Question about Holmes Products HFH5606-U Compact Heater
Heater wont run on hi and doesn't get warm at all
Heater wont run on hi and doesn't get warm at all fan works on low but wont get hot air.
  • 1,476 Answers
One of two things here. You blew an internal fuse or the heating element is broken. Take your unit apart and check for bad fuses and also check that the heating coil has continuity. Let me know how you make out.
hardrocko
Posted on Feb 07, 2010
2000 caddy Seville ...after starting and engine warm turn on the heater and it blows cold air. Fan works / waiting for hot air and then all the sudden it kicks in. Engine at normal temp
Low coolant, if there is an air pocket in the engine it will make it to the heater core. Once there , the air coming out is cold/cool. Once the coolant fills the heater core, it gets hot. If the coolant is fine hot or cold, then have the HVAC system scanned.
Oct 09, 2016 | 2000 Cadillac Seville
I have a 2002 Ford torus that doesn't put out enough heat in the winter I have flushed out the heater core and change the thermostate but it still don't get warm enough and it doesn't have a...
If both heater hoses are getting hot then you know the coolant has to be flowing and the core should be hot.
What you will have to do is locate the blend air door servo.
The blend air door is a door (or flap) between the heater core and the A/C evaporator (even without a/c there is still a door to control the cabin temp)
Early vehicles with the slider controls used a cable but the later vehicles with a rotary knob or digital buttons use a servo to rotate the door mechanism.
The servos can go bad and the switches as well.
But from the sounds of it, your door is not moving to allow the heat through the vents.
Oct 01, 2011 | Cars & Trucks
My heater won't blow out any air unless it is on high with the fan blowing.
Hello let me verify.
1 heater wont blow out warm air unless on high?
possible clogged airfilter.low on coolant or antifreeze.
2 heater wont blow any air unless on high?
Could be a bad switch low ane med do not work.
Jan 14, 2010 | 2005 Jeep Grand Cherokee
Home is not warm enough
This sounds like one of two issues. Either your fan speed is on high and needs to be adjusted to low, or if that is done then the issue lies in the duct work. either the duct work or plenum ( your air ducts connect to) is leaking air and the hot are is escaping threw holes. Another issue is rats or mice eating the duct work. Also check your thermostat to make sure that the fan switch is on auto and not on
Jan 10, 2010 | Heating & Cooling
No heat air is blowing cold
First you have to identify what causes the problem.
To do this you have to:
1) When engine is cold check the level of coolant. If it is low fill it up.
2) Start engine and check if engine reaches regular temperature. If your engine is not heated enough it means your thermostat does not work properly and should be replaced.
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is worm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
4) If pipe/pipes are hot/warm, turn off the fan, switch controller to the hot position, wait for 3-4 minutes and turn on the fan. Note if the cold air blows first or warm air blows first but it cools down in 5-10 seconds. If the air blows cold than it is most probably the problem with blend door or blend door actuator.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest to flush the heater core.
Oct 22, 2009 | 1998 Ford Taurus
MY 1998 FOR TARUS HEATER WILL NOT WORK.WAS DRIVING
It is most probably the problem with blend door or blend door actuator. But just in case I would suggest to follow the entire procedure:
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is warm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest flushing the heater core.
Oct 17, 2009 | 1998 Ford Taurus
Heater not working
Heater wont blow warm/hot air
check your radiator coolant, thats what I did and it blows warm again
Jan 15, 2009 | 1999 Pontiac Grand Prix
Car just blows out cold air from heater
there is something wrong with your coolant system. Turn your car on, check your fan. If the fan runs nonstop, your relay switch to the fan needs to be changed. If its not the fan, its the thermostat. The thermostat is broke. If the thermostat is broke, it prevents your vehicle from warming up. The thermostat is a temperature Regulator for the engine. If your antifreeze is running nonstop in a circular motion, your engine will run cold. Your engine wont start that cold in the winter either.
Dec 03, 2008 | 1995 Honda Accord
Holmes Products HFH5606-U Compact Heater Logo
196 people viewed this question
Top Holmes Products Heating & Cooling Experts
paulcarew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
