Question about Garmin Forerunner 305 GPS Receiver
GPS unit won't charge when placed on cradle and plugged in wall
This is the first time I've had the problem. Normially when I place the forerunner on the charging cradle "Battery Charging" will read on the screen. But that isn't the case now. It either wont do anything or it shuts on and off and says low battery but isn't charging.
  • princessj813 Feb 07, 2010
    How do I change the battery to the main unit itself? I can't find any instructions in the owners manual and can't figure it out by looking at the forerunner.
  • 12,061 Answers
You may have to replace your battery, these go faulty often, even though they seem OK.
Posted on Feb 07, 2010
Yesterday i download the forerunner 205 software from the garmin website. after i connect my unit using usb to the computer, my garmin won,t power on immediately. i tried to reset it (soft and hard reset)...
Did you install the software correctly? Because such errors appear usually when the update/upgrade is not finisher or was not done in a proper manner.
If possible try to verify the device on another computer (a friend's) to see if the same problem appear.
If the problem persists I'd say you've burned out your battery (hope not the hole Forerunner...!).
Mar 05, 2011 | Garmin Forerunner 205 GPS Receiver
I reinstalled the driver of my garmin forerunner 205 but it is still not recognized by my computer. it has been working for over a year but now I do not get any connection and the device is not recognized...
When you connect the unit to the cradle is there any reaction from the unit? I would try using a different USB port and cord first if this dosent fix your problem the next step would be to obtain a new cradle for your unit. They can be purchased here http://www.gpscity.ca/garmin-forerunner-205-305-charging-cradle.html.
Hope this helps!
Feb 25, 2011 | Garmin Forerunner 205 GPS Receiver
Forerunner 305 will not charge. Connection seems like it's not making between cradle and unit. If i wiggle it, sometimes it will briefly connect
Try cleaning the contacts on the back of the Garmin with an eraser then wipe the contacts clean on the Garmin and on the docking cradle with a rag dipped in methylated spirit or isopropyl alcohol.
Jan 15, 2011 | Garmin Forerunner 305 GPS Receiver
Charged in the cradle, came on a bit, but didn't last long. Now completely dead. I read to hit mode and reset at same time. How do I find reset when the unit is off?
Before you reset have you checked the fuse in the car lighter adapter.... unscrew the silver tip of plug CAREFULLY its spring loaded check fuse...
Oct 29, 2010 | Garmin Forerunner 205 GPS Receiver
Won't turn on
The device may just be locked up and needs to be reset so that it can start up normally. To do a reset on the device, make sure the unit is plugged in to the charging cable/cradle and connected to power. Next press and hold the Mode + Reset buttons at the same time for approximately 10 seconds. After releasing the Mode + Reset buttons, attempt to power the device on normally.
Dec 18, 2009 | Garmin Forerunner 305 GPS Receiver
My forerunner will no longer turn on or even charge, can they be repaired or am I best to buy a new unit?
Garmin will repair it for about eighty bucks.
http://www8.garmin.com/support/outofwarranty.html
But first, try cleaning the electrical contacts on the forerunner and the cradle by rubbing them with a pencil eraser. The slight abrasive should remove any oxidation on the metal. A bad contact between the unit and the cradle could be your problem.
Jul 22, 2009 | Garmin Forerunner 205 GPS Receiver
Garmin 305 wont power on, wont charge on cradle
Same thing happened to mine. Put the unit in the cradle (just like you are going to recharge it) and press the reset and mode button at the same time for 3 seconds. This will "wake" the unit up.
Mar 30, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin forerunner 305
My husband is the best!  Here's what he did and now it works:
Hold the on/off button and mode button, then hit the lap/reset button.
Hope this helps!
Jun 21, 2008 | Garmin Forerunner 305 GPS Receiver
Forerunner 305 won't charge
Question: My Edge or Forerunner 205/305 won't power on. Is there a soft reset that I can do?
From the Garmin web site.
--------------------------------------------------------------------------------------------------------------------------------------------- Answer: If a Forerunner or Edge 205/305 is unable to power on, a soft reset can be performed to un-freeze it. This will not erase any user data and is most effective if the device is connected to the computer while performing the reset.
To reset the Forerunner or Edge 205/305:
  1. Connect the device to the computer using the USB cable
  2. Press and hold the mode and reset (lap) buttons together for 10 seconds
  3. Release and wait for 3 seconds
  4. There should be some indication of battery charging (either Finished or In Process)
  5. Power the device on while keeping it connected to the computer
In addition, please make sure that the device has the latest software version
May 26, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
292 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
