Question about Dell Latitude D800 Notebook
Resetting to factory settings
We need to have our notebook reset to the factory default settings. It was used on a network at a business and we need to change it up and have it connect to a different home/office network. Can you tell me how to do this? I have tried the system restore but that hasn't worked.
Thank you,
TP
  • 2 more comments
  • jtsservices Feb 22, 2008
    First- Thank you for your response. I tried but there isn't a utilities folder in the dell folder on the local disk C. I have a dellbutn, DELLSUPPORT, E-wtrmrk and sol_cent. I tried searching for the dell utilites but came up with nothing again. Even tried just typing in the RUN box the address at the bottom, no luck either. Anything else I can try?
    One thing, we do have another newer laptop that is a Dell Insperion B130. We have the dell utilities and applications disk for that one. Would it work for the Latitude D800?
    There is a boot menu that comes up at startup when I hit the F12 key. But there wasn't a DSR or anything like that on it. Thank you.
    Well that sucks for us. Thank you for your time and help.
  • 97 Answers
IF YOU CAN STILL BOOT TO WINDOWS try this steps if you can still boot to windows
1. Open local disk C:
2. Go to Dell folder
3. Go to Utilities folder
4. Open DSR folder
5. There will be a file named "boot_DSR", double-click on it.
6. It will have a prompt that will tell you that it will now perform the restoration, click OK
7. The system will now reboot and you don't need to do anything, it will automatically go to the PC RESTORE.
C:\Dell\Utilities\DSR\boot_DSR
Posted on Feb 21, 2008
  • 1 more comment
  • MR R
    MR R Feb 22, 2008
    Normally they have a separate partition into which they place the "repair" files see if you can load a boot manager this might let you get access to the partition on which will be the Boot_DSR or some boot file of some kind. Ofcourse it may be that the drive was a clean install of XP over the DELL XP if this is the case you would need to buy XP and re-install and download the other drivers from the DELL site
  • MR R
    MR R Feb 22, 2008
    Sorry to say it more than likely would not you have legal issues if you did so i would steer clear not only that the driver will be different
  • MR R
    MR R Feb 22, 2008
    Yes that's the DELL hardware testing utility not really part of the Dell recovery partition more's the pity, We use Dell PC it appears even after we have wiped the HD. it could be that your partitiion has been wiped of the Dell recovery boot DSR and all is lost
Hello. How can I reset Panasonic Lumix DMC-TZ60 to factory default? (Can I reset software and hardware?) Thank you for answer
Resetting by 'Software'
Resetting to the Factory Default Settings from the interface:
  1. Go to the interface of your camera by typing in the camera's IP address in the browser. Example: http://192.168.1.253/
  2. Click Setup, Maintenance, Default Reset, Reset to default and then click Execute.
Resetting by 'Hardware' Resetting to the Factory Default Settings using the Control button:
  1. Disconnect the 'DC IN' cable from the camera.
  2. Hold down the 'Initial Set' button.
  3. Reconnect the power adapter using the 'DC IN' jack while holding down the 'Initial Set' button. Release the 'Initial Set' button after 5 seconds. (The reset could take up to 180 seconds)
  4. When the 'Status' indicator changes to green, the process is completed and the camera had a Factory Default Reset.
Sep 11, 2016 | Panasonic Cameras
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
How to delete former owners wireless data on HP 4500 - G510n wireless printer.
Settings
RESTORING
FACTORY SETTINGS
initialization
Mar 26, 2015 | HP Office Jet 4500 G510n
Hi. what is default password Ip Camera model vivotek ip7730 ?
By default, the Network Camera is not password-protected.
Hardware Reset
The reset button is used to reset the system or restore the factory default settings
Sometimes resetting the system can return the camera to normal operation If the system problems remain
after reset, restore the factory settings and install again
Reset
: Press and release the reset button with a paper clip or thin object
Wait for the Network Camera to reboot
Restore
: Press on the reset button continuously for over 5 seconds
Feb 15, 2015 | Computers & Internet
I need a code for a kodakhero printerphotocopier 7.1
I don't believe that model has a password. You may just need the password for the network you are using. If you want to reset the unit to the factory defaults see below.
