Question about American DJ Quick Scan Sys 4 Scanner System S-O System
We areusing an American DJ Sytem model ''Quick
We are using an American DJ Sytem model ''Quick Scan System. I turned on the system, the fan and mirrow work, however the light did not light. All connections have been checked and are good. We need help with this problem. Thanks, Dave
  • 30 Answers
Hi Dave, nice to meet you,
Um...You might want to change the light.
I am not responsible for any damage
-K.R.
P.S.- I am British
Posted on Feb 07, 2010
My fog storm 1700 turns on but the machine will not heat up
Replace the circuit breaker by opening up the machine. You do this by unscrewing all the screws and exposing the circuit board. You will then be able to detach the 2 cables going to the circuit breaker and unscrew the circuit breaker's thread on the outside thus releasing the circuit breaker. Hope it helps!
DJ EM-A
jmavila02.wix.com/djem-a
Nov 18, 2011 | American DJ Fogstorm 1700hd Fog Machine W/...
Light is dead all fuses are good.. Maybe bad transformer ?
Probably NOT the transformer as most of these have switching type supplies. A Chauvet unit I have would not light and the problem was the socket for the Halogen bulb. The socket had burned and the contacts were so burned they would not contact the bulb. Worse, you can't even see the problem as the socket is ceramic and has a mica like cover. Replacement of the socket fixed the problem. In the Chauvet unit they had a very cleaver lamp power supply. That threw me off because there was no voltage at the socket... until I put the Oscilloscope on it... then there were tiny spikes. It turns out the supply sends tiny spikes out and IF the lamp is there and contacts are good, the supply senses the load and the feedback starts driving the supply to full output. I wasn't able to see the burned contact until I uncapped the socket. Just maybe you have a similar problem. These 250 watt Halogens with the tiny pins carring 11 amps just are ******* the contacts in the sockets.
Aug 05, 2011 | American DJ Supply American DJ Accu Scan...
Hi there, I have an american DJ Dekker LED. I plugged it in and put it into Sound active / sound to light mode. I'm getting response to sound because I can hear and see the fan inside the unit...
I have OFTEN found that a cable has come loose. Open the unit and look for such a situation. Also make sure the motion (probably a disc) is working/rotating since with high power LED devices, they have interlocks for safety to keep beams moving.
Jun 24, 2011 | American DJ Supply American Dj Dekker Led...
The cooling fan is remains running on my scan 250 if the light is plugged in.
It's American DJ, buy something more Professional and this won't happen, but at least your light shouldn't overheat.
Mar 16, 2010 | American DJ DJ-Scan-250 Effects Light...
Shoots out liquid instead of fog...
that thing(the heater) just doesn't work well,
bring it to someone to repair it
Apr 23, 2009 | American DJ Dyno-Fog-II Fog Machine W/...
Dj deck
hello -  i purchase used xdm-352 mixers- working or not if you are interested -  give le a shout -  203-910-7903 John
May 07, 2008 | American DJ Q2422MKII 19" 3 Channel Mixer...
American DJ Vaporizer Fog hog
Sounds like the pump either is not working or can't inject the fog fluid ( solution of distilled water & glycerin ). My unit clogged up, so I took it apart and cleaned out the lines. Be sure to run pure distilled water through unit, after each use.
Oct 30, 2007 | American DJ Fogstorm 1700hd Fog Machine W/...
128 people viewed this question
Top American DJ Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an American DJ Audio Player and Recorder Expert? Answer questions, earn points and help others
