Question about Whirlpool Refrigerators
Water drips out of the water dispenser steadily
  • 572 Answers
Ur valve might be going bad
Posted on Feb 07, 2010
Water dispenser drips sometimes after filling a cup with water. Does not happen every time. If not addressed, the drip continues indefinitely. To stop the drip, I use my index finger to give a good poke...
When water leaks from the dispenser like this it will be caused by a defective water control valve that will not shut properly when off. The leaking water is the same as a leaking faucet. The KSCS25IN uses a=> W10247725-Water Control Valve or HERE
Sea Breeze
Sep 24, 2013 | KitchenAid KSCS25IN Side by Side...
Very slow drip from water dispenser. How do I fix
Good day,
A slow continues drip, but still dispenses O.K. is caused by the dual water valve on the bottom rear of the machine not closing completely.
Only fix is replacing the water valve assembly.
Mar 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a leaky spigot what can I do
If the spigot means the end of the water tube in the water dispenser, and it steadily drips even if the dispenser is not used for 10 minutes or so - replace the water valve. If the dispenser drips water mostly wright after you used it - you might have some air bubbles in the refrigerator water tubing.
Oct 17, 2009 | GALAXY Microsystems 25.4 cu. ft....
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Kenmore refrigerator Model No. 106.56839600 water dispenser
Hi
The water is kept cool in reservoir in the fridg. Remove the inlet tube push for water check pressure better worse? Work your way back to valve
good luck
Apr 12, 2017 | Kenmore 21.7 cu. ft. Side-by-Side...
Hotpoint Superba side by side 2169955 water dripping out of dispenser
hi there,
sounds like you may have something broken on the icemaker case itself.
if the water is leaking down the front, it could be the front casing.
if the water is leaking inside the door, it's something a bit bigger.
i would recommend a technician to come and take a look.
Jun 04, 2008 | KitchenAid (KSRD22FKST) Side by Side...
The Water dispenser is leaking water
It's either a bad water valve or the switch in the dispenser is stuck.
Oct 19, 2007 | KitchenAid KSRG22FK Side by Side...
Water Dispenser Drips
Had the same problem after replacing over seven water valves and installing a water regulator in the water line to the refrigerator with no help. Had to reduce the water pressure to about 27 pounds the reduce most of the drips. It drips an amount about the size of a quarter and when the water gets the coldest it stops the drip, but there is always a droplet at the end of the water disperser tube.
The problem is with water stored in the refrigerator side of the box. Water come in and does not leak. After the water gets colder it expands and oozes drips from the water dispenser. It is worse with the roll of tubing behind the crisper drawer on the bottom, because there is no room for expansion in the tubing. We replaced the tubing with and older style tank and it helped some, but not completely. The solution is 1. Try to buy a refrigerator with a tank instead of the roll of tubing in the bottom of the refrigerator side. 2. Don't use the water dispenser. 3. Reroute the tubing directly to the water dispenser and bypass going into the refrigerator, the water will not be as cold. 4. Avoid those built by Whirlpool.
Oct 04, 2007 | Hotpoint HSS25GFP Side by Side...
Water dripping from the water dispenser on freezer
If the water is dripping from the dispenser tube, you need a water valve. The valve is not shutting off completely. Check to make sure water is not dripping from ice chute. If the chute door doesn't seal off you will get moisture there and it will also frost up the ice chute.
Sep 30, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser dripping
Your house valve may not be totally closed (bad seal or something) letting a small bit of water through. Disconnect the line to the fridge completely (in the back) to be sure. That way even if the fridge solenoid valve is bad AND the house valve is bad you won't get dripping. If you know the valve is good, there are times when the water filter will have air trapped in it letting the water in the line drip out slowly until it's finally empty. Pull any filters you have also.
Feb 16, 2007 | Kenmore 53582 / 53584 Side by Side...
Refrigerators Logo
67 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
