Washer won't spin or drain
My Kenmore front load washing machine won't spin or drain. Are they connected problems? What do I do to fix them?
I checked the drain and pump. There is no clog what is next?
  • Washing Mach... Master
  • 8,220 Answers
Lid Switch/suds detect
Top 10 frontload washer problems
1)Water fill problem: water took more than 10 minutes to fill to desired level sometimes indicated as a LF/IE or long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
2)Excessive vibration: noisey,roar, knocking noises. Bad damper,bearing or broken trunion. no error code
3)Dispenser drawer open/detergent in wrong compartment: washer will not operate with drawer open or cleaning products in wrong compartment.
4)Washer won't drain: clogged pump/filter, slow or clogged drain usually indicated as a LD/DE, if a code is given (long drain/drain error) Clear pump of objects
5)Drum overfilled: usually caused by sediment in the water level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
6)Door open, Door not latched, clothes/objects keeping door from completly closing. Tighten door latch, add washers if nessesary to make good contact and close door tighter in case of leaks.Note some models send a sig nal to the motor and another to the control letting both know the door is secure before proceeding, corrosion gets into the lid lock and the door can be locked and the control is ready but the motor ain't getting the message.
7)Cold water does not enter washer: hoses connected backwards. Oops.
8)Oversudsing: Wrong Detergent, too much detergent, detergent in wrong dispensing drawer, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. On some models a suds detect is determined by the motor over amping, most machines will try a few mini loads to correct the problem. Remove detergent, retry
9)Locked motor: error LE,loose connection,broken wire/hallsensor, motor overheated/failed.
10)Water heating error, hE, the thermister/heater is out.
Posted on Feb 07, 2010
Washing machine won't spin, drain, or wash
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 22, 2011 | Kenmore Washing Machines
Water will not drain out of the washing machine and won't complete cycle.
heatman101
Sep 10, 2011 | Kenmore Washing Machines
Machine won't spin, therefore water cannont be emptied. The agitator works. I have a top open Kenmore 90 series machine.
heatman101
Aug 14, 2011 | Kenmore Washing Machines
Why won't my washing machine spin?
heatman101
Aug 13, 2011 | Kenmore Washing Machines
Washer will wash but won't spin or drain
heatman101
Aug 11, 2011 | Kenmore 22422 Top Load Washer
The water in my front-loaded kenmore-he washer is not draining and doesn't seem to spin very fast either.
heatman101
Aug 10, 2011 | Kenmore Front Load Washer
My washer won't spin and drain. what should I do?
heatman101
Aug 09, 2011 | Kenmore Washing Machines
Model no. 23832, won't spin, lid switch is good and so is motor coupler. HELP
heatman101
Aug 09, 2011 | Kenmore 2383x
My Kenmore washer 20432990 will fill and agitate but won't drain or spin. When I push down on the lid switch I hear nothing but when I let it go I hear a faint click.
heatman101
Jun 15, 2011 | Kenmore Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
