Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Windows 7 can't find it on my network. Both the computer and the printer report that they are connected to the network bu my installation will not complete because it can't find the printer.
    Scholar:
  • 93 Answers
Here you have the Windows 7 driver for your printer
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-79353-1&lc=en&dlc=en&cc=us&product=2512010&os=4062&lang=en
Download and install it
Thank you
TechSaver
Posted on Feb 07, 2010
Can i make a hp officejet 6110 printer wireless
SETTING UP A WIRELESS PRINTER WITHOUT A WIRELESS ROUTER - WINDOWS 7
Install Virtual Router first "Turn any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot Spot."
EditByBSEditor: Virtual Router turns any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot SPOT using Windows 7's Wireless Hosted Network (Virtual Wifi) technology.
The Wireless Network Create/shared with Virtual Router uses WPA2 Encryption, and there is not way to turn off that encryption. This is actually a feature of the Wireless Hosted Network API's built into Windows 7 and 2008 R2 to ensure the best security possible.
You can give your "virtual" wireless network any name you want, and also set the password to anything. Just make sure the password is at least 8 characters. http://www.brothersoft.com/virtual-router-327895.html Then install Connectify-Me Connectify is an easy to use software router for Windows 7 computers. After downloading and installing the lightweight application, Connectify utilizes your computers' built in Wi-Fi card to wirelessly share any available Internet connection: a cable modem, a cellular card, or even another Wi-Fi network. Other Wi-Fi enabled devices including laptops, smart phones, music players, and gaming systems can see and join your Connectify hotspot just like any other Wi-Fi access point and are kept safe and secure by password-protected WPA2 Encryption. http://www.connectify.me/ Then reboot computer
Aug 18, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Tip
How to determine your computer's MAC address Applies to Windows XP, Windows...
Applies to Windows XP, Windows Vista and Windows 7
1. Click Start - Run
2. Next enter "CMD" and click OK
3. Next at the command prompt type "ipconfig /all" and press enter
At this point all your active connections will list on the screen. Note you may need to scroll back up the window to get to the MAC address info you need. Also keep in mine if you are connected to your wired or wireless connection because both will have a MAC address assigned to them and they will be different.
4. Look under the Local Area Connection if connected to your network via a wired connection or Wireless Network Connection if connecting via a wreless connection.
Once under the right connection you will want to look for the line that shows "Physical Address" this will have what the network cards MAC Address listed.
Note if you have Windows Vista or Windows 7 and you access a lot of different networks then you may have a lot of Tunnel Adapters list that causes overflow in the CMD buffer. If this happens the top part of the "ipconfig /all" report will get cut off. To fix this all you need to is turn off IPV6 in your network properties and reboot your computer. This will remove the ones that are tied to IPV6. After you reboot you should be able to see MAC address for your netork devices. After you get the MAC address it is recommended that you turn IPV6 back on because there is some programs that have been writen for IPV6 for when it becomes a standard.
How to turn off IPV6 in Windows 7 and Windows Vista
Here is an example of what "ipconfig /all" looks like on a computer running Windows 7
Other Helpful Links
How to allow ping request through Norton Internet Security 2010 Smart Firewall
How to check and change you computer IP address in Windows 7
How to enable and disable printer and file sharing in Windows 7
How to take file ownership in Windows 7 and Windows Vista
How to change your drive letter in Windows Vista and Windows 7
on Aug 21, 2010 | Computers & Internet
HP Color Laser Jet printer CM1312nfi: scanner no longer working; when I try to scan, receive error on printer:scanning error, cannot connect. Printer is networked. This error occures only on a networked...
Go to your network and sharing center. Choose homegroup and sharing options. Change advanced sharing settings. Under your home or work profile, scroll down to file sharing connections. Switch to enable file sharing for devices that use 40 or 56 bit encryption. If that does not work, under password protected sharing, select "turn off password protected sharing". This is not recommended if you use your computer in multiple locations (laptop). I have found that turning all of these features off, running a scan from the printer successfully and then turning them back on, Windows seems to be comfortable allowing the printer to connect to the computer.
Jul 22, 2010 | HP LaserJet CM1312 All-In-One Printer
I loaded Windows 7 on my hp laptop and have lost the wireless connection between the laptop and wireless Dell printer.
If this is a new installation of Windows 7 and you have never used the printer on this installation, you will need to install the printer from scratch. If you have the installation disc that came with the printer, pop that into your computer and follow the installation steps. If you do not have that disc, you can look up your specific printer model and download the driver to your computer. Then use the Add Printer Wizard in Windows 7 to search for printers, and if yours is powered on (and both the computer and the printer are connected to your network) it should see it, and then tell it where you saved the driver.
Jul 15, 2010 | Dell P703w Printer
I have a computer with windows xp connected with usb to my canon pixma mp780 and connected to my network my laptop with windows 7 is connected with wlan to the network.the laptop see the printer but i...
I've had a similar problem trying to print to a printer that was not on my laptop but connected to the network through a desktop that was connected to the WiFi router and a cable modem.
If you can see the printer, maybe the driver is already installed.
In my experience, I had to log on as the administrator to print to the printer but I have windows 7 on all 4 of my computers.
I don't have xp anymore.
Maybe xp is the problem.
Jul 02, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Can't connect to remote Deskjet 5150
Please, how does your Win 7 x64 machine compare to anything else on your network?
Can any other computer see that printer at all?
When you install the printer locally does that mean by USB, or what please?
Nov 29, 2017 | HP DeskJet 5150 InkJet Printer
I want to use a printer on my network. printer
hi: go to the hp site for downloading driver for windows 7 they are there
Microsoft Windows 7 (32-bit)
Nov 01, 2009 | HP LaserJet 1000 Printer
Problem with my printer
Windows 7 has compatibility problem with most of the peripherals on the market. When you switch to Windows 7 you must ensure that your printer and the other devices are supported. Your printer disk won't help, as it does not have Windows 7 disk. This printer is not compatible with Windows 7, drivers are not been released, therefore you will need to replace the printer or downgrade the system.
Jul 21, 2009 | HP DeskJet F4280 All In One Printer InkJet
Printer is offline
go in control pannel> printer> right click on your printer there was option use printer online click on it
Jan 17, 2009 | HP Deskjet 3915 InkJet Printer
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
62 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
