Question about LG LFX25960 Bottom Freezer French Door Refrigerator
LG display error code FF IF
This error code shows up whenever my icemaker is turned on. If I turn it off, it goes off, but then, of course, I have no ice.
  • 311 Answers
The FF error code is the freezer fan motor error. It could be a problem with your freezer fan motor or an issue with the control board not sending proper power to the board. If you remove the back panel you can check to make sure there is no ice restricting the fan motor from turning. If there is ice then check the icemaker fill tube and make sure its in place properly and not leaking down on the evap fan blade.
Hope this helps _MJ_
Posted on Feb 07, 2010
Is it OK for ice thickener sensor touch water on ice maker
Yes, it has to touch the water. As the ice builds up the thickness sensor moves up and turns of the refrigeration and turns the heater on.
  • How Icemakers Work ' HowStuffWorks home.howstuffworks.com/icemaker.htm How Icemakers Work. ... we'll look at the cycle an icemaker goes through to make ice. ... Get the best of HowStuffWorks by email. Keep up to date on:
  • How Does The Ice Maker On A Refrigerator Work ... - YouTube www.youtube.com/watch?v=x4YDWUK0jv8
    • BY REPAIRCLINIC.COM
    • 4 MIN
    • 347K VIEWS
    2012-05-15 · Video embedded · This video provides information on how a refrigerator icemaker works and offers troubleshooting tips ... How Does a Refrigerator Water and Ice Dispenser Work?
  • How Ice makers Work - ApplianceAssistant.com applianceassistant.com/.../Ice-Makers/How-Ice-Makers-Work.php How Ice Makers Work! Learn How Ice Makers Work, ... How Ice makers Work. The Ice Maker Cycle ' Ice Maker Components ' Cube Size Replacement Ice Makers . They Don't Make
  • How Does an Ice Maker Work? - Reviewed.com Refrigerators refrigerators.reviewed.com/features/how-does-an-ice-maker-work Here's how your ice maker works. BACK TO . Best Right Now; How To s; Award Winners; How We Test; ... How Does an Ice Maker Work? It's more complicated than ...
  • Refrigerator Icemaker Repair How It Works
    May 12, 2016 | Refrigerators
    Uline Echelon Ice Maker P1 error code
    P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
    Jan 17, 2014 | U-Line Icemaker
    Ice maker leaks or runs over Causing big chunks of ice in the drawer
    It's very possible that the water inlet valve isn't cutting off completely. I had that to happen on mine.
    Mar 17, 2010 | Amana ATB1832AR Top Freezer Refrigerator
    I keep getting an error code( Er IF) on my kenmore refrigerator(#79578412800) . So far if I turn off the icemaker for a day or two the error will go away and I can turn the icemaker back on it will work...
    I have the same problem as JJ1764... I keep getting the same error code ER IF and all the ice melted and water was everywhere... If I turn off the fridge and then turn again it clears for a few minutes but then goes back to the same thing...Why is this happening?
    Feb 20, 2010 | Kenmore Refrigerators
    ICE MAKER BLINKING ON/OFF. TURN IT OFF & BACK
    Icemaker is jamming. Stripper may be bent where the ejector hangs up advise replacing icemaker
    Feb 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    The icemaker leaks water from the fill tube into the fridge
    my suggestion is to start from the beginning! shut down the fridge for a couple of days store food somewhere else (obviously and see if you get much water at bottom. have mos and bucket nearby. blow into any hoses that are accessible. unplug fridge of course.
    Mar 18, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
    Error code IF or 1F not making ice model #795,77562... Sears/LG
    You posted under an incorrect model number, so can only give general info. IF is a code for ice room fan. It is a fan located in a plastic box in the upper left hand corner of the freezer. The IF code shows up if the control board does not get a feedback signal from the fan telling the control board that the fan is running. I'd check to see if there is some ice blocking the fan blade. If that is not the case, you will need a meter to do further diagnostics to find out if your problem is with the fan motor or the control board. (note: when you turn the icemaker off, the fan will no longer blow cold air into the ice room, and all the ice will melt. Also, when the icemaker bin is full, the same basic thing can happen. Steady use of ice or dumping the bin will prevent ice from melting in bin.) The fan runs on 12 to 16 volts DC (variable speed), and the feed back signal is about 4.5 volts DC.
    Jan 11, 2009 | LG LRFD21855 Stainless Steel French Door...
    Ice maker
    your plastic water tube coming in to the icemaker is probably frozen needs to be taken out and remove ice not letting water come in to icemaker I have run on this alot in the field.This seems to happen [alot] when you turn off the water to the icemaker
    Sep 14, 2008 | Kenmore 53642 / 53644 Side by Side...
    Ice Maker not Getting Water
    There are two solenoid-operated water valves - one for the water dispenser and one for the icemaker. They're located near the water connection at the back of the fridge. There is no pump; the water pressure sends water to the icemaker whenever this valve is opened by the icemaker controls. Your symptoms sound like the coil is burned out on the valve. You can check it by disconnecting the wires and checking for coil continuity with an ohmeter. If the coil is open, replace the valve. Both valves might be combined into one assembly, so be sure you test both coils. Of course it's also possible that the trouble is in the icemaker itself, but a failed intake valve is more likely.
    Jul 15, 2008 | Kenmore 53642 / 53644 Side by Side...
    LFX 25950TT problem
    Just had this same problem. We were away at Disney for four days - turned the icemaker off before we left. We have the LG french door double drawer freezer model. Came home, the ER IF code was displayed. Wouldn't dispense water or ice. Took the icebox out, and it was all frozen in the augers. Then I read on the door something to this effect - "if you turn off the icemaker, it will not continue to cool the ice. This will cause the ice to melt and leak out of the unit, and when it refreezes, the dispenser will not produce ice or water."
    So, I took the ice box out, emptied it, reinstalled it, and the unit os making ice and dispensing water as I write.
    Again, if you turn off the icemake, empty the ice box, or you will get the error message when you start the ice maker again.
    Apr 08, 2008 | LG Refrigerators
    LG LFX25960 Bottom Freezer French Door Refrigerator Logo
    618 people viewed this question
    Top LG Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Mike
    Mike
    Are you a LG Refrigerator Expert? Answer questions, earn points and help others
