Question about Dryers
How do you remove blower wheel from the motor?
  • Dryers Master
  • 8,220 Answers
Agrevatin ain't it. I bet you are talking about a whirlpool dryer. The rest of them ain't hard to get off. The blower has a squre nut on the back of it, hold that with a wrench and the pulley with a good pair of vice grips. The blower threads are backwards. Righty tighty is righty loosey. On tough birds I do this: I lock down the pulley inside the dryer with vice grips. I go around to the backside and insert a hammer handle in between to fins at the 3 o'clock position and slam downward. Get mean with it I mean. Works for me!!!
Posted on Feb 07, 2010
  • 572 Answers
I grab the motor shaft with wrench and with a 1/2 inch rachet extension. and remenber its reveresed thread
2 Suggested Answers
ned_san_jose
  • 234 Answers
SOURCE: the blower wheel is loose ,how do i get it off
the wheel is a real pain to take off. you actually need to break it off. whenever i change out a motor, i always order a blower wheel. Good luck :)
Posted on Jul 15, 2009
How to change ac blower on a 2001 chevy silverado with the 5.3 liter v8
With Delphi Blower Motor
  1. If equipped, remove the sound insulator panel.
  2. Remove the blower motor insulating cover screws.
  3. Disconnect the electrical connector from the blower motor.
  4. Remove the blower motor insulating cover.
  5. Pull the retaining tab down while turning the blower motor counterclockwise in order to disengage the blower motor from the heater/ventilation module.
  6. Remove the blower motor.
With Visteon Blower Motor
  1. Remove the sound insulator panel.
  2. Disconnect the electrical connector from the blower motor.
  3. Remove the screws from the blower motor.
  4. Remove the blower motor from the HVAC module.
  5. Remove the retainer from the blower motor wheel. Discard the retainer.
  6. Remove the blower motor wheel from the blower motor.
Jul 27, 2014 | 2001 Chevrolet Silverado
How to Replace a Blower Fan in an Excursion
Blower Motor
See pics bellow Removal
  1. Disconnect the electrical connector from the vacuum pump (7.3L diesel engine).
  1. Remove the bolts (7.3L diesel engine).
  1. Disconnect the vacuum hose and remove the vacuum pump and mounting bracket (7.3L diesel engine).
  1. Disconnect the speed control servo connector (5.4L and 6.8L gasoline engines).
  1. Remove the bolts and remove the speed control servo (5.4L and 6.8L gasoline engines).
  1. Disconnect the connector.
  1. Remove the blower motor ventilation tube.
  1. syo%7eus%7een%7efile=ani_caut.gif%7egen%7eref.gif CAUTION: Carefully remove the blower motor so as not to damage the wheel.
    Remove the screws and remove the blower motor.
  1. syo%7eus%7een%7efile=ani_caut.gif%7egen%7eref.gif CAUTION: If the wheel is to be reused, clean the corrosion from the shaft end prior to removing the wheel.
    Remove the wheel from the blower motor.
    1. Remove the push clip.
    1. Remove the wheel from the blower motor
5_7_2012_2_47_23_am.jpg2
5_7_2012_2_48_41_am.jpg3
5_7_2012_2_49_22_am.jpg4
5
6
7
8
9
Installation
  1. Follow the removal procedure in reverse order.
Jan 11, 2012 | 2000 Ford Excursion
How do i change a blower motor in a ford tempo 1992? i have the blower motor lose but the bottom og the glove box bar is in my way. how do i take that out to get the motor out?
Less Air Conditioning
  1. On models equipped with airbag, disarm airbag system as described under MAINTENANCE PROCEDURES/AIRBAG SYSTEM DISARMING.
  2. Disconnect battery ground cable.
  3. Remove screws securing right ventilator control cable to instrument panel.
  4. Remove screw securing right register duct to lower right edge of instrument panel.
  5. Remove glove box and hinge bar from instrument panel.
  6. Pull right register duct from installed position between air inlet duct and right register opening, Fig. 10.
  7. Remove ventilator grille from bottom of ventilator assembly, then screws securing right ventilator assembly to blower housing.
