Question about Nikon D60 Digital Camera with 18-55mm lens
My nikon d60 fell off a chair, now the lens will not lock into place. no parts are visibly broken or damaged. Any suggestions?
  • kakima May 11, 2010
    If you have another lens or another body, try to determine whether it's the lens or the camera that's at fault. If you don't have either, take your camera and lens to a good camera store and determine which is at fault. The store can also give you an estimate on fixing whatever is broken.
    Brigadier General:
  • 11,967 Answers
Obviously, the lens mount is no longer in line.
Posted on Feb 07, 2010
I have a Nikon N65 and an AF Nikkor lens on it. The lens fell off some time ago, and now it does not lock in place.
The most likely culprit is a broken mount on the lens. Some Nikkor lenses have a plastic mount whose bayonet blades can break off when the camera is subjected to a shock. Since you neglected to specify the lens I don't know if this is the case with yours.
If you have access to another lens, try it. If that one stays on then the problem is with your lens. If that one doesn't stay on then the problem is most likely the mount on the camera itself, which is a more serious problem (unless the mounts on both lenses are broken).
Jun 19, 2012 | Nikon N65 35mm SLR Camera
I broke the plastic mounting tabs off the lens of my Nikon D60 so it fails to catch, is it possible to just replace the outer ring that serves to lock lens in place (fastened to entire lens mount by the 6...
i have done this before and i found a local camera shop that was able to give me a phone number to order the part but since they didnt charge that much more i just had them do it do make sure it was done right.
Nov 29, 2010 | Nikon 28-100mm F3.5-5.6 G-AF Lens - Black
I locked my nikon 50mm lens aperature ring to the appropriate setting for my Nikon D60, yet the camera still tells me to lock it into place, as if it is not registering the fact that I've locked it down...
Sounds like the coupling pin on the body is missing, Try a diff auto focus on the body, If it still does it then I believe that\'s the problem, On the body next to the lens mount, About 7 o clock there should be a lever that couples with the lens when is is at f22 or larger
May 13, 2010 | Nikon 50mm f/1.8 AF Nikkor Lens
My nikon D60 fell off due to strong wind and lens has damage !!
http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
May 04, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Nikon d60 When I try to take a picture with the
That is a problem that has to do with the Flash...make sure your flash settings are not turned on. If the flash can't find an image...it rotates and usually never finds the image. It's reading in a Flash mode.
Mar 25, 2010 | Nikon D60 Digital Camera
My Nikon D60 fell and the lens came off. Now the lens no longer holds -- it appears that a piece of plastic has chipped which prevents the lens to click close. Where do you recommend I get it fixed. I...
If you are no longer covered by an in-store warranty, whether an extended service or recent sale (typically 30 days) type, going back to Best Buy probably will not help (but asking about it can't hurt).
Nikon Customer Support may be the best place to get the camera repaired, but you'll have to determine if the cost is worth it. If you decide to buy new, be aware that not all Nikon lenses work with all Nikon cameras. Otherwise, if you buy a new Nikon, you'll be able to reuse many of the accessories you currently own for the D60. This can save you a fair amount of money - but make sure your lenses and other accessories will work with the new Nikon model you're planning on buying *first*
Contact Nikon Service for more help with your D60 below:
http://imaging.nikon.com/products/imaging/support/index.htm
I hope this helps!
Oct 30, 2009 | Nikon D60 Digital Camera with 18-55mm lens
I have been using a Sigma DG 70x300 lens on my Nikon D-60
This lens has a motor fitted to it to work on a D60 have you moved the A/M switch to M if not the lens is faulty and will need repair
Aug 19, 2009 | Sigma 70-300mm f/4-5.6 DG Lens
How can i repair my D60 Nikon lens? It wont zoom in or out ?
Sounds like its damaged, if the zooming is stuck. It might have fallen causing internal parts to damage.
I strongly recommend contacting Nikon service for this kind of repairs, because its far too easy to trouble the glass if you open it. I mean even if you manage to fix the issue many things can go wrong inside and the lens wont be come out clean. Better to leave it to professionals here.
Ruchir
Aug 13, 2009 | Nikon D60 Digital Camera with 18-55mm lens
My nikon d60 does not recognize my sigma 105mm lens
Hi I had a similar problem with a 50mm prime and I fixed it by locking the aperture ring on the lens in place.
May 04, 2009 | Sigma Telephoto 105mm f/2.8 EX Macro...
NIkon D60 - blury lens
for the close up photo u have to use micro or close lens set
Apr 25, 2009 | Nikon D70s Digital Camera
Nikon D60 Digital Camera with 18-55mm lens Logo
144 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
