatable with the motherboard. Replace the old memory and visit http://www.crucial.com, they have a scanner tool which will confirm what mem can be installed.
Apr 30, 2009 | Computers & Internet
Upgraded Dell Dimension 3100 memory to 2 Gigs - Windows XP fails
Did you add the two sticks with the 512 or remove the 512 and add the two 1gb sticks? Try booting the machine with ONLY the 1gb sticks in.
Your machine supports 1gb modules but they can't be higher than 533MHz. Check that the memory you purchased was either PC3200 (400MHz) or PC4200 (533MHz) and is 1.8v. If you post the part number off of one of the modules I can look it up for you.
Feb 22, 2009 | Dell Dimension 3100 PC Desktop
Asus Mobo Will Not Boot After Memory Upgrade
not right ram gotta use samusng low density sum mobo so picky
Jan 20, 2008 | ASUS P4PE-X Motherboard
Problem in install winxp
Your upgrade options
If you want to upgrade your system to Windows XP, the first thing you need to do is verify that it meets the system requirements for the newer operating system.
You will need:
  • Windows 98 or later version of Microsoft Windows operating system.
  • At least a 233Mhz processor. Any manufacturer (AMD, Intel, IBM, VIA, etc.) will do.
  • At least 128MB of system memory.
  • 1.5 Gigabytes of free hard drive space (note that you should have at least 3 gigabytes if you want to do any meaningful work with your system after the upgrade).
  • A CD-Rom or CD/RW drive.
  • Mouse and keyboard (either USB or PS/2).
  • A video adaptor and monitor capable of displaying 800x600 resolution. If you are not sure about this, change the resolution within Windows 98 by right clicking on an empty area of the desktop and selecting 'properties' then going to the 'settings' tab. The resolution slider is at the bottom left. Set it to '800x600' and click 'apply.' If your screen is still legible, you are fine. If the 800x600 option is unavailable, you may need to upgrade your video adaptor before upgrading Windows.
Note that if the screen becomes scrambled, blank or unreadable, you will probably need a new monitor as your current one cannot handle the required resolution. If your system meets the minimum requirements for Windows XP, it's time to find out which version of the operating system you can upgrade to.
This is Microsofts recommendations
Sean
Dec 11, 2007 | NEC PGA370 SIS620 ATX Motherboard...
Windows 98 install
It could be a memory related problem. Try to test your memory module by installing it to a different system that is surely working. If that system restarts, then you must replace the memory module.
Nov 20, 2007 | Microsoft Windows 98 for PC
Dell memory Dimm B errors, 2 gig memory upgrade
Can your laptop support 2 gigs?
Also, are you using the right memory for your laptop?
Nov 15, 2007 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