  8. Remove hub clamp spring from blower wheel hub, Fig. 11.
  9. Pull blower wheel from blower shaft, then remove three blower motor flange attaching screws.
  10. Pull blower motor from housing, disconnect electrical connector, then remove motor from vehicle.
  11. Reverse procedure to install.
  12. On models equipped with airbag, rearm airbag system as described under MAINTENANCE PROCEDURES/AIRBAG SYSTEM DISARMING.
With Air Conditioning
  3. Remove glove box door and instrument panel lower reinforcement from instrument panel.
  4. Disconnect blower motor electrical connector, then remove blower motor and mounting plate from evaporator housing.
  5. Rotate motor until mounting plate flats clear edge of glove box opening, then remove motor.
  6. Remove hub clamp wheel spring from blower wheel hub and remove blower wheel from motor shaft.
  7. Reverse procedure to install.
  8. On models equipped with airbag, rearm airbag system as described underMAINTENANCE PROCEDURES/AIRBAG SYSTEM DISARMING.
Dec 18, 2010 | 1992 Ford Tempo
Blower motor repair
Section 12-02A: Heating and Defrosting, Ranger, Explorer 1995 Aerostar/Ranger/Explorer Workshop Manual REMOVAL AND INSTALLATION Blower Motor and Blower Motor Wheel Assembly Removal and Installation
  1. Remove the windshield washer bottle.
  1. Position the speed control servo out of the way (if so equipped), refer to Section 10-03A.
  1. Disconnect the wire harness connector from blower motor by pushing down on the connector tabs and pulling the connector off the blower motor .
    Item Part Number Description 1 18527 Blower Motor 2 19A786 Blower Motor Housing Tube 3 - Heater Case Insulator
    (Part of 19850) 4 19930 Blower Housing 5 - Electrical Connector
    (Part of 19805)
  1. Disconnect the blower motor housing tube (19A786) at the blower motor .
  1. Remove three screws attaching the blower motor to the A/C blower housing (19930) .
  1. Holding blower motor housing tube aside, pull the blower motor from the heater plenum chamber case (18A484) and remove it from the vehicle.
  1. Remove the blower wheel hub pushnut and, if applicable, the clamp from the shaft. Then, pull the blower motor wheel (18504) from the shaft. For installation, follow removal steps in reverse order. Check system for proper operation. NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
Nov 16, 2010 | 1995 Ford Explorer
Need to replace heater blower motor. How do I get to it?
Behind the glove box. Please see my tip at http://www.fixya.com/cars/r6234839-doesn_t_heater_or_air_conditioner_blow . These are generic instructions. If you get stuck, please get back to me.
See instructions from autozone.com below.
REMOVAL & INSTALLATION
See Figures 1, 2 and 3
  1. Disconnect the negative battery cable.
  2. Remove the glove compartment door and glove compartment.
  3. Disconnect the blower motor wires from the blower motor resistor.
Fig. Fig. 1: Disconnect the blower motor wires from the blower motor resistor-1988 Escort
  1. Loosen the instrument panel at the lower right-hand side prior to removing the motor through the glove compartment opening.
  2. Remove the blower motor and mounting plate from the evaporator case.
  3. Rotate the motor until the mounting plate flat clears the edge of the glove compartment opening and remove the motor.
  4. Remove the hub clamp spring from the blower wheel hub. Then remove the blower wheel from the motor shaft.
Fig. Fig. 2: Unbolt the mounting plate from the case
Fig. Fig. 3: The motor can now be removed from the case
To install:
