I have a Kenmore front loader washing machine that won't spin or drain. What is wrong?
  • Washing Mach... Master
  • 8,220 Answers
Top 10 frontload washer problems
1)Water fill problem: water took more than 10 minutes to fill to desired level sometimes indicated as a LF/IE or long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
2)Excessive vibration: noisey,roar, knocking noises. Bad damper,bearing or broken trunion. no error code
3)Dispenser drawer open/detergent in wrong compartment: washer will not operate with drawer open or cleaning products in wrong compartment.
4)Washer won't drain: clogged pump/filter, slow or clogged drain usually indicated as a LD/DE, if a code is given (long drain/drain error) Clear pump of objects
5)Drum overfilled: usually caused by sediment in the water level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
6)Door open, Door not latched, clothes/objects keeping door from completly closing. Tighten door latch, add washers if nessesary to make good contact and close door tighter in case of leaks.Note some models send a sig nal to the motor and another to the control letting both know the door is secure before proceeding, corrosion gets into the lid lock and the door can be locked and the control is ready but the motor ain't getting the message.
7)Cold water does not enter washer: hoses connected backwards. Oops.
8)Oversudsing: Wrong Detergent, too much detergen, detergent in wrong dispensing drawer, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. On some models a suds detect is determined by the motor over amping, most machines will try a few mini loads to correct the problem. Remove detergent, retry
9)Locked motor: error LE,loose connection,broken wire/hallsensor, motor overheated/failed.
10)Water heating error, hE, the termister/heater is out.
Posted on Feb 07, 2010
  • 15,935 Answers
Likely the pressure switch is bad... or the latch/lock has failed.
Locate the service manual inside the washer housing (behind lower kick panel) to get the testing procedure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Model 5000 front loader. Why doesn't pump work?
Whirlpool washing machine drain pump replacement and ...
? 17:45
www.youtube.com/watch?v=2abTptUYXH8
Feb 5, 2012 - Uploaded by HandySavesMoney The drain pump replacement procedure will apply to kenmore, whirlpool, maytag and other front-loading washing machines. ...does anybody knows about front loader whirlpool that won¨t start? i could use some help tx.
Oct 07, 2015 | Whirlpool Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Feb 03, 2013 | Washing Machines
Front loader stuck in final spin - not draining
Very likely the reason your washer isn't draining is because the filter screen on the drain pump is blocked so it cant drain, its a fairly common thing wrong with those type front loaders soi have written this tip covering how to clean that filter, http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 06, 2011 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
Machine won't spin, therefore water cannont be emptied. The agitator works. I have a top open Kenmore 90 series machine.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 14, 2011 | Kenmore Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
My kenmore washing machine (front loader, model #970-C42062-00) is not spinning the clothes dry. sometime water is left in the drum other times not. the drum is making a squeaky noise as well. what...
heatman101
Mar 22, 2011 | Washing Machines
My ge front end loader washer won`t spin water or pump water out
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
Kenmore Front Loader Washer Doesn't Drain
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 25, 2010 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
164 people viewed this question
Top Washing Machines Experts
