Question about HP Pavilion dv6000z Notebook
I bought a replacement battery for my hp pavillion 6775us, and charged it and discharged it then charged to full and the battery check said i needed to replace it. it wasn't an HP original equipment battery, but an online replacement. i got 2 hrs and 45 mins of use on a full charge. what's up
  • 358 Answers
First of all, disconnect your battery from back of the
laptop, then try and get a friend or a technician that
uses the same type of laptop, and try to swap the
battery just to check whether it works and charges
it properly. Also do the same thing with the
Adapter/Charger and charge it with it.
This is because, there are two diagnostic possibilities
here:
1.) It is either the battery that you bought is not good
and you need to return it quickly before its too late
or;
2.) The charger that you are using is bad, or not
supplying enough current to charge the battery
cells...and this might even damage the battery after
a while, or make the battery not to charge to its full
capacity and as well discharge quickly.
Try this out and let me know how it goes.
Hope this helps you out.
Goodluck and thanks for using fixya.
Kindly Let me know how it goes.
Hope this helps.
Posted on Feb 07, 2010
Model 800 has no power after full charge will spin but I can stop it with my two fingers
It sounds as though the battery is not carrying the proper full charge. If the unit is still under warranty, have the battery unit replaced. Visit the website and see if there are any recalls fro your model. If yes, check to see if your model number, serial number, batch number are included.
If this is a new purchase, have you 'conditioned' the battery by charging it fully and discharging it fully at least 5 times? It's a form of 'battery exercise'.
It uses a Lithium-Ion (Li) battery, so it is unlikely to be suffering from the 'memory effect'.
If it is the original battery and you bought it years ago then the battery pack needs replacing. While it reports a full charge, the battery is simply incapable of holding enough charge to provide a strong current to drive the motor.
Jan 31, 2015 | Tools & Hardware - Others
Hp pavillion zv6233nr
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Rechargeable batteries will fail if stored in a discharged state for long periods.
May 05, 2013 | HP Pavilion Computers & Internet
I bought a replacement hp battery for my HP Pavillion zv5000 a year ago. It was working fine for about 6-8 months. Then, it seemed to stopped storing energy even when the charging light stopped and...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 08, 2011 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavillion ZV6000 - Charging Problems
hi
It seems that your laptop is not charging so in that case you must take your laptop to your vendor.For more support you can visit---------http://robs-tech.blogspot.com/2009/06/free-solution-regarding-computer.html
Jun 22, 2009 | HP Pavillion ZV6000 Notebook
My Compaq nc6220 only starts up when the ac adaptor is plugged in. I think the battery needs to be replaced. does this sound right ?
To check if the battery is charging go to Control Panel - Power Options - Power meter. If it shows unknown or zero charge then the battery is faulty or worn out. Rechargeable batteries have only a finite amount of charge and discharge cycles and over a couple of years use they lose their full amp hour charge capacity.
Jun 10, 2009 | HP Compaq nc6220 Notebook
HP PAVILLION DV6000 REPORTS BATTERY NOT CHARGING
If you charged up your battery up for 2hrs but didnt increase the percentage or didn't charge up at all it means that your battery is faulty. I have also a same case with you.
Send it to the service center near you and ask them to rplace your battery. Replacement is free if machine is under warrant.y
Jun 03, 2009 | HP Pavilion dv6000z Notebook
Just bought a new hp pavillion laptop. when puttin on charge says 'plugged in not charging' but d battery poer does not increase or decrease?? whats wrong?
Hello
I think your battery is getting old...try consider replacing it...but first try and re calibrate your battery...If its still unsccessful its ok to use the battery but beware that at any moment its likely to go off...try replacing your battery i would suggest.
Nov 25, 2008 | HP Computers & Internet
Problem with my hp notebook battery!!!
discharge your battery compleately and then
charce your battery for 16 hrs add then discharge compleately
and charge till 100% batt level approx 2hrs
that will help
Nov 03, 2008 | HP Pavilion dv5020us Notebook
I just bought new rechargeable batteries, and got only a few shots. Why so little usage from new batteries? Is something wrong?
Nothing is wrong with the camera or the batteries. Rechargeable batteries of all kinds will self-discharge over time. Charge them fully (if they are NiMH completely charge and discharge them a few times), and you should see full battery capacity.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
