Question about HTC P3300 Smartphone
Artemis/p3300 After reboot "Device start up failed..." and hard reset :(
"Device start up failed due to sudden loss of power. Please click "Yes" to continue. Note: Do not remove battery before device has been completely shutdown (OFF)."
I get this message when I reset my PDA after some heavy surfing. Is there something wrong with my memory?
I tried a different battery, SD card, CE version and sync software. The hard resets (that I cannot get around) occur around every other day so you can imagine that this is frustrating!
Thanks!
  • 4 more comments
  • cocopsa May 12, 2008
    Unfortunately, same problem with my P3300.
    Thank you for your help
  • htcUser Oct 28, 2008
    same problem....but the left button is NOT working now?? the right button is working but...that's not the way I need to go on :S
    any help is welcome!!
    Thanks!
  • Anonymous Jan 21, 2009
  • esfa Jan 25, 2009
    Hi,i have the same problem,any idea to fix it?
  • albertico123 Feb 26, 2009
    Hello..
    I have the same problem, and puhs the green button, but the problem continue.
    Some have idea?
  • Anonymous Mar 05, 2009
    Hard reboot hangs (get outlook + clock error).
    Note: I upgraded months ago to WM6.1
DO NOT USE THE TOUCH SCREEN ....instead, use the LEFT soft key to select "continue" ....I guarantee it would work again hehehehe......BUCHOG here
Posted on Jun 05, 2008
I've got the same problem I think it has to do with the internal memory.
Posted on May 30, 2008
My samsung t210 is not resetting i have tried button and inside setting options both look like its working but when reboots no change the accounts come back aswell
Before performing the Hard Reset:
- In case your Galaxy Tab 3 7.0 can connect to a computer, Then it is better to make a backup of your saved data using Samsung kies software, You can read this Guide to learn how.
- But in case that is not possible, Then you can check that your phone's battery has enough charging level, Otherwise you should charge it.
Samsung Galaxy Tab 3 7.0 SM-T210 and SM-T211 Hard Reset Steps:
- Turn your Galaxy Tab 3 off.
- Take out any existed SIM or memory card.
- Wait for 10 seconds.
- Press and hold the Volume Up key + Home key, Then press the Power key.
- Keep pressing the keys until Samsung logo appears,Release all keys.
- Wait until you get Factory reset / System Recovery menu on screen.
- Use the Volume Down key to select Wipe Data / Factory Reset option.
- Use the Power key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use the Power key to confirm.
- After performing the hard reset, Select Reboot System Now option, And confirm it using the Power key.
- Now the phone will reboots, Wait for it to be fully on and then you can start using it.
New Hard Reset / Factory Reset Method Using Odin3 Flasher:
In case you cannot put the Samsung Galaxy Tab 3 7.0 Into Recovery Mode for any reason, Or the Normal Hard Reset operation does not solve your problem, Then you can use this new method to Hard Reset the device so easy, This New Method will reprogram the User area, And it can solve many software errors too, Just follow the steps below:
- Download and Extract Samsung Galaxy Tab 3 7.0 Hard Reset File ( SM-T210 ' SM-T211 ).
- Download Odin3 flasher.
- Put your phone into Download Mode.
- Run Odin3.exe
- Click on CSC button and Select the Hard Reset file.
- Connect your phone to PC via USB cable, And wait until Odin3 detects the phone.
- Click on Start button and wait until the operation done.
- Now your Samsung Galaxy Tab 3 7.0 will be rebooted.
- Done.
Jun 02, 2016 | Samsung Tab Tablets & eReaders
Samsung galaxy ace duos S6802 incoming call always busy. I try to hard reset nothing happens. Call forwarding are disabled. Please help me to fix.it
When a Samsung cell phone becomes unresponsive or when the device slows to a crawl, a reset may be in order. There are two primary methods used to reset the phone. Users should always start with the soft reset when the phone locks up or programs slow down due to memory or software response issues. A soft reset is akin to a reboot of the machine and usually solves most problems without any loss of user data. A hard, or master, reset is required when the phone completely locks up and becomes unresponsive to any cellular signals. This second and more drastic reset deletes all personal data, preferences and settings so that the device is restored to the original factory configuration.
Perform a Soft Reset
Step 1 Press and hold the power button for 10 to 20 seconds.
Step 2 Release the power button and tap the "Power Off" option under the "Device Options" menu that appears. Tap "OK" to initiate the shutdown.
Step 3 Press the power button again to restart the device.
Perform a Hard (Master) Reset
Step 1 Tap the "Menu" key from the home screen and then tap "Settings."