  1. If removed, assemble the blower wheel to the motor shaft and install the hub clamp.
  2. Install the motor and blower wheel assembly.
  3. Secure the instrument panel at the lower right-hand side.
  4. Connect the blower motor wires at the blower motor resistor.
  5. Install the glove compartment door and the glove compartment.
  6. Connect the negative battery cable.
  7. Check the system for proper operation.
Without Air Conditioning
  2. Remove the air inlet duct assembly.
  3. Remove the hub clamp spring from the blower wheel hub. Pull the blower wheel from the blower motor shaft.
  4. Remove the blower motor flange attaching screws located inside the blower housing.
  5. Pull the blower motor out from the blower housing (heater case) and disconnect the blower motor wires from the motor.
To install:
  1. Connect the wires to the blower motor and position the motor in the blower housing.
  2. Install the blower motor attaching screws.
  3. Position the blower wheel on the motor shaft and install the hub clamp spring.
  4. Install the air inlet duct assembly and the right ventilator assembly.
  5. Connect negative battery cable.
  6. Check the system for proper operation.
Nov 05, 2010 | 1989 Ford Escort
Cannot find heater blower in 1999 ford taurus
It's hiding deep behind the right side dash. See instructions from autozone.com below.
1997-99 Models
  2. Disengage the instrument panel insulator from the instrument panel.
  3. Detach the wiring connector at the blower motor.
  4. Unsnap the instrument panel upper finish panel from the instrument panel.
  5. On vehicles equipped with autolamp, Detach the electrical connector from the light sensor amplifier.
  6. Unsnap and remove the instrument panel finish end panel from the right side of the instrument panel.
  7. Remove the 3 screws retaining the instrument panel to the upper cowl top panel.
  8. Remove the 2 screws at each right side of the instrument panel.
  9. Remove the 3 screws retaining the blower motor to the evaporator housing.
  10. Pull the instrument panel away from the cowl and remove the blower motor from the A/C evaporator housing.
  11. If required, separate the blower motor wheel from the blower motor by removing the retainer from the blower motor shaft and sliding the blower motor wheel off the blower motor shaft.
To install:
  1. If the blower motor wheel was removed, align the flats on the inside diameter of the wheel hub with the flat surface on the blower motor shaft and slide the blower motor wheel onto the blower motor shaft. Install a new blower motor wheel retainer onto the shaft.
  2. Install the blower motor and wheel assembly into the evaporator housing and firmly tighten the 3 retaining screws.
  3. Reposition the instrument panel and install the 2 screws at each right side of the instrument panel.
  4. Install the 3 screws retaining the instrument panel to the upper cowl top panel.
  5. Install the instrument panel finish end panel to the right side of the instrument panel.
  6. On vehicles equipped with autolamp, Attach the electrical connector to the light sensor amplifier.
  7. Snap the instrument panel upper finish panel to the instrument panel.
  8. Attach the wiring connector at the blower motor.
  9. Engage the instrument panel insulator to the instrument panel.
  10. Connect the negative battery cable. Check for proper blower motor operation.
Nov 01, 2010 | 1999 Ford Taurus
How to replace a blower motor in a 1996 ford thunderbird lx
Removal
  1. Remove the glove compartment liner to gain access to the heater blower motor and blower motor wheel assembly mounting screws.
  1. Use a small screwdriver to remove clip retaining hydraulic damper strut.
  1. Remove four screws and remove the heater blower motor assembly and blower motor wheel assembly from the heater blower motor housing.
Installation
  1. Using a new seal, position the heater blower motor and blower motor wheel assembly to the heater blower motor housing with the flat side of the flange near the heater blower motor switch resistor (18591). Install the four retaining screws.
  1. Tape the heater blower motor power lead to the air inlet duct to keep the wire away from the blower outlet during installation.
  1. Install the heater blower motor and blower motor wheel assembly in the vehicle.
  1. Install the glove compartment liner.
Oct 07, 2010 | 1996 Ford Thunderbird LX
How do I replace the ac/heater blower moter?
Hope this helps....please don't forget to rate...thank you:
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection.
  3. Disengage the wire harness connectors from the retainer.
  4. Disconnect the blower motor electrical connector.
  5. Remove the motor cooling hose.
  6. Remove the screws and remove the blower motor.
    NOTE
    Prior to removing a wheel that is to be reused, clean any corrosion from the blower motor shaft to prevent damage to the wheel mounting shaft.
