Question about Frigidaire ATF6000ES Front Load Washer
My frigdairr Frigidaire GSTF1670AS0 will not agatate or spin the motor trys to turn but cant> is the motor the likley problem?
  • 1,531 Answers
It could be the problem but the first thing i would look at is the drain pump and check for anything that may be obstructing it from turning this will cause the washer not to run properly
Posted on Feb 07, 2010
My laundry center washer will not turn on or fill or anything .the motor trys to start and kicks out after a second even when its not turned on.the motor gets red hot when I turn the power on. thanks
Something in the drive train is preventing the motor from spinning up and is causing the motor to have too much current go thru it - hence the real hot condition. Do not turn motor on till you find the issue lest you burn out the motor windings!
Get rid of the obstruction and you have resolved the problem. Look for a stuck sock or something in the drive train gumming up the works.
Aug 31, 2015 | Frigidaire Washing Machines
When i go to start my dryer model # aeq6700fso all it does is make a buzzing sound no heat and drum does not turn? i checked the belt is fine and motor spins freely by hand
If the motor is hummming or buzzzing it most likly the motor or a bad wire conection to the motor.
you can try to turn the drum by hand and retry to start the machine.. if this does work, you have a bad spot on the motor and if it does not and you can verify the noise is coming from the motor then the motor is most likley bad.
Oct 06, 2010 | Frigidaire Affinity AEQ6000WH Dryer
We have a Frigidaire FWTB59RGSO front load washer. The fast spin cycle is not working properly. The shocks on the bottom were replaced because they were broke. The problem has not gone away. It is...
I have a front loader washer # fwtb59rgso and it wont spin or agatate, everything else works fine. feels like normal drag on the drum when I try to rotate it. Any ideas what could be wrong?
Nov 28, 2009 | Frigidaire Washing Machines
I have a top loader maytag washer which doesnt want to spin on the spins cycles or will it agatate? any ideas
Usually the machine will not spn because the lid switch is not working properly. It could be stuck or broke. Do you hear a clicking noise when you raise and lower the lid? If its not doing either spin or agitate could have a bad transmission, motor, belt, etc
Sep 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore 4025090 washer spins but will not agatate
problem solved ,agitater dogs were broken up inside the agitater hub replaced these and works fine now ,
Dec 10, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag washer will fill but never starts cycle
motor is faulty most probably
or mayby faulty capacitor on motor
Mar 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore washer 80 series 4 years old
my washing machine is not rinsing and spinning
Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 4 years old has prob
You may not have the coupling seated properly. However, if the unit is agitating and spinning at the same time, you may have a more serious transmission problem.
Washer go though all cycles but no spin
the motor operates off the timer cams inside the timer. in the wash mode the agitator turns in one direction. when it calls for tub empty the motor reverses direction and actuates the pump. at this stage the tub should spin. sounds like the timer is bad for this one function. timers cost around $120. (mechanical timers)
Aug 22, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
114 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
