Question about Keurig B60 Coffee Maker
Have to lift and reset the water tank each time to have water pulled into system. Any fixes?
  • 3 Answers
No mine is doing the same thing. Keurig said they redesigned water pump recently. It acts like it is vapor locking at times so it does not draw in water. I am returning this model.
Posted on Feb 08, 2010
My hot water to the shower goes cold after 3-4 mins could please help?
a couple of things to check on the side of the hot water system you will see a valve with a small lever
lift that lever until there is a solid stream of water coming from the pipe
that ensures that the heater tank is full
next -if you have a temperature mixer on the hot water pipe out of the tank ( stops scolds in the bath, shower sink) by controlling the temperature mix at the tank
They are known to fail and shut down the hot water supply by adding extra cold water into the system
other than that get a plumber in to fix the fault.
Apr 20, 2015 | Water Water Heaters
How do I remove the plastic shield over the grinder on saecco Vienna
a) Remove the water tank and the coffee bean container cover.
b) Remove the two fixing screws of the coffee bean container.
c) Remove the housing screw under the water tank (Torx/T10).
d) Remove the housing screw under the coffee bean container.
e) Remove the two bottom housing screws . Pull the housing left of the electronic system slightly forwards and lift.
f) Move the upper housing slightly to the left so that the notch of the steam dial is visible on the right side of the machine. Release the steam dial using a sharp object and remove.
g) Remove housing and pull water hose off.
May 02, 2014 | Saeco Vienna Espresso Machine
Have a Duo Flush System from FluidMaster. It continuest to ghost flush. Have adjusted the float valve several times but is still ghost flushes. How can I stop this?
follow this steps and fix it. God bless you
f the toilet bowl overflows, use a plunger or auger to eliminate clogs. If the toilet does not flush, tighten or replace the defective handle , adjust or replace the lift chain , or replace the flush mechanism. Jiggling the handle forces the lift chain or rod to re-seat the flush mechanism, telling you that something is awry.
If the bowl drains sluggishly, remove the clog with a plunger or auger, or raise the water level in the tank .
If water runs continuously through the toilet, lower the water level in the tank , adjust or replace a lift chain or wire , repair or replace a worn flush valve , clean or replace the valve seat assembly .
If water appears under the tank, tighten the tank hold-down bolts , lower the water level in the tank, replace the float valve , replace a malfunctioning ball , or tighten nuts on the water supply line, replace leaking supply line . As a last resort, re-seat the toilet .
If the seat is cracked or unsightly, replace it .
If the bowl or tank is cracked or otherwise unacceptable, replace the entire toilet .
Nov 25, 2013 | Delta Home
My saab 9 5 1.9D engine light on .. water in fuelcode but not having any problems with it..HAd it into Saab norway several times and they gave in without being able to fix it.. saab sweden have had it...
Take it back to Saab shop, have the put it on the lift and loosen the fuel tank drain plug a crack. Water will always lay on the bottom and it can be drained off from the plug on bottom. Otherwise, you have to have a syphon unit in system originally that pulls the water off the bottom. The latter is most likely. Just resetting the light out isn't removing the water. Makes sense Huh? Thing is, someone just isn't doing their job at Saab.
Jul 15, 2017 | Cars & Trucks
I have the Kohler toilet with the top actuator, it flushes fine but won't stop running. If I lift the tank top I'm making the toilet flush again. Can this be fixed or do i have to replace the whole system?
(Problem 1) if you can see the water running in the bowl it's a good chance that the flappers warn. you'll have to look at the angle where the light hits the water. The water will be rippling where the top of the water meets the inside of the bowl edge.
For more info on how a toilet works = http://www.aplumbers.com/residential/toilet
solution 1
1. tank the tank lid off.
2. flush, the rubber thing that comes up and allows the water to go to the bowl is the flapper 3. remove 4. replace that should fix it.
problem 2 it could be the water levels to high.
(solution 2)
1. tank tank lid off.
2. if the waters flowing over the long tube in the center and down then the water level is too high 3. adjust the level either it will have a ball **** or a float in either case a ball **** adjusts by a screw on the fill valve. the float has a either a metal rod w/ a pinch clamp or a plastic long screw type thing. 4. adjust water level . 5. lift the flapper to allow a little water out til fill valve kicks on then release handle til valve stops . 6. just keep re adjusting til you get the water level right there should be a molded in line for the level on the back of the tank.
Nov 14, 2010 | Kohler Acorn Lift-Knob Flush Actuator...
Heater on 1995 Chrysler Concorde stopped heating. Replaced water pump and thermostat. Blows semi warm air out of one dash vent and pure cold out of other dash vent. Does anyone know codes to reset?
there are no reset codes, did you bleed the air out of the cooling system? if not do this procedure, if that doeasn't fix it u have a failed air temperasture control blend door motor actuator.
The generic method of bleeding air from the cooling system is to use a floor jack and raise the front of the car as high as poss, then fill the coolant recovery tank full and run the engine until it just starts to overheat, high end of normal zone on gauge, then shut the engine down and run cold water over the radiator core, this will self bleed the system and the coolant will be pulled from the recovery tank, repeat as necessary, never let the recovery tank run dry or more air will be pulled into the cooling systeml ,
Jan 11, 2010 | 1995 Chrysler Concorde
How do i disengage the dirty water tank from the machine to empty dirty water.
There are two colored levers on the left and right side of the tank, simply pull them outward and then lift the tank off of the machine.
-OR-
There is a handle on the top of the tank, lift that handle straight up unlocking the tank.
Best of Luck
Jun 13, 2009 | Hoover SteamVac F5914-900 SpinScrub...
No Pressure..No heat
Se my solution re no heat on page. pressostate or microswitch fail is easy to fix. many times the water tank is bebt out of shape with time. A twisted tank lift one side and tank is no longer resting on four points. This cause no contact with electrodes inside tank saying = no water = no power allowed. The GROUND must be established! A small piece of alu foil rolled to a ball will help to ground the electrode again. Lift the tank gently and find the two v - shaped contacts for the electrodes. Have also replaced the electronic box once :-( on friends ECM /// olev
Nov 19, 2008 | ECM Giotto Espresso Machine
Keurig B60 Coffee Maker Logo
347 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