  7. Remove the wheel from the blower motor as follows:
    • Remove the push clip.
    • Remove the wheel from the blower motor.
Blower motor cooling hose
Blower motor mounting plate
To install:
  1. Install or connect the following:
    • Wheel to the blower motor, if removed.
    • Blower motor and securely tighten the screws.
    • Motor cooling hose
    • Blower motor electrical connector
    • Wire harness retainers
Sep 15, 2010 | 2005 Mercury Grand Marquis
How do i get to heater blower motor it roars
Blower Motor — Plenum Removal
  1. Access the blower motor.
Remove the screws
  1. Remove the wheel.
    • Remove the gasket.
Hopes this helps.. Cobra
Jun 12, 2010 | 2001 Ford Windstar
How to install a front blower motor in a 96 ford explorer
Blower Motor - REMOVAL & INSTALLATION
(see Figures 1 and 2)
Fig. 1: Exploded view of the blower motor mounting
Fig. 2: Exploded view of the blower motor and wheel (fan) assembly
  2. Remove the air cleaner or air inlet duct, as necessary.
  3. If necessary, Remove the speed control module and the washer fluid reservoir.
Fig. 3: To remove the blower motor, first disconnect the electrical wire harness plug...
Fig. 4: ...then remove the blower motor cooling tube from the motor
  1. Disconnect the wire harness connector from the blower motor by pushing down on the connector tabs and pulling the connector off of the motor.
  2. Disconnect the blower motor cooling tube at the blower motor.
Fig. 5: Remove the blower motor attaching screws and the washer fluid reservoir...
Fig. 6: ...then slide the blower motor from the housing. Take care to not damage the blower wheel (arrow)
  1. Remove the 2 screws attaching the blower motor and wheel to the heater blower assembly.
  2. Holding the cooling tube aside, pull the blower motor and wheel from the heater blower assembly and remove it from the vehicle.
  3. Remove the blower wheel push-nut and/or clamp from the motor shaft and pull the blower wheel from the motor shaft.
To install:
  1. Install the blower wheel on the blower motor shaft.
  2. Install the hub clamp and/or push-nut.
  3. Holding the cooling tube aside, position the blower motor and wheel on the heater blower assembly and install the 2 attaching screws.
  4. Connect the blower motor cooling tube and the wire harness connector.
  5. Install the vacuum reservoir on the hoses with the 1 screws.
  6. If removed, install the speed control module and the washer fluid reservoir.
  7. Install the air cleaner or air inlet duct, as necessary.
  8. Connect the negative battery cable and check the system for proper operation.
  2. In the engine compartment, disconnect the wire harness from the motor by pushing down on the tab while pulling the connection off at the motor.
  3. Remove the air cleaner or air inlet duct, as necessary.
  4. If necessary, remove the solenoid box cover retaining bolts and the solenoid box cover.
  5. Disconnect the blower motor cooling tube from the blower motor.
  6. Remove the blower motor mounting plate attaching screws and remove the motor and wheel assembly from the evaporator assembly blower motor housing.
  7. Remove the blower motor hub clamp from the motor shaft and pull the blower wheel from the shaft.
To install:
  1. Install the blower motor wheel on the blower motor shaft and install a new hub clamp.
  2. Install a new motor mounting seal on the blower housing before installing the blower motor.
  3. Position the blower motor and wheel assembly in the blower housing and install the attaching screws.
  4. Connect the blower motor cooling tube.
  5. Connect the electrical wire harness hard shell connector to the blower motor by pushing into place.
  6. If removed, position the solenoid box cover into place and install the 2 retaining screws.
  8. Connect the negative battery cable and check the blower motor in all speeds for proper operation.
Hope this help (remember comment and rated this).
Apr 23, 2010 | 1996 Ford Explorer
Dryers Logo
97 people viewed this question
Top Dryers Experts
