I just purchased a onkyo hts6200 and when the volume is over 35 or there is a loud noise in a movie or TV show, the receiver turns itself off. Also, when I performed the speaker set up, it shut off when it got to my back left speaker.
    Brigadier General:
  • 8,546 Answers
There's a clue in that. Swap the back left and right speakers and see what happens with the setup. If it followis - it's the speaker. If it goes away there was probably somethign amiss with its wiring. Report back.
Posted on Feb 07, 2010
While wathching TV, the typical volume level
Cleared all AV settings and reprogrammed.
Jan 30, 2010 | Onkyo TX-SR703 Receiver
My onkyo cuts off during loud sounds also. What can I do to stop
This seems to be a fault with your Amp,so needs to be replaced
Aug 15, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR705 shuts down suddenly
Onkyo receivers have a safety circuit in them to protect the Amplifier from blowing up:
If you listen closely when it shuts down ( after a loud scene ) there is likely a loud 'Relay Click'..
If this is what is happening you might be able to verify it by turning the volume all the way 'off' and waiting for the circuit ro reset ( releasing the safety relays & returning power to the internal Amplifier ) : you should hear another click, yhen you can bring the volume back up carefully and there will be sound again.
This safety circuit trips when then Onkyo receiver detects an 'Over Current' condition on the
' Power Supply ' that feeds the internal 'Audio Amplifier'..
Generally caused by:
1.
Improper load presented to the Amp outputs ( FL, LR, RL, RR, SUB, CENTER )
If you can ( one at a time ) turn off the SUB, Center, Fronts and Rears: trying to re-create the failure each time while you have one part of your system disabled or having their level turned way down..
You can isolate where the problem is coming from.
- any or all of these speakers being the wrong Impedence ( I.E. 4 Ohms instead of 8 Ohms )
Unless the receiver manual or the sticker near the 'speaker connetor' specifies a range or another value, you should assume 8 Ohms. Your speakers should say on the back of them.
- any of the speakers being connected in parallel ( 2 speakers to a single one speaker output ) .. Two 8 Ohm speakers connected in parallel make a 4 Ohm load to the amplifier.
- If the Suwoofer is Passive ( Not having its own power cord and amplifer ) it has a
Passive Crossover : this crossover can have its own power rating or limitation.. If it is constructed with capacitors that have too low of a working voltage, then they can saturate and the crossover itself can present a load to the amplifier that will case this 'Over Current Shut-Down'..
You user manual should detail this.
Ed
Apr 09, 2009 | Onkyo TX-SR803 Receiver
Onkyo TX-SR705 Muting Problem
if what Dark_Orbit said does not work try doing a master reset by ressing and holding the dvr/vcr button and stand by button simultaneously. This would erase all your assignments so you would need to reassign all your sources hooked up to your onkyo.
Mar 04, 2009 | Onkyo TX-SR705 Receiver
Have to turn the volume near max on my Onkyo receiver to hear TV
it sounds like a source level adjustment refer to your users manual and see if there is a way to turn the SLA up and if not then a small amp can be bought or purchased to boost the sound from the tv. check out the Fiio E5 for examples it might just do the trick
Feb 18, 2009 | Onkyo TX-SR500 Receiver
Volume Control
I had the same issue, there is a Late night mode on the remote that minimizes the volume of a loud scene so you don't have the constantly adjust the volume. Works great if you are trying to watch a movie while others are trying to sleep.
Dec 15, 2008 | Onkyo HTR500 Receiver
My Onkyo Receiver TX 601 is turning itself off
Several things can cause this: Loud signal passages can momentarily draw high currents at the mains, especially if you have unit plugged into power stripe with other equipment. Or if unit is plugged into isolation transformer, current draw may exceed output of transformer. Too many speakers hooked to output or if one is bad (partially shorted due to overheating)
Apr 04, 2008 | Onkyo HTR500 Receiver
May not help, but I had the same thing when I turned up the volume.. off it went.. then I found my two surround sound speakers had the wires shorting. Looks like a safety switch if there is a problem. Could check if the wires are crossed, shorted, and/or thick enouch to handle the volume.. test it by just having the stereo speakers enabled. Cheers,
Jan 11, 2008 | Onkyo HTR500 Receiver
Volume Control
How do you have it hooked up to speakers (are you using a center channel)? What listening mode are you in (dolby digital, stereo, pro-logic...)? It sounds as though you're not getting center channel info....
Jan 09, 2008 | Onkyo TX-SR605 Receiver
104 people viewed this question
 Grubhead
Grubhead
