Question about Caroma 270W-RF Reflection Round Front Dual Flush Toilet - White
How do I get the lid off a stylus toilet cistem
Solution I received " lever up the two flushing buttons with a fine blade screwdriver.
They may be a push fit on two plastic posts. Once off, they reveal a screw between them. Release this to remove the cistern lid. Make a note of the position of the buttons as they only fit one way round."
Posted on Apr 16, 2010
  • gk_1176 Nov 05, 2011
    Thank you so much, you have solved my on going frustration. I even tried a plumbing shop that was no use. Much Appreciated.
, Hi good evening ,i need the lid tank for toilet tank 4440
Amazon lists one:
Product Description
Briggs - China Toilet Tank Lid for use on tank #s 4420, Altima 4430, 4433 and Abingdon 4440 tanks. Click here to buy now. Same day shipping on most orders. High quality construction. Quality Replacement Part.
Briggs China 7469 130 Toilet Tank Lid
Feb 01, 2015 | Home
How to fit seal on fluidmaster flush valve
before you replace the seal: inspect the bottom seal by running your finger around and inside the rim. not likely but could be a burr. If the seal is OK, install a new flapper bulb. while the old one may look fine, the rubber may have hardened and thus will no longer seal properly. It's an easy fix, just be sure to get the correct replacement bulb. AND/OR, buy some silicon plumber's grease. A small container costs $3 or so. Spread the grease on the bulb and the seal-rim; where the two pieces meet to form the seal. Should provide a better seal.
Jul 05, 2014 | Plumbing
Toilet is not flushing
sounds like you need to adjust water level in tank,take lid off and check if theres enough water to flush should be a water level line in tank.
Sep 24, 2011 | Dmm Mansfield 119CL EcoQuantum Toilet Tank...
I have a 1 yr old new Danze Orrington two piece toilet. DC013230-DC012223. I have 3 of the same actually but only one is giving me problems...the one on the first floor of the house. The flush is weak...
Your thought is probably correct. Usually toilet tank lids and feet on them to allow air enty. You might have to add rubber feet (self adhesive) or balance the lid on the tank differently.
Jun 03, 2011 | Danze - Toilet - One-piece - Orrington -...
I am looking for a replacement toilet tank lid for a Eljer Preserver II toilet. Manufactured in 2003.
I checked the Eljer website; several different toilets came up searching with the number you provided but
no information on a Preserver model.
I think your best bet would be to contact your nearest dealer for the Eljer products. You can use the location finder on the Eljer website:
http://www.eljer.com/dealers.aspx
It is possible a dealer may have old stock oand should know if there is a substiute available.
Mar 02, 2011 | Eljer Toilet Tank Lid Preserver II ...
How do i take the lid of the cistern
There is a trick to this for Porcher toilets. Push big flush button down, then lift up and out the small button. The big button lifts out. Undo plastic bolt and lift up lid. cheers, zoofish
Dec 18, 2010 | Porcher Toilet Seat Veneto 70032.001
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Aug 29, 2010 | Toto Aquia II Dual Flush Toilet
Toilet lid is broken, is there a way to find a replacement
Any normal toilet seat may work, check your local Home Depo.
Mar 23, 2010 | VitrA Aria Toilet with Round Bowl /...
How do I get the lid back on the toilet?
lightly grease the rubber seal first this will help you slide it into position thats the hard bit now you can fit the lid remenbering to tighten corner to corner so that you get an even pull down
Nov 17, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
We have a broken tank lid and need to replace it.
Try your local plumbers merchants [u need the make of the toilet] or thy local salvage yards www.salvo.com could be helpfull
Always take the broken lid with you
Sep 07, 2009 | VitrA Aria Toilet with Elongated Bowl/...
Caroma 270W-RF  Reflection Round Front Dual Flush Toilet - White Logo
3,242 people viewed this question
Top Caroma Home Experts
john h
Ngoro
Ngoro
Are you a Caroma Home Expert? Answer questions, earn points and help others
