Question about Bushnell Optics
Double vision I have a model Ensign Bushnell binoculars and I see a double image when I look through them.
    Brigadier General:
  • 3,006 Answers
The yoke which connects the eyepieces and keeps them aligned as the focus changes is damaged. If you can easily move one eyepiece back and forth with respect to the other then the yoke has broken, if not then it's bent, probably cracked and waiting to break.This is easily the most common fault on most binoculars, and it's always uneconomic to repair on budget brands such as Bushnell.
If bent, the yoke *might* be able to be straightened, but it will be weakened and the alignment afterwards will rarely be spot-on. If broken, then the yoke must be replaced professionally but the repair will cost more than replacing the binoculars with new. In any case, it's unlikely that Bushnell even list the spare part for it. The break cannot be simply glued: the contact area is too small to carry the loads it has to carry, and you also usually find that the yoke bent before breaking anyway so you then have all the same problems as you do with a bent yoke.
The fragile nature of the yoke is why binoculars must always be inserted into their case with the objective lenses facing down; this avoids shock loads on the delicate yoke assembly.
I hope that you've found my posting to be of use and in return ask only that you take a moment to rate my answer.
Posted on Feb 13, 2010
Left lens no clear view and both lenses blink
What color is it when you turn on you Bushnell binoculars? I think this Bushnell 26-3150 is a digital NV devise that uses CCTV image tube. In other words, it not anolog operation, but uses a digital devise to convert the iit (image intensifier tube) analog signal to a digital signal. There are advantages using digital signal, increase pixel rate, low power comsuption, etc. stewbison. Call Bushnell Night Vision and listen what they have say on this matter. stewbison.
May 20, 2011 | Bushnell 26-3150 Nightvision
My discover binoculars have a double vision. They used to work fine. Are they repairable? Where?
Contact Bushnell, who was the manufacturer of Bausch and Lomb binoculars. They can service them for you.
Contact number for Bushnell is 800-423-3537.
Ben Lizdas
Sales Manager
Eagle Optics
www.eagleoptics.com
Dec 07, 2010 | Bausch and Lomb Discoverer Binocular
Binocular eye cup replacement
this can be procured by contacting bushnell customer service at 800-423-3537 option 1.
Oct 03, 2009 | Optics
I dropped them and they are seeing double now they are the xtra-wide bushnell ,how do i get them back in focus
Try grabbing the binoculars in both hands and twisting the body in the opposite direction of the double vision until the images coincide.
Sep 25, 2009 | Bushnell Xtra-Wide (4x30) Binocular
Unable to focus my Bushnell 7x35 insta-vision binoculars
insta-vision bino's are self focusing no adjustments.
Jun 05, 2009 | Bushnell "Insta-Focus" Binoculars
Bushnell binoculars /double image
they have to be aligned if you want mail them to me for an estimate..larry@reichinstruments.com
Apr 19, 2009 | Bell & Howell Optics
Double vision
I'm assuming you have set the dioptre correctly for your eyes.
Normally this is caused by a collimation error when one (or both) prisms move. This can be by a small amount.
Your going to have to take them in for service/repair to fix this as is not a DIY problem. (Unless of course you have a collimator lying around)
Mar 24, 2009 | Bushnell H2O 13-2412 (12x42) Binocular
Bushnell Ensign 7X35
since some models change the size of the eyecaps they use ,your best bet is to take off the other side and mail to bushnell for a proper match
Jun 17, 2008 | Bushnell Optics
Double vision
The distance between the centers of the eyepieces of your binocular must be the same as the distance between your pupils. This distance is adjusted as follows: 1. Focus on a distant object. 2. Pivot the two halves of your binocular farther or closer apart until you can see a single unobstructed, circular field of view. Make sure to focus on a distant object when you do this because when you focus on a close object you always see two slightly overlapping circular fields. Your binocular may have a scale on the top, between the eyepieces, to help you remember this setting.
Jul 03, 2007 | Bushnell Powerview - Compact 10 x 25...
Optics Logo
1,266 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
