Carlsbro dsp marlin amp is buzzing loud constantly even without anything plugged in, can anyone help?
Cheap power leads?
Posted on Jun 22, 2011
    Champion:
  • 211 Answers
If it's buzzing even when the volume is down, there must be a problem in the power supply.
Then you have to look if there's a diode or capacitor not correct.
Kind regards,
Gerard
Posted on Feb 07, 2010
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Why does my carvin sx-300 amp buzz
Most Amps will buzz or hum when there is a bad ground. It could be because you're plugged into an outlet with some other piece of equipment on it like a motor. if it buzzes on every outlet then there's probably a ground issue in the amp. You can try cleaning your 1/4 jacks with cleaner cause sometimes they'll get cruddy and make for a bad connection. I wouldn't recommend opening the amp and messing around with anything since you could zap yourself. If the amp buzzes withouth even having anything plugged in, then yeah, it's probably the amp with the bad ground. If it buzzes with instrument plugged in, then maybe it's a plug on your instrument since they have to deal with movement and can go faulty after a while. Good luck!
Oct 21, 2014 | Music
Where can I get a user manual for Carslbro Marlin 8400 DSP power mixer amplifier
Try Googling (Carslbro Marlin)(8400 DSP)(manual) without parens.
Jan 17, 2013 | Audio Players & Recorders
Carlsbro Bass Reactor 400 bass amp - power section dead
• Could be drive transistor , output transistor or both on the main amp.
But check for power supply and in the preamps also.
• A signal tracer will come in handy when troubleshooting these kind
of symptoms.
• Measure supply voltages,
• Check offset voltage
• Check idling current
Isolate , and trace afterwards.
• Schematic is really needed when there are burnt and unrecognizable
component. But one can use similar schematics to analyze circuit
problem.
Aug 01, 2012 | Audio Players & Recorders
Buzzing Refrigerant Lines
Have someone check your pressures & temperatures in your refrigeration system. Also check the compressor amps with an analog meter to see if the amps fluctuating. There might be something wrong with the compressor.
Jun 12, 2012 | Bryant Heating & Cooling
I bought a behringer bxl3000t yesterday and when I plug it to the wall it gives me a pretty big noise, even when the bass is not plugged in, If I turn the amp on without anything plugged and all the knobs...
Since you just bought this, exercise your warranty (assuming you bought this new). The amp probably will have a slight buzz with nothing connected... the question is how loud it is. If you can hear it loud at five feet, that is too much. If you bought this used, prepare to have it serviced at a shop.
Jun 29, 2011 | Behringer Ultrabass Bxl3000
I have a Marshall MG100DFX. I turned my amp on a few days ago and I heard this loud sound (not the standard hum/buzz that you hear when you plug a guitar into an amp; it sounded more like a foghorn). Now,...
I would try hitting the side of the amp before turning it on. There may be a loose piece of solder or other conductive particle stuck somewhere. Bang the cabinet rather hard with your fist. If that doesn't help it might be a loose solder connection at a resistor or capacitor but a tech should check that out.
Dec 04, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Buzzing in speakers on Carlsbro Marlin 8400 Power Amp
If your volume is down and there's a hum, then it could be that your capacitors in the power supply are blown. Also there could be a problem with the bridge rectifier, possible that there's 1 or more diode's defect. Any technician can reapir that.
Hope it helps,
Gerard
Jan 20, 2009 | SpeakerCraft MZC-66 Amplifier
NAD T751 constant buzz
It is a known problem with this model. The source of the buzz is the Dsp power supply. On the DSP board itself there is a 2200my\f/16v capacitor that is defective . Usually the capacitor will turn brown and swells due to overheating. Replace it with a higher temp rating capacitor with the same capacitance and voltage specifications.
Sep 26, 2008 | NAD T751 Receiver
341 people viewed this question
 Grubhead
Grubhead
