Question about RCA HD52W66 Projection Television
Convergence i need the part number for the convergence panel, and so far i have had no luck. the complete model number is hd52w66yx39 and it uses an itc222a chassis. this convergence panel doesn't use the normal stk's but many transistors instead. any help is greatly appreciated.
  • premier100 Feb 23, 2008
    color picture distorted with a rainbow appearance
  • SarahakaJojo Dec 08, 2008
    my model D52W19, chassis ITC222 has the same issue. Also it tries to correct itself 3 times.
    Scholar:
  • 133 Answers
You could have bad solder joints on the board . Mostly the sockets where the wires comes from the signal board or the power supply that feeds it . If you need the module go to union electronics on the web they can order it or may have it in stock. James (tech) at LRF Electronics
Posted on Feb 27, 2008
    President:
  • 4,402 Answers
Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link:
Posted on Feb 21, 2008
How to install a convergence kit in R61WH76 chassis no. itc222a
That model doesnt have the normal convergence components that nost other sets have. There are no convergence ICs the convergence is actually affected by three boards within that chassis it can be deflection board related, Convergence power board or the convergence amp board. Based on your TVs setup menu diagnosis will determine wether a component needs replacement or wether a circuit board will need replacement.
Aug 06, 2011 | RCA R61WH76 61" HDTV
Color seperation on my oct. 2006 rca hdtv model no. r52wh73 --- serial no. g432c106i---- chassie itc222a----service no. r52wh73yx61
ghostflame88,
Bad convergence circuit. See my tip at http://www.fixya.com/support/r5119668-fix_convergence_problems_rca_chassis to help solve your convergence problem.
Thanks for using FixYa and for the great rating.
hardrocko
Jun 27, 2011 | RCA R52WH73 Projection Television
I have a RCA HD52w59 model an it needs conversion adjustment the picture has red,blue,anyellow around it tryed using menu button but no luck
the repair kit called the ITC222 and ITC222A convergence misssing repair kit should solve hat issue. The kit also contains instructions and is available from www.tvrepairworld.com
Apr 28, 2010 | RCA R52WM24 52" HDTV Projection Television
I have a rca hdtv, model #hd52w59, chassis #itc222a, convergence is off real bad, happened all of a sudden, went to menu to set up and convergence is not showing, is there something special i need to do to...
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. The convergence board should be checked for cracked solder joints and please make sure to check the resistors as if they are shot the ICs might blow again. All this is only recommended if you have electrical expertise and know how to solder/re-solder components, if not then you should get this done by a professional. The typical cost to get this fixed by a pro is around $250-$300. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 23, 2010 | Televison & Video
Modle model hd52w67yx66 lost convergance pic has three colors in main menu no convergance option like when new open for sugestions tuner and sound ok
Thats a easy and inexspensive repair. www.tvrepairworld.com has the RCA repair kit called "ITC222 and ITC222A convergence option missing repair Kit" The kit contains the components and the CD with detailed repair instructions.
Dec 22, 2009 | Televison & Video
My auto convergence has disappeared, and my colors are messed up
The ITC222 and ITC222A convergence option missing repair kit fixes tha issue. The kit is available at www.tvrepairworld.com and has complete instructions on CD
Oct 07, 2009 | RCA HD52W59 HDTV Projection Television
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
I cannot find the convergence functions on my tv
Sounds like your talking about an RCA HDTV with the ITC222 or ITC222A chassis. If so the ITC222a Convergence option missing repair kit at the following link will repair that issue. www.tvrepairworld.com
Aug 21, 2009 | Televison & Video
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
RCA HD52W66 Projection Television Logo
95 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
