Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My mower will not move,it seem's like the highdro. trans. is not working. what can i do to fix the problem?
  • 677 Answers
Most hydro units run off of a belt or shaft from the engine.
Look under the seat/fender, and find which it is.
Please let me know what you find.
Posted on Feb 07, 2010
Why does my forward and back pedals on my cub cadet riding mower have so much play in them causing my mower not to move?
must have come disconnected from the trans. trace the linkage from the pedal back to the trans.
May 23, 2016 | Cub Cadet Garden
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
Riding mower won't move forward or reverse
WHAT MAKE AND MODEL MOWER? YES...YOU EASILY COULD HAVE BROKEN THE AXLE!
SEE IF EACH WHEEL WILL SPIN INDEPENDENTLY OF ONE ANOTHER IN BOTH DIRECTIONS. ALSO, SOME MOWERS HAVE A ENGAGE/DISENGAGE TRANS LEVER (USUALLY PULLS IN AND OUT AND LOCKS WITH A CLEVIS PIN RETAINER)
Jul 26, 2013 | Garden
Husqvarna Riding Lawn Mower Problem
sounds like a linkage problem or the valve in the trans some older ones had a problem with a roll pin inside the trans falls out of place cheap fix but a lot of time to pull the trans out and apart
Jul 12, 2012 | Garden
Cub cadet will not move forward or back
did the belt fail?the trans and the drive are different belts
May 19, 2012 | Garden
1997 MTD Riding Mower 18hp 42"cut. Drive belt
I wish to tell dwhandys that this is a great answer, and a great solution. You surely know how to work!
Sep 03, 2011 | Yard Machines Garden
The mower will not move foward or backwards when in gear and teh brake is released. I did check to make sure that the brake isn't locked. It seems like teh transmission is not engaged. It worked fine in...
Is there a lever or pull device that disengages the drive so you can push the mower? If you can push the mower with the brake off, the trans is not properly engaged.
Is this helpful?
Gary
Feb 28, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Troy-built 21" mower - self propel problem. From my research it seems like a manufacturer problem that was availiable thru a claim but I am the 2nd owner so I must fix myself. Its a model 834. I have...
do you have the complete model number from the data tag on the mower frame? there are two typical systems for these machines, both require the belt to be tight and not slipping at the crank shaft, and the pulley on the trans-axle to not be slipping on its shaft, the older style trans axle uses a belt tensioner system to tighten the belt and turn the pulley, i.e. if the pulley turns then the axle should too. this can be checked by hand with the axle and belt removed. the second system is a clutch style axle that has a constantly tight belt and uses a small cable controlled lever on the transmission housing to engage a drive clutch inside the transaxle, if moving the lever forward doesn't cause the axle to turn as the pulley and shaft are turning the clutch mechanism is usually toast. with both of these systems one should also note whether the axle is turning inside the wheels when they are on the ground, the over running clutch sprags inside the drive gears could be stuck causing the wheels to turn without resistance applied, but stall when in contact with the ground.
while inspecting the trans axle note any wobble or free play in the axles or input shaft, this will indicate a worn case or bearing, resulting in a slipping gear in the trans axle.
Jul 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
61 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
