Question about Lexmark Office Equipment & Supplies
Lexmark6100 roller fails to feed paper.I keep cleaning but it work for a bit but then fails to feed again.
    President:
  • Lexmark Master
  • 990 Answers
Hello sir; I strongly recomand have to use " rubber rejuvenator " to clean rebber roller 95% it work, try it !
Posted on Feb 07, 2010
Media missfeed
First what model? Second miss feed and jam are different, miss feed the roller can grab the paper, replace the roller putting a rubber sleave is going to mess with the feed system. Clean the rollers with alcohol
Apr 01, 2015 | Minolta Office Equipment & Supplies
My Lexmark C510 keeps popping up with a Paper Jam 241 error in Tray 1. There is no paper jam. I open the printer door take the tray out, put it back in and shut the door. How can I fix this problem? I...
I have a Lexmark C510 colour printer: Manufacture date June 2005.
I had been getting the "Paper Jam 241 error in Tray 1" message for some time. Sometimes it would print just fine but in the past several months, it's been bad. I'd pull the tray out (notice roller marks on the top sheet that was only partially fed), reinserted the sheet properly into the tray and try again and again. The techy at Lexmark mentioned that I could purchase a new rubber roller that feeds the sheet but that I might first wipe down the roller myself as they get worn and old. I first wiped it down with a damp cloth to clean it then thought to try reconditioning it with leather conditioner we'd purchased for our couch (I'm sure Amourall would work just as well). Voila, the old, dry roller was picking up paper again. Just open the rear door and that grey roller (it's black again when you recondition it) is at the bottom. Hope that helps.
May 11, 2010 | Lexmark C510 Laser Printer
Won't feed paper to printer
Its printer feed roller problem. Roller needs cleaning . Clean all the roller using cotton moist with cleaning liquid eg. Petrol , Spirit or even Nail polish remover. Clean all rollers properly . It will resolve your issue.
Sep 03, 2009 | Canon PIXMA MP470 All-in-One Printer
I keep getting intermittent paper jams in the back. Not every time, just occasionally. Nothing can be stuck or jammed because I keep getting good copies too.
if you have used the fax a lot or have used a cheaper quality paper the rubber feed rollers are slipping.
Open the unit up and use a bit of isopropyl alcohol on a paper towl and rub or clean the roller. Let dry and close it up again. That usually will clean enough to make it work again. If not the roller may need to be replaced.
Jul 22, 2009 | Brother IntelliFAX 2920 Plain Paper Laser...
Printer won't pick up the paper in the tray to print. Keep getting out of paper message
First check if the feed rollers are 'Slick" with paper dust, if they are ,clean then with 409 on a cloth rag, and scrub till u dont see the white paper dust on the rollers, let the rollers dry, then reset the printer, by turning it off. then turn it back on ,reinstall the paper and begin printing again.
Jul 15, 2009 | Office Equipment & Supplies
Paper feed not working properly
1. first check to see if there is any bits and pieces of paper in any place in the paper carriage -- look very carefully in front access and rear access
2. if this is not the problem, then disconnect printer from computer -- turn off printer, unplug power cord, unplug printer cable from printer
3. gain access to paper roller assembly, usually in rear
4. using lint free cloth, dampened with distilled water clean rollers -- read manual to determine direction of rotation (usually clockwise)
5. keep rotating rollers until all is wiped clean of paper dust
6. reassumble and try a test print as your printer manual directs
Apr 22, 2009 | Office Equipment & Supplies
5300 won't load 8 1/2x 11 photo-weight paper.
''grabber'' roller out of work sometimes, you may try
1) there is a input paper sensor around roller, the roller out of runing if the sensor is not senitive enough or sensor switch dirty,
clean the sensor as you can find it,
2) Lighter-weight paper feeds and prints fine, which means this paper input sensor works ok, but you need to make sure they are same paper input sensor,.
3) the paper surface bright and the roller worn could be cause paper feed fail, you need clean the roller anyway. still not fixed, you need to adjust the roller pressure by increase the spring force.`
Feb 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Pagepro 1350 will not feed paper
I have the same printer and had the same problem.
Cleaned takeup roller wit isopropyl and it has worked now for 18 months. If you dont use it often, remove top sheet from stack and blow the dust off it before printing.
Nov 14, 2008 | Konica Minolta PagePro 1350W Laser Printer
XEROX 8200 PAPER JAMMING
SOund more to me like you have worn out feed wheels. They are slipping when trying to feed, therefore you get a paper jam indication, but no paper has been fed. Check the feed roller texture. If it is slick replace the roller.
I will state that first. You could have a sticking sensor, but that is less likely if you say it feeds paper.
The second most likely problem is the paper feed or paper registration clutch failing. Those are electromechanical clutches that are located on the loerf front section of the frame. You would need to remove the left side cover ( looking from the front). The clutches are round and silver, about an inch and a half thick with black gears on them. If the clutch faces are slipping, the rolllers will not drive and result in a jam.
The more I think about what your describing, the more I believe one of your clutches is bad.
Sep 26, 2008 | Xerox Phaser 8200 Laser Printer
Will not feed paper ,keeps jamming paper
99 times out of 100 this problem is due to a dirty "paper kicker". The material they use is not a very good grade and it picks up dust and paper debris very quickly. Fortunately, it is very easy to clean.
Remove all paper from the feed tray. Open the front door and remove the toner cartridge and the envelope/bypass feeder tray. Look inside the paper feed housing - at the back - dead center. You will see a black roller-type mechanism that looks like it's made of a hard rubber material. This is the thing that needs to be cleaned.
Take a non-paper cloth (no paper towels, tissues, cotton balls, etc.) and dampen it with an extremely diluted cleaner (dish soap works great, just don't use anything with alcohol in it). Mix a little bit of the cleaner with a lot of water, then dampen the cloth. Another thing that works great for this is a pre-moistened cleaning cloth (e.g. Lysol wipes, Clorox wipes, etc.).
Reach back in the housing and wipe down the black roller mechanism a few times. You don't need to scrub it harshly, just use firm pressure to get a good rub down. Rinse your cloth thoroughly with water, squeeze out the excess, and wipe down the roller again to remove any residual cleaner. Now use another dry cloth to remove any excess water.
That should do it. Put the feed tray and toner cartridge back in the unit, load it with paper, and start printing again. Periodic cleaning of the pickup roller should keep your printing working well.
May 01, 2008 | Office Equipment & Supplies
43 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
