Kenwood KDC-319 CD Player Logo
Posted on Feb 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Doesn't eject CD! and im unsure how to wire up the two RCA outputs that are lable SUB. and the other lable CENTER! do i really fire up my two 12'' subs, just off one RCA jack? and if so do i run two 6'' CENTER speakers the same?
electronic & computer repair& servicre
Level 3:
  • Master 12,061 Answers
  • Posted on Feb 07, 2010
Master
Level 3:
Answers
12061
Questions
0
Helped
4007923
Points
36390
I think you will find that those outputs, SUB, CENTER, must go into an Amp that in turn you plug into, unless they are the ones with inbuilt amps. This depends on the output from your unit though. As to whether it would drive them or not.
1 Related Answer
Anonymous
  • 306 Answers
SOURCE: 6 output RCA. 1 lable
yes the sub out on this radio is mono. but to feed you amp will require two rcsa so get a y adaptor to feed both inputs on the amp.
3answers
Why is rear stock subwoofer not working?
I need to have more info about how you installed it, did you use rca wires from the radio to the amp.? Make sure the sub setting on radio is turned on. Make sure rca wire are in the input connection and not output, also check you connection from radio that they're in rite place. I really need more info about the map of your wireing
Im trying to hook up a paradigm pdr-12 to my tv and xbox 360 and need an idea of how to do this the right way so it only plays the bass and nothing else
Hello there this subwoofer has a built in crossover variable from 50hz to 150hz which means that any signal you feed it the sub it will ignore anything but bass anyway.
As for the connection it is made quite difficult if you don't already have an amplifier powering your other speakers, usually home cinema amplifiers have a low level pre out for subwoofers, for which you would just need a phono to phono cable.
However if it doesn't and you have any type of amplifier with at least 2 separate left and right speakers you can connect the wires from these into the subwoofer and it will output the bass from these 2 channels.
Another option is to use a mono to stereo (2 to 1) phono cable where the 2 connectors at one end connect to a tape or record output on your amplifier and the single phono at the other connects to the subwoofer, the same would go if you have a red & white phono (RCA) output on your TV you could also use this to power the sub, in the worst case scenario you could use a single to single phono or rca cable to connect one of the output channels (left or right) on your TV to the subwoofer however this would mean that the subwoofer would only output bass from either the left or right channel.
Hope this helps
Kind Regards
Ant
I spliced my blue amplifier wire to the corrisponding wire of the Nesa player and to my best knowledge the sub is properly attached to the battery and grounded in the trunk but I am unsure where to plugin...
use the one that is labeled sub and if not available use the rear output and if neither is available then use the front out and be sure the rca on the amp side is connected to the input of the amp
2helpful
How to hook up protron pds-2315
First of all, the PDS-2315 is not a DVR (this question is incorrectly categorized), it is a home theater system. Also, this system is not a receiver -- it is a DVD player (DVD/CD/HDCD/CD-R/CD-RW/Kodak PCD Playback) with a "full function" Karaoke feature with two microphone inputs. If you haven't figured out how to set it up in the past 11 months, this is how you do it.
1. Connect the supplied RCA cables (labled FR, FL, SR, SL, Cen, and SW) to the corresponding RCA connections in the back of the DVD player and the back of the Sub-Woofer.
2. Connect the DVD Player to your television.
A. Video:
There are several options here depending on your available Television inputs: Coax Cable, Component (yellow jack), S-Video and Composite (composite providing the best video resolution and coax the poorest). HDMI is not available. Use s-video or composite if you can. You will note that the composite RCA jacks are colored Orange, Blue, and Green. In a pinch, any RCA Cables will work - just don't cross the color codes between the DVD Player and the television. If you need to use coax you will need a coax to RCA adapter. If your television only has a component jack (yellow), it's a simple connection between the two.
B. Audio:
On the back of the DVD player you'll find two RCA jacks labled "Main R" and "Main L". These will be connected to your Audio Out connections on the back of your television. If you don't have Audio Out RCA jacks on the back of your television, but have an earphone jack, you can purchase an RCA adaptor to make that connection. With rear audio out jacks, you should have an option in your television's audio setup menu to select those outputs. (DO NOT CONFUSE "AUDIO OUT" WITH "AUDIO INPUT" because the will look identical.) If you don't have either of these connections, you will not be able to use the system to listen to television signals.
3. Connect the speakers. Each of the speakers is labled with their position (FR, FL, CEN, SR, SL). The speaker wires are color coded to the spring connectors in the rear of the sub-woofer/amplifier. Press the spring lever and place the wire into the opening. For proper biasing, place the color coded wire into the colored spring connector and the other wire into the black connector for the specified speaker. Connecting the speakers should be very easy. If the ends of the speaker wires become damaged, simply strip the wires back half an inch and connect as above. Place the speakers as specified by their position lables (FL, CEN, FR in front of the television and SL and SR to the right and left of the seating.)
4. Plug it in and power on. You'll need to plug in both the DVD player and the sub-woofer. Press the power button, hit the open/close button on either the DVD player or the remote control and put a disc in the machine. If you don't have a picture or a "Protron" title screen, hit the "P-SCAN" button on the remote (top left corner below the "STANDBY" button).
5. Hit the "SETUP" key and enter your system's information and you're done. Your system will work just like any other DVD player with theatre quality sound. --With the added feature of functioning as a Karaoke machine! Just add proper Karaoke CDs, a couple microphones, a bunch of friends and copius amounts of alcohol . . .
1helpful
DXZ545MP rcas to sub amp
Blue white is remote to amp.... Grey and black are your RCA out to amp...
Powered subwoofer wiring
Red = 12v power Always
Black = Ground Allways
Blue = memory wire that has to run to a Amplifiers Memory Terminal
2x White, seems to be the dimmer and Ant, but im unsure as of these two,
Rca's will go into the AUDIO out of the cd player RED and White holes, that will go to your amplifier.
Im unsure if your talking about a Cd player here, but it seems this it is. If so you should have color coded wires for speakers also (ex- green, green with white stripe, Yellow, yellow with white stripe )
Please provide more information if this dosent solve your problem
Thank you
How connect amplifire ??
You hook the amp up to the deck with rca cables red and white. you have output rca on the back of the deck also the blue wire labled remote also goes to the amp to turn it on and off.
Jensen Amp and Sub
If you followed the instructions correctly, then the amp must be defective. This is sort of simple.
My generic suggestions:
You have the power, the ground, the outputs to the speakers, and then the input.
Make sure that none of the speaker wires are somehow being grounded. Make sure that nothing is shorted that feeds the speakers.
Jerry G.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