Step 2 Go to "Privacy" and tap "Factory Data Reset" to review the Factory Data Reset information.
Step 3 Review the Factory Reset options. Place a check next to "Format USB Storage" to clear your device of user data, such as music, pictures and other account settings.
Step 4 Review the disclaimer and verify your changes before tapping "Reset phone."
Step 5 Tap the "Erase Everything" or "Yes" buttons to confirm the reset the phone to factory settings. The device initiates the restoration process to the original factory configuration.
Perform an Alternative Soft Reset
Step 1 Power off the phone. If the phone does not turn off, remove the back cover of the phone and take out the battery. Wait between 10 and 30 seconds and then replace both the battery and the cover to restart the device.
Step 2 Simultaneously hold down the power/lock keys.
Step 3 Release the keys when the Android screen appears.
Tips
  • The ATT Samsung SII models have an alternative hard reset that requires you to simultaneously hold down the "Volume Down" and power keys after an alternative soft reset, and then release the power button, bringing up the menu titled "Fastbook, Recovery, Clear Storage, and Simlock." Use the "Volume Down" key to navigate to "Clear Storage" and then press the power button. Press" Volume Up" for "Yes" and "Volume Down" for "No." This will reset your device to its original factory setting.
  • A soft reset on a Galaxy S phone involves pressing the "Volume Up" key simultaneously with the power button.
  • Some older Samsung models have a reset button located behind the battery cover. Press the reset button using a small, blunt object.
Warnings
  • A factory data reset removes all user data and settings associated with the current account. Make a backup of all data on your device before starting a hard reset.
May 12, 2014 | Cell Phones
Factory setting?reset
Hi..
To reset a smart phone..
you can see black rubber bush back side of the mobile..please remove that push and you can find a reset hole in that. you need to reset by using any pin
I hope it helps..
Regards,'
Raj.
Feb 18, 2009 | HTC P3300 Smartphone
I have not found menu from start button
you can hard reset your phone, anything on the phone will be deleted.
sim remains intact.
www.xda-developers
search for p3300 hard reset.
its the 2top side buttons and then the one ya gotta use a pen for, all at the same time..i think.
Feb 14, 2009 | HTC P3300 Smartphone
The hard reset has no result
To perform a NORMAL Hard Reset
1) TAP ON START ---> SETTINGS ---> SYSTEM
2) TAP ON THE " CLEAR STORAGE " ICON
3) ENTER 1234 & TAP " YES "
IN YOUR CASE DO HARD RESETTINGS AS MENTIONDED BELOW
1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the lower left side of your device.
2. Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen:
3)“Press Send to restore manufacturer default, or press other keys to cancel.“
3. Press on your device.
YOUR HTC P3300 BECOME LIKE NEW ONE WHEN PURCHASED IT USE IT 1ST TIME.
NOTE : ALL ADDITIONAL PROGRAMME LOADED BY YOU AND CONTACT NOS PHOTOS VIDEO SONGS STORED ON MAIN MEMORY WILL BE VANISHED AFTER HARD RESETTINGS SO PLEASE THINK TWICE BEFORE DOING HARD RESET !
PLEASE RECHARGE HTC P3300 BEFORE PERFORMING BOTH HARD RESETS
Feb 01, 2009 | HTC P3300 Smartphone
Hard reset
Occasionally, you may need to reset your device. A normal (or soft) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings — the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on your device will be lost. Only Windows Mobile software and other pre-installed programs will remain.
To perform a soft reset
Use the stylus to press the RESET button found on the lower left side of your device. Your device restarts and displays the Today screen.
To perform a hard reset
  2. Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen: “Press Send to restore manufacturer default, or press other keys to cancel.“
  3. Press on your device. Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
Oct 29, 2008 | HTC P3300 Smartphone
I want to change the operative system in my htc p3300 phone, from italyan to english it is possiblle
go to this site
http://forum.xda-developers.com/forumdisplay.php?f=316
and be sure it's for the artemis.. if not from the same site go to artemis..
there is everything you may need.
you have to unlock your phone first and choose a rom you like :)
Oct 01, 2008 | HTC P3300 Smartphone
Sim lock
yes you can doit your phone is an artemis faloo this link red if you not abel too unlok mail me jhonyvyrus@yahoo.com
link www.xdadeveloper.com
Jun 10, 2008 | HTC P3300 Smartphone
HTC Artemis Problem
dry it as mch as u can... air dry for at least 24-36 hours..goodluck
Jun 01, 2008 | HTC P3300 Smartphone
HTC P3300 Smartphone Logo
1,153 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
