Question about HP PSC 1210 All-In-One InkJet Printer
It is giving me a error message saying check print cartridge
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
Printer keeps giving alignment problem message
hello, remove cartridges, clean with something soft the wiring of both printer cartridge slot and cartridge itself, make sure you use alcohool, sanitary or even parfume wich dries fast and is not greasy, after that power up printer and check to see if everything is alright, if other error ocurs reply here.
hope that helped, best regards
Feb 28, 2014 | Lexmark International Lexmark 7300 Series
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
Cannot print, scan or copy. Continue to receive
Solution
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts. Click here to see how.
  3. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
  4. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty.5. Replace Cartridge.Please rate my response!!!Thanks,SF
Jan 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Check print cartridge blinking cartridges refilled today and installed laptop not recognising printer as result
    • If the message on the computer does not identify a particular cartridge (it says only Print cartridge error ), follow the steps below to determine which cartridge is causing the problem.
      1. Open the cartridge access door.
      2. Remove either cartridge (not both).
      3. Close the cartridge access door.
        • If the computer message is Print Cartridge Error , then the print cartridge that is still in the printer is the problem cartridge.
        • If the computer message is NOT Print Cartridge Error (instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed), then the cartridge you have removed is the problem cartridge.
  • If the problem still occurs, the electrical contact between the cartridges and the printer might be bad. Removing and reseating the cartridges might help. Also, you can clean the electric contacts on the cartridges with a dry cloth.
Hope that will help solve your problem!
Jan 16, 2010 | HP PSC 1205 InkJet Printer
My printer will not accept a new black cartridge.
ITS NOT THE BLACK CARTRIDGE!!! Try changing the colour cartridge and see what happens. When a 9600 checks ink levels it does the black ink first, then the colour, if the colour is low it goes back and checks the black again but will constantly give an error message for the black cartridge. Sounds bizarre but try just the black cartridge in with no colour. print a test page in black only, if that does not print then it is a fault. Also make sure the driver is updated!!!
Feb 16, 2009 | HP DeskJet 9650 InkJet Printer
PRINTING ERROR
I would not recommend you refilling HP ink cartidges.
Because no other ink cartridges can give you a better quality or value for you money.
Even if you call HP and say that you are using reffiled ink cartridges then they will not support you even if you are in warranty.
Because Genuine HP Cartridges are manufactured under SIX SIGMA Quality assurance and they give Value for you money.
What i can suggest you is to try a Geniune set of ink catriadges and check.
Good Luck
Sep 01, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Hp Officejet 7110 Not Printing From Computer
    HP 7110 Printer
    The problem with the printer is it does not work, there are flashing lights and the message it gives you is to turn the power on and turn it back on. Needless to say when I reboot the system and unplug the printer and plug it back up, I get the same message, does anyone have any solutions to this problem????
    Sep 07, 2007 | HP OfficeJet 7110 All-In-One Thermal...
    Wrong Cartridge Error Message
    The Print Head might be the fault of that,try replacing the print head and see if that helps
    Jan 31, 2007 | Canon MultiPASS F50 All-In-One InkJet...
    HP PSC 1210 All-In-One InkJet Printer Logo
    88 people viewed this question
    Seeker5211
    Seeker5211
