Question about Apple Cinema Display 23" HD Monitor
Image/screen shifting with mouse position
Have an older 23" Cinema Display with a dual G4.  when I move the mouse pointer past the middle point (horizontal or vertical) it shifts the entire screen about a millimeter up/down or left/right, causing blurring in the letters.  also notice that letters are blurry in the middle more than they are to the top/bottom/left/right.
  • ariehl Aug 12, 2008
    I'm having the same issue. The screen just started misbehaving last night while using the computer. It seems that the screen is divided into four quarters, and depending on the position of the mouse, the other three will stretch distorting the images, on both vertical and horizontal lines. If I turn the resolution down to 1024x768 or lower, the issue seems to stop, but I can't work at that low resolution. The screen has not been disconnected for years, and power cycling the screen made no difference.
I realized my issue was that the screen was "slightly" zoomed in using the universal access panel in the system preferences. Turning it off, or zooming out completely solved the problem.
Posted on Aug 13, 2008
    Sergeant:
  • 458 Answers
Make sure that none of your pins a bent on the plug. Try changing your screen resolution or refresh rate.
Posted on May 29, 2008
My 23" Apple cinema display (2002) has black screen and code flashes three short flashes. How do I find out if the monitor is dead or the power supply?
The only way to test is to use a known working power supply or known working cinema display with the parts you already have.
Dec 11, 2012 | Apple Cinema Display 23" HD Monitor
How do you print screen?
Hi John,
To print the screen what you see, Press the Print Scn Button on top row of your keyboard.
Open Paint Brush or Microsoft Word and mouse right click and click left click on Paste.
Click on File and Print button or CTRL + P key to open the print dialog box and click print.
It used to be much easier earlier when there were dot matrix printer which would directly print when Print screen button was pressed. But today you need to follow this work around to print the screen
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
May 16, 2011 | Bosch Computers & Internet
My desktop image shifts as I move my mouse arrow around the screen. How do I stablize the image
What you have done is accidently magnified your screen slightly. To correct this hold down your ctrl key and scroll down on your mouse, this should fix it. Hope this helps.
Nov 18, 2010 | Apple iMac G4 Desktop
My iBook G4 continues to run slowly and/or freeze
Try resetting the PRAM by turning on the iBook then holding option + command + P + R and wait till u hear another chime. If it still freezes, it may indicate an application may be causing it to lock up hold shift after you hear the chime to boot OS X into safe boot.
Mar 18, 2009 | Apple iBook G4 Mac Notebook
Monitor displays alternating pattern of pink and blue stripes
It sounds like your video card is failing and you need to find a way to get around it if possible?
Feb 18, 2009 | Sony VAIO VGC-LS30E 1.73GHz Pentium Dual...
The small scrolling icon on Windows Vista
1-Firstly you go to system control panel(Start button->setting->Control panel)
2-select the mouse option and click
3-you see the 5 option under it,select the pointer options
4-under the visibility option unmark Display pointer trails &
Hide pointer whilt typing option
and also check the pointer speed option under pointer option.
5-than ok..
Thanks,
Feb 10, 2009 | Microsoft Windows Vista Ultimate Edition
Screen draging
here's my guess =)
maybe you have the mouse pointer option set to Display pointer trails? if this is the case... this is the solution.
  • go to control panel: START > SETTINGS > CONTROL PANEL
  • select mouse
  • go to Pointer Options
  • look for Visibility section
  • uncheck Display pointer trails
Jun 03, 2008 | Lenovo ThinkPad T61 Notebook
Apple Cinema Display 23" HD - Dust on inside of screen.
Well, I pretty much knew that the display would have to be disassembled to clean the dust out. I should have been more specific by asking if the display "could" be taken apart to clean it out, especially since the dust is in between the image and light source layers.
Jan 15, 2008 | Apple Cinema Display 23" HD Monitor
Apple Cinema Display 23" HD Monitor Logo
163 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