To reset defaults to the factory default settings:
1. Press .
2. Touch , then touch Printer Settings.
3. Touch , then touch Reset All Settings.
4. When you see the message, "This will reset printer settings to factory defaults,"
touch Yes.
NOTE: Resetting factory defaults does not change the date and time, language, or
country/region.
Jun 19, 2014 | Netflix
How do I recover a forgotten password for an overdrivepro63E wireless internet stick
Wireless networking is a common feature in homes and offices.
Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network.
If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu.
Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable.
Open your Web browser. Enter the default address of your router.
The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1."
Enter your username and password.
Many routers use "admin" for the username and password by default.
Locate the wireless security settings.
Disable the wireless security.
Reset to Factory Defaults
Locate the reset button on your router.
Typically the reset button is a small indented hole on the back of the device.
Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings.
Locate the wireless security settings and add security as necessary.
Nov 05, 2013 | Computers & Internet
Need to hard reset westell 7500 modem to factory defaults..cust chngd admin password and can't remember what they chngd it to and i need to get into modem
  • Note: Resetting your router to the factory defaults not only changes your router user name and password to the factory default values, but it also deletes all your home network settings. This includes the SSID and network encryption key. After you reset your router to the factory defaults, your home network won't be accessible until you reconfigure your router and all your network devices to use the same SSID and encryption key.
To reset your VersaLink 7500 gateway to the factory settings:
  1. Hold the reset button on the back panel of the VersaLink 7500 gateway for 30 seconds.
    • All your settings will be lost including network encryption information and any SSID information you have entered.
    • The gateway user name and password will revert to the default of Admin as the user name and Password as the password.
  2. Your VersaLink 7500 gateway is now using the default settings for the network configuration. This includes the default SSID and network encryption key. You must re-configure your VersaLink gateway to match your previous settings that were assigned to all other devices on your wireless network. Otherwise, no other network devices will be recognized.
Nov 05, 2011 | Westell Wirespeed VersaLink...
Ant get a network --lost password
If you forgot the password, resetting the router will allow you to access the router's configuration screen again. However, this will reset the router to the factory default settings default, and you will have to reconfigure the router.
Instructions for the router:
http://www.belkin.com/PDF/F7D1301_Basic_Router.pdf
From page 12: Reset Button on the back of the router.
This button is used to restart your Router in rare cases when it functions incorrectly. Resetting the Router will preserve your settings. This button may also be used to restore the factory default settings. Please see the Troubleshooting section (page 15) for more information.
Apr 10, 2011 | Belkin Basic Wireless Router
My grandpa set up our wireless network a few years ago, but bless his heart, he passed away just this year and we forgot our WEP key and we need to reset it or just get ahold of it so the family can access...
Sorry for your loss.
  • Note: Resetting your router to the factory defaults not only changes your gateway user name and password to the factory default values, but it also deletes all your home network settings. This includes the SSID and network encryption key. After you reset your gateway to the factory defaults, your home network won't be accessible until you reconfigure your router and all your network devices to use the same SSID and network encryption key.
To reset your VersaLink 327W gateway to the factory settings:
Hold the reset button on the back panel of the VersaLink gateway for 30 seconds.
  • All your settings will be lost including network encryption information, MAC Address filtering information, and any SSID information you have entered.
  • You will need your user name or password to reconfigure the unit..
Your VersaLink 327W gateway is now using the default settings for the network configuration. This includes the default SSID and network encryption key. You must re-configure your VersaLink gateway to match your previous settings that were assigned to all other devices on your wireless network. Otherwise, no other network devices will be recognized.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 18, 2011 | Westell Wirespeed VersaLink...
Printer Password
If you reset the network card on the 8008 back to factory defaults it will reset the web password back to 'sysadm'
To reset factory defaults power the pritner on holding down CLEAR, keep CLEAR held down whilst you power the printer ON, keep the clear button held down untill you see RESETT on the display.
Resetting factory defaults will reset all network settings EXCEPT - IP, Sub net and Gateway address
May 13, 2008 | TallyGenicom 8008 Laser Printer
Dell Latitude D800 Notebook Logo
1,372 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
